    MMM-GooglePhotos
    294 Posts 56 Posters 409.5k Views 59 Watching
    • RoggerFabriR
      RoggerFabri
      Hi @Sean , thanks a lot for your time and effort on creating this module, I was searching for something similar for a long time already. From time to time, I’m getting several Forbidden 403 responses from the requests to load new pictures, this gives the impression that the pictures are stuck. Do you have an idea of what might be causing that?
      ? B 2 Replies Last reply Reply Quote 0
        A Former User @RoggerFabri
        @RoggerFabri
        All those kinds of errors (403, 500, …) means network/server errors. Nothing could do in client(module) itself. Only thing would be just waiting(stuck) problem solved by network/server.
          bhepler Module Developer @RoggerFabri
          @RoggerFabri - I don’t know if this is relevant, but I know Amazon AWS bulk storage returns 403 errors if you get the URL wrong. I’m not sure if their security model is so granular that files have to be authorized independently or if the wrong URL attempts to serve up the directory index and that file is locked out. And I have no idea if Google uses the same technique.
          Either way, I would check the request to make sure it is pointing to a valid asset.
          • G
            gonzonia @Guest
            @Sean 403 is a “forbidden” status. Is it possible to catch that status being returned and then go back to refreshing the token and starting the process over from there?
              A Former User @gonzonia
              @gonzonia
              There could be possibility “dead url after it’s lifetime”(60 minutes) but to avoid it, photos working urls would be rescanned and refreshed per 50mins.
              Of course, if there be network error to prevent resurrection, it will not work. That is not the token issue.
              • O
                orayoflighto Project Sponsor @orayoflighto
                • G
                  gonzonia @Guest
                  @Sean Okay. Thanks. As a stab in the dark I changed the pageSize in the getAlbum call to 25. It’s been running now for 14 hours without an error. If it’s still good in the morning I’ll restore the old version and see if the error comes back. I don’t remember what led me down that path but something this morning made me think to give it a try.
                  • G
                    gonzonia @gonzonia
                    @Sean So I had over 24 hours with it working. Swapped back to the original file and it errored out within 2 hours. Swapped back to new file and again errored in 2 hours. I don’t get it. I was mistaken with what I changed, I changed the getImage call to a pageSize of 25. This made indexing take longer. It always returns the TLS error when indexing. I have it looking at two albums. One is big with 937 images. The other is only 129. When the error happens it is always while indexing the first one. Is the large album the problem?
                    [2020-05-02 21:35:51.841] [LOG]    2020-05-02T21:35:51 <log> [GPHOTOS] Start Album scanning (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:44 Class.log)
                    [2020-05-02 21:35:51.845] [LOG]    2020-05-02T21:35:51 <log> [GPHOTOS:AUTH] Token is alive. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:20 Auth.log)
                    [2020-05-02 21:35:51.848] [LOG]    2020-05-02T21:35:51 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                    [2020-05-02 21:35:53.427] [LOG]    2020-05-02T21:35:53 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                    [2020-05-02 21:35:55.358] [LOG]    2020-05-02T21:35:55 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                    [2020-05-02 21:35:56.996] [LOG]    2020-05-02T21:35:56 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                    [2020-05-02 21:35:58.431] [LOG]    2020-05-02T21:35:58 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                    [2020-05-02 21:35:59.769] [LOG]    2020-05-02T21:35:59 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                    [2020-05-02 21:36:01.544] [LOG]    2020-05-02T21:36:01 <log> [GPHOTOS:CORE] Indexing photos now. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                    [2020-05-02 21:36:16.288] [LOG]    2020-05-02T21:36:16 <log> [GPHOTOS:CORE] Error: Client network socket disconnected before secure TLS connection was established (/home/pi/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:124 GPhotos.log)
                      philmavedzenge
                      I’m having the same issue above as @gonzonia . After some time the module stops changing the images and they become stuck until I refresh the browser. This only started about 2 or so weeks ago.
                      • G
                        gonzonia
                        @Sean Okay. I think I’m understanding the behavior a little more. It ran yesterday for over 12 hours. When it failed, it happened on indexing, then a single image was loaded successfully. After that all images failed and the module never tried refreshing the token or indexing again.
                        I don’t know what the cause of the network socket disconnected error is, but is there any way for the module to recover?
