    MMM-ping
    voice controlmodalpingonlineofflinehostsnetwork
    7 Posts 4 Posters 5.0k Views 4 Watching
      shashank @strawberry 3.141
      @strawberry-3.141 I got this module installed working fine, I have a request here, I have many devices connected with DHCP in my local network at home, is it possible to get the IP using MAC address of the device. only IP with friendly name has to be displayed on the Mirror. At present i have 5 Rasp pi connected each in a room using as a MultiRoom audio system.
      • I Offline
        ianperrin @shashank
        @shashank said in MMM-ping:
        @shashank I had a similar requirement so I temporarily created another module which scans the network for devices based on their mac address, and then displays their status. I use it to display an indicator of who is home based on the visibility of their smart phone devices…
        I was planned to see if I could merge this into MMM-Ping and create a pull request. Sadly this is bottom of the pile right now. I could publish it as a separate repository if that helps
        "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
          shashank @ianperrin
          @ianperrin Thanks for the update,eager to see the module.
          • strawberry 3.141S Offline
            [2.0.0]
            Added
            • Nunjuck templates
            • Contributing guidelines
            • Issue template
            • Pull request template
            • Integration of MMM-voice and MMM-Modal
            Changed
            • Config files
            • async/await on the node side of the module.
            • eslint recommended instead of airbnb ruleset.
            alt text alt text
              [2.0.1]
              Added
              • Config option transitionTime https://github.com/fewieden/MMM-ping/issues/4
              [card:fewieden/MMM-ping]
              • W Offline
                wirthmaster
                Could someone give an example how to activate / deactivate the monitor (hdmi) with dependency to the ping order?
                Like: if pinged device = onlinte then set hdmi := online if not hdmi := offline
                Thanks a lot
