Changing compliments?
17 Posts 10 Posters 20.6k Views 9 Watching
    A Former User
    I am totally new to the programming world and was wondering if I could get some instruction on how to change the compliments module to reflect personalized statements. Do I have to change the .css file? How is this done? Also do/can I change the config.js.sample file to reflect these changes for future installations?
    B 1 Reply Last reply Nov 4, 2016, 7:29 PM Reply Quote 0
      bhepler Module Developer @Guest
      @artworks79 Sure, no problem.
      For starters, you probably copied the config.js.sample file to config.js to get you started. That’s great, as the config.js file is what the Magic Mirror software reads in order to arrange and configure the various modules. For future installations, I recommend making a local copy of the config.js file and then dropping that in your new mirrors.
      In the config.js file, you’ll see an entry for the compliments module that tells the system which module to load (compliments), where to place it and what configuration values to pass into the module (config: {...}). This part of the config.js file modifies how the Magic Mirror software treats the compliments module.
      Inside that config section, you can modify the behavior of the module itself. You can change the update interval or change the compliments themselves. Here’s the one pulled from my config.js.
              module: 'compliments',
              position: 'bottom_center',
                      updateInterval: 30000,
                      compliments: {
                              morning: [
                              "Good morning, sunshine!"
                              afternoon: [
                              "It's a pretty day outside. Go play in it!"
                              evening: [
                                      "Wasn't the sunset beautiful?",
                                      "Wasn't the day just spectacular?"
      Inside the config: {...} section there is a variable called compliments. The value of this variable must be an array, as specified by the morning: [...] structure. Please note that arrays require square brackets. Each compliment must be enclosed in double quotes " and each compliment is separated by a comma. You can have as many compliments as you like in each array. In the compliments:{...} variable you are allowed a morning array, an afternoon array and an evening array. No other array names will have any effect.
      ? V 2 Replies Last reply Nov 5, 2016, 11:19 PM Reply Quote 1
        A Former User @bhepler
        @bhepler Thanks for the assistance. When I get a chance I will definitely give it a try.
        1 Reply Last reply Reply Quote -1
        • V Offline
          VirtualLeonard @bhepler
          @bhepler I have hade a lot of trouble getting compliments to work correctly on my mirror. I then simply copy and pasted your code into my config.js file and I am still having the same issue. When I run Magic Mirror (even when using your exact code) the module only shows “compliments” in a larger font then “module_2_compliments” underneath. I am not sure what I am doing wrong, is this an easy fix?
          M B 2 Replies Last reply Dec 22, 2016, 8:22 AM Reply Quote 0
            MichMich @VirtualLeonard
            @VirtualLeonard You probably modified the compliments module. Which is something you shouldn’t do. I suggest you backup you config and reinstall the mirror.
            All customisations should be done using the config.js, you should never need to modify a default module.
              bhepler Module Developer @VirtualLeonard
              @VirtualLeonard Hmm. Give @MichMich 's suggestion a try. Don’t forget that after you reinstall the mirror software you drop your config.js file back into its proper place.
              If that still doesn’t work, either post your config.js file here and let us take a look at it or upload it somewhere such as dropbox so we can try to drop it into our mirrors.
                AAPS
                What exactly should the config.js file look like when I try to change the compliments?
                B 1 Reply Last reply Jan 2, 2017, 8:05 PM Reply Quote 0
                  bhepler Module Developer @AAPS
                  @AAPS See my post in this thread from November 4th. If you compare the code I included to the default entry for the compliments module, it should get you started. The default code is only this:
                  Basically, everything I included in the config section on Nov 4th is new code that will modify how the module behaves.
                    matic55maci
                    hello,
                    this helped me a lot. I only have one problem left and that’s when I tried to put more than 3 compliments for each part of a day, the mirror didn’t want to show any of compliments. Is there a ways to change the amount of compliments for each part or is it limited to only 3?
                    Thank you
                    M 1 Reply Last reply May 26, 2018, 2:19 AM Reply Quote 0
                      Mykle1 Project Sponsor Module Developer @matic55maci
                      @matic55maci
                      I think it’s likely that there is an error in the way you added the compliments (formatting?). Post your config for compliments in a code block