                        If it recovered even in another 50 min when it should do another scan, I think that’s reasonable. The problem is that the error is fatal to the scanning process and all the URLs are bad after the 60 min lifespan. The module never restarts the scanning after the initial failure.
                        • K
                          kykzzang
                          Dear @Sean
                          Here is a log from the latest commit.
                          It hasn’t been recovered yet. but it has good Internet access.
                          “Image loading fails…” logs keep accumulating.
                          Thanks.
                          [2020-05-06 21:23:04.194] [LOG]    [GPHOTOS:CORE] Indexing photos now.
                          [2020-05-06 21:23:07.145] [LOG]    [GPHOTOS:CORE] Indexing photos now.
                          [2020-05-06 21:23:09.834] [LOG]    [GPHOTOS:CORE] Indexing photos now.
                          [2020-05-06 21:23:15.916] [LOG]    [GPHOTOS:CORE] Indexing photos now.
                          [2020-05-06 21:23:18.606] [LOG]    [GPHOTOS:CORE] Indexing photos now.
                          [2020-05-06 21:23:20.520] [LOG]    [GPHOTOS] Getting 218 photo(s) list from 'display'
                          [2020-05-06 21:23:20.521] [LOG]    [GPHOTOS] Total indexed photos: 218
                          [2020-05-06 21:23:21.424] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_ZAGkc2g_-LhINGiFXSqctac3jIms5eqooJW4_hLdNP4ehf_KR2peBRmgNVFUCDKVOT
                          [2020-05-06 21:25:21.010] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_aRmsMj1l0vutiPh7HG5ZlkmEV-af6cPOPI_SES2O6PzX8gaGfLmJoMMPDw3xcZ3beo
                          [2020-05-06 21:27:21.095] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_YKc6UhR4ZvdFPODYflw6cJYOaApkgyig85PP2UBuqyRIwVFreSLYerOS0L6eI9KlCB
                          [2020-05-06 21:29:20.803] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_ZANdgPjWShaWBl8CgPt8LgN2EVYO6Muq4GwolO8eJh1i65kVxRQEpwYokdjwrxD5bW
                          [2020-05-06 21:31:21.026] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_aC6voVTY4cjTOGEGner4cuOGtUC41vpPTElactvgQiPCRufJIt-CekLjGvna1lNf5q
                          [2020-05-06 21:33:21.279] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_aSF39eNT_5LY4V7Q1pD-VWqsYU2d3oIOPtaTZEPIdDT20UQfKbcgmesm0ylq2pZDP6
                          [2020-05-06 21:35:22.344] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_bb6fTpmmBjYcDWx_jS8TbY_lj9SyxNX423SIWrRVPxlmMPeQwsWJTDdyuEqTdrJpFD
                          [2020-05-06 21:37:21.065] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_ZJYlbhKK_ggA67q6TWDFVW1IKKHYyuwH36KyYZ9qKqTOmYL9hfVw5aX2QjumzmcIuA
                          [2020-05-06 21:39:21.220] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_bOkvNs0-l0NP0MC9dL3xjt152FCwXo9SOW1cSyrrSxaYCg-tPYqTs6SqJYPz1jvz_h
                          [2020-05-06 21:41:21.288] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_brpTK4ce4oteU2Te43zXsgUNyobzmk8MkiqFF6jpPr23lh1WrAqwj8dLPKCzbmhNkW
                          [2020-05-06 21:43:21.509] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_YXQKGn4L3DOuTxaqK_khpcrSZDvJggiDLMoQEn8YHfkDm4ZmY4HiDB2kKihBa9lYRp
                          [2020-05-06 21:45:21.225] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_adPN03hNIlKDYJ8QQWct1QUEbYEcDTV9rrN-Bzb-ilGXQ7fBqjxZccWvT6XoGGedrf
                          [2020-05-06 21:47:22.063] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_YiyTxwNVgIYEXnCNt8B3auhdEQ5H2KdEIf2qEcdoPCheIaV6mPde96o2YxmuqNfK5i
                          [2020-05-06 21:49:21.664] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_Yaj48kiRsP2FFtguvyIApL5kPeFGkjzKbFtyP0p9LJSQZIzhuCTEhaTWEH6gD4peFG
                          [2020-05-06 21:51:21.005] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_bG-4fdNDpDGNJI5P91gZBl3Wj9xa3MrxNeAmpgH6ZDstKl5_vPNMlNWEXsSI0Hw_qs
                          [2020-05-06 21:53:21.391] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_bm09bFbINYYpaWRsLcUGMSRGHHuvngYwi-uQKqvWE5JEH12_kWbayq0sUoEGVoZTxX
                          [2020-05-06 21:55:21.004] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_Yvu_S-5wIgSEAjPLs2ekIfRmZxlgWQAurf9RMFun9neeBkQ5KDRs9lvXovnNWrXGDL
                          [2020-05-06 21:57:21.028] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_YJygMYRIxk4kP386m8TBzNrSzu0hOIK5a_PMWai9lsnp0PJkwc4qsbVfYZNA-T7oW5
                          [2020-05-06 21:59:21.091] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_b7Iuy-YjiS6zdyKfd6nXF-7IakajHHaSJ_dvH_qOyh4gdkX1hzI-X7Uk49IN9oHK8y
                          [2020-05-06 22:01:20.645] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_aJHCYEO9T3xoxSU_eV3qF1NL8FUd545Lqf1OUZ
                          [2020-05-06 22:03:20.645] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bEH7pOxzBdRdkA8X9eU4YdshzT-HoaCw9-0XKr
                          [2020-05-06 22:05:20.645] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_YzKj9MLh4hpOiVdujA8fJ26pop4TBfqQfOvemT
                          [2020-05-06 22:07:20.642] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ak9_lafawfAhSbhANtZXBdVHKOejIoGQkaV6jg
                          [2020-05-06 22:09:20.646] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_aQZeAz0lgmTYU5yQeFSTldb3scIuV3JHh5XlRM
                          [2020-05-06 22:11:20.646] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ZAsV0o2wtiNNk3fKwxvPmMXfSWFfZ3qjgFoPv7
                          [2020-05-06 22:13:20.639] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bvB6ykWhOyPUcRLEAns7oT3Ki6feq2XwCwI6CV
                          [2020-05-06 22:15:20.650] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_b_CM8oP6af_yfbt_z1avXwYtCb73Pv5nhZwWgP
                          [2020-05-06 22:17:20.641] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_YTziKyYe6pjVgxePdK1WmlFNvbuxsdBHQMxg0F
                          [2020-05-06 22:18:20.551] [LOG]    [GPHOTOS] Start Album scanning
                          [2020-05-06 22:18:20.555] [LOG]    [GPHOTOS:AUTH] Token is alive.
                          [2020-05-06 22:18:20.557] [LOG]    [GPHOTOS:CORE] Indexing photos now.
                          [2020-05-06 22:18:20.573] [LOG]    [GPHOTOS:CORE] Error: getaddrinfo EAI_AGAIN photoslibrary.googleapis.com
                          [2020-05-06 22:19:20.652] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_b0lHI5Yb2yEo0cvz5PeedACuCUQVXlwh4emujT
                          [2020-05-06 22:21:20.643] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_YCEopH8TdGyRfIY8H8ZUTzsU0qS-X7CO3nmutB
                          [2020-05-06 22:23:20.641] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ZS2xOl1MGDGVD8BSG2RuZ4sA9420QAQTXy-a67
                          [2020-05-06 22:25:20.641] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_boFHSaOpWwMDu8a4Mmk3Wt2uCxMLwx0gvzjkvz
                          [2020-05-06 22:27:20.654] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bg60eryk44zXE1qAXmShms29YBS5CkOqhkWIJm
                          [2020-05-06 22:29:20.653] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_YiAaGQbuwZyzDl8KAPUWdsLaXKsCc6MEmuiEpf
                          [2020-05-06 22:31:20.647] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_br8F5aUbIbDWDk4FTzmawCGeYS8JlH1fYuK8or
                          [2020-05-06 22:33:20.647] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_Zs_BgUJgTgurcCBrDgV8SMQP1Co-lVhT5McCSM
                          [2020-05-06 22:35:20.657] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bA80MDC-Clsfa8Mkh-NgbAboCps1DHRPsupQxj
                          [2020-05-06 22:37:20.648] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bV4Q0F-APfHaNq7pYU1DMHEkKk480oIDLcW9U_
                          [2020-05-06 22:39:20.657] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_a_15C3RmH37JYxvm32cwOHgKt_5eCR8PrA6N9T
                          [2020-05-06 22:41:20.658] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_Z83PeGemOxMHOvciv-a_8__crs-cqQ2XYw8vzk
                          [2020-05-06 22:43:20.664] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_Zxi4V3iJWKOf9F9cN1T29TDt-FFZIpo0FRqBW-
                          [2020-05-06 22:45:20.653] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_atKOkiCTBnM_4IkZELUpjgYhSKrItSGQRSe2lT
                          [2020-05-06 22:47:20.661] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_YIqlfr5fXAdBlmAATjbo4G928V5A7lKMqs_0CI
                          [2020-05-06 22:49:20.661] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bipyHtNScWr3gl4cQVoewCyIlyD-ZfQT_pRb8y
                          [2020-05-06 22:51:20.662] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ZLyGsme1Z5GbQ6AU-AriXZHHd6hQvzI1iWxEiT
                          [2020-05-06 22:53:20.665] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_a3Pgwf0uVyWcUqP8-qaWPh8xOL_mYGqpjEKhhA
                          [2020-05-06 22:55:20.661] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ZoyynSCyzTQfmQ1jO2Ol2jJqYLgBvOMGJ07YcZ
                          [2020-05-06 22:57:20.664] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_b8DtApJPwR13hJkJ6FfAbReueFS389qNjggGkU
                          [2020-05-06 22:59:20.666] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_Yr3nj_Y6RdmqUWA96FG3FI547-PZFLO5JrP5pI
                          [2020-05-06 23:01:20.668] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_br-EpEIN8WzStxPcQt1c5h6NnpH8XE21YEApGp
                          [2020-05-06 23:03:20.669] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_a08aZNB_XhCglG7WXcQ092a8eFzMzNUNaRZvqO
                          [2020-05-06 23:05:20.658] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_aVURlKJiJR0fTzJWpcGTMlXvfiGk5nJ6etiSHi
                          [2020-05-06 23:07:20.659] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_akPXXjHYRbPdSNItqwOLtXOcOSrc-HhJXyM3xb
                          [2020-05-06 23:09:20.668] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_Z05i2rhrYihDYrlFNXa5Whwx6GhoHWfNqH1bKg
                          [2020-05-06 23:11:20.670] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bIkwJb-V0P5Gwy5K3bQ8EANAZKmKzOA0I_LxPs
                          cowboysdudeC K ? 3 Replies Last reply Reply Quote 0
                          • cowboysdudeC
                            cowboysdude Module Developer @kykzzang
                            @kykzzang said in MMM-GooglePhotos:
                            That’s because if you copy one of those links…those images do not exist.
                            • K
                              kykzzang @kykzzang
                              sometimes, image loading is successful.
                              but after index failing, it does not run again.
                              [2020-05-07 09:53:21.010] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ak9_lafawfAhSbhANtZXBdVH
                              [2020-05-07 09:55:21.137] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ahNqW5H91XaNth2sJoX9QE7s
                              [2020-05-07 09:57:21.130] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ZaAjKoODb_OPlUzISo9jy1u4
                              [2020-05-07 09:59:21.153] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bvB6ykWhOyPUcRLEAns7oT3K
                              [2020-05-07 10:01:21.139] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_Zs_BgUJgTgurcCBrDgV8SMQP
                              [2020-05-07 10:03:21.237] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_YmrDraY6gfuXVS7lDA6-op7K
                              [2020-05-07 10:05:21.153] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_YiUySpsiSfYCRte96P2xYIzZ
                              [2020-05-07 10:07:20.918] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_aC6voVTY4cjTOGEGner4cuOGtUC41vpPTElactvgQiPCRufJIt-C
                              [2020-05-07 10:09:21.142] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_ZWO0WENWR6IqtlvCWqWAZVSF
                              [2020-05-07 10:11:21.023] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_Zk6JM9zPQ72ll8EYULsuoCBM
                              [2020-05-07 10:13:21.154] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_b_oSZict47mORzvT6uwd6tCm
                              [2020-05-07 10:15:21.147] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bIkwJb-V0P5Gwy5K3bQ8EANA
                              [2020-05-07 10:17:21.158] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_avm5xrDSN-xwthqb5zg9MxC8
                              [2020-05-07 10:19:21.160] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_YC1P-nHfYfVb5AEm6qJfpuvp
                              [2020-05-07 10:21:21.159] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_buVXMwyR52HwdEOb_Vtz22OL
                              [2020-05-07 10:23:21.154] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_aJ7QVByAhmj-5G29sTowiQH6
                              [2020-05-07 10:25:21.157] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_Z3Ucrm8Tf08CoidOImN531tQ
                              [2020-05-07 10:27:21.206] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_b_CM8oP6af_yfbt_z1avXwYt
                              [2020-05-07 10:29:20.983] [LOG]    [GPHOTOS] Image loaded: https://lh3.googleusercontent.com/lr/AFBm1_YXQKGn4L3DOuTxaqK_khpcrSZDvJggiDLMoQEn8YHfkDm4ZmY4Hi
                              [2020-05-07 10:31:21.147] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_bipyHtNScWr3gl4cQVoewCyI
                              [2020-05-07 10:33:21.158] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_azVty06EiBsdLlD5CggnEQcb
                              [2020-05-07 10:35:21.023] [LOG]    [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_a1uFaqkL2Oloi6jGCObhQKcp
                              • G
                                gonzonia @cowboysdude
                                @cowboysdude The URLs only last for an hour. That’s why it re-indexes and updates after 50 min. The issue @kykzzang and I are having is that sometimes during indexing there’s a network issue and the indexing doesn’t complete. When that happens the URLs don’t get updated and the module tries using the old URLs resulting in the the failed image loading.
                                • cowboysdudeC
                                  He added logging and in there it should tell you why it’s failing…
                                  • G
                                    @cowboysdude said in MMM-GooglePhotos:
                                    Yes. This is the error and I appreciate all @Sean has done. However, whatever is causing the error below isn’t something I can identify/control/fix. There are no network issues anywhere else on my network except this single module. At least once a day I need to manually intervene to get it started again.
                                    • cowboysdudeC
                                      cowboysdude Module Developer @gonzonia
                                      @gonzonia said in MMM-GooglePhotos:
                                      It’s disconnecting before the proper connection can be made… so it sounds like a Google issue.
                                      • G
                                        greenmansuperhero
                                        I’m a newbie on Magic Mirror, so please, be indulgent :)
                                        I’ve setup magic mirror as a server only on my NUC (via Docker) and I’ve installed npm module MMM-GooglePhotos on it.
                                        I can access MM, and see all basic modules, browsing to the server and port configured in docker. So no problems there.
                                        I’m blocked though, on the installation (authorization part) of MMM-GooglePhotos module.
                                        I’ve created all credentials on google, however, being a server only installation of magic mirror, I cannot complete the OAUTH token generation as advised in the docs, as via console there is no way to open a “browser” and access google consent screen.
                                        Is there any other way, maybe using a generic google API in the config, to authorize without going through consent screen?
                                        Maybe doing the consent somewhere else (accessing an URL?) and then copy (and/or craft) the token somehow?
                                        Thank you for your time and help!
                                        P.S.
                                        Apologies if this is not the best place to post this message, so please advise if that’s the case.
                                          A Former User @kykzzang
                                          As I’ve said in another post, I couldn’t maintain this module anymore.
                                          However, yesterday night, suddenly I got an idea of what happened. (Not tested, and… sorry, I couldn’t test)
                                          Most of MM modules and MM itself are using the same port to communicate internally and externally. I suspect some modules(and even inside logics in a module) were racing to use the port. They had opened and closed the port by their own schedule, which could make this symptom. Connection with Google Server often needs some long time probably.
                                          The solution might be to use a different port not to race. and make the connections not to happen asynchronously. For the performance, I usually used asynchronous attempting to communicate with Google Server, It might make worse that issue.
                                          Well, some modification of source might be needed, but as I’ve said (again), I couldn’t.
                                          Anyway, this guess is not confirmed by the test, just an idea.
                                          If someone could get an inspiration, I hope this guess could be a help.
                                          cowboysdudeC G 2 Replies Last reply Reply Quote 0
                                          • cowboysdudeC
                                            cowboysdude Module Developer @Guest
                                            @Sean makes perfect sense!! I guessed that was Google … I could only offer that much help as I don’t have time to really look at it either.
                                            Thank you for the response and someone with more time could take a peek at it.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
