    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
      Cetax @Jalibu
      I think I’m too stupid to get an API key. Are there any instructions in German or can someone help me?
      Thanks a lot
      greeting
      Stefan
      C 1 Reply Last reply
        Cetax @Cetax
        Ok, i think i have a Key… But i see errors…
        Have i a wrong Key ?
        Is this Key, the right ? “-> Maps JavaScript API”
        And i see error on the google Page…
        I don´t understand it… Why the Limit is 1 ?
        • JalibuJ
          Jalibu Module Developer
          Just wait for the OpenStreetMap support.
          Here is a beta branch: https://github.com/jalibu/MMM-RAIN-MAP/tree/feature/OSM
          Reply Quote 2
          • JalibuJ
            OpenStreetMap support is pushed to master. Please give me feedback, as I did not have the time for
            extensively testing.
            On my Raspberry Pi I currently have problems with the script when it runs over a longer period of time. I think it causes memory problems and the systems hangs. Does anybody have similar problems?
            @Fozi @rxlDavid
            FoziF 1 Reply Last reply
            • FoziF
              Fozi Project Sponsor @Jalibu
              @Jalibu Yes, I can confirm the memory problems. The module consumes rather quickly a lot of memory and after about 3 hrs the RPi freezes.
              JalibuJ lavolp3L swvalentiS 3 Replies Last reply
              • JalibuJ
                Jalibu Module Developer @Fozi
                @Fozi thanks. I think I found the problem and will solve it by the end of the day.
                • JalibuJ
                  The memory problem should hopefully be fixed.
                  FoziF 2 Replies Last reply
                  • FoziF
                    @Jalibu ok…I just pulled the latest version and just restarted my MM. I’ ll report back if the memory issue improved.
                    • FoziF
                      @Jalibu There still seems to be a memory issue. I took about one hour until the memory was full and the Pi froze.
                      I deactivated the module now and restarted the Pi to be sure that no other module causes that problem.
                      • JalibuJ
                        Does anyone else have the problem? I can’t reproduce it anymore.
                          chassain 0
                          Nice and working module for me (conf openstreetmap)…Be carefull with timeformat, need no " "
                          • lavolp3L
                            lavolp3 Module Developer @Fozi
                            @Fozi @chassain-0 Ah that may be what is crashing my pi recently every day. I’ll try disabling the module…
                            How to troubleshoot modules
                            MMM-soccer v2, MMM-AVStock
                            C FoziF 2 Replies Last reply
                              chassain 0 @lavolp3
                              @lavolp3 i don’t think but you can check…the format was only in 12h
                              • JalibuJ
                                I fixed the timeFormat error. Thank you for your feedback @chassain-0
                                C StoffbeuteluweS 2 Replies Last reply
                                  chassain 0 @Jalibu
                                  @Jalibu thank to you. It’s a nice module even if the rain is null in south of france lol
                                  • FoziF
                                    Fozi Project Sponsor @lavolp3
                                    @lavolp3 just a question as I have the same issue and @Jalibu and I tried his latest release, but no success on my side.
                                    Which modules do you have activated?
                                    I assume that the module might interfere with another module, but I am not sure which one. I’d like to compare your activated modules with mine and maybe I can find out which one is identical and might cause the conflict. Here’s a list of my modules, which are separated over two pages:
                                    Page1:
                                    newsfeed,
                                    alert,
                                    updatenotification,
                                    MMM-PIR-Sensor,
                                    MMM-AlexaControl,
                                    MMM-MyCalendar,
                                    MMM-page-indicator,
                                    MMM-Pages,
                                    MMM-withings,
                                    MMM-Sonos,
                                    MMM-DarkSkyForecast,
                                    MMM-DWD-WarnWeather,
                                    MMM-MyScoreBoard,
                                    MMM-Podcast2,
                                    2x MMM-PublicTransportHafas,
                                    MMM-google-route,
                                    MMM-RemoteControl,
                                    MMM-GroveGestures,
                                    Page2:
                                    netatmo,
                                    MMM-Tools,
                                    mmm-hue-lights,
                                    MMM-Homematic, .
                                      chassain 0 @Fozi
                                      @Fozi the best way is to add disabled: true at each module one by one and restart mm beetwen
                                      • StoffbeuteluweS
                                        Stoffbeuteluwe Project Sponsor @Jalibu
                                        @Jalibu Hello, the module is very good but it only shows the time that has already passed and not the time that is yet to come…
                                        can I change that is showing the next 2 hours
                                        JalibuJ 1 Reply Last reply
                                        • JalibuJ
                                          Jalibu Module Developer @Stoffbeuteluwe
                                          @Stoffbeuteluwe nope, the data provider only serves weather history
                                          D 1 Reply Last reply
                                          • rubenixR
                                            rubenix
                                            @Fozi We’ve a MM setup with 10 pages on it (its more a Family panel than a mirror; so useful for us to keep activities, list and routines and important info for a daily basis)
                                            Anyway the modules that matches yours:
                                            default modules:
                                            newsfeed,
                                            alert,
                                            updatenotification --> config disabled: true
                                            Third Party modules:
                                            MMM-AlexaControl,
                                            MMM-Pages & MMM-page-indicator,
                                            MMM-RemoteControl,
                                            MMM-GroveGestures,
                                            MMM-Tools,
                                            Im pretty sure the rpi freezes due to RAIN-MAP animation itself and not because of any module interaction but am not 100% sure.
                                            I’ve updated the module but nothing changes and mirror freezes if I show the RAIN-MAP (got it hidden on start and call it by alexaControl whenever I wanna show it).
                                            If I disabled the module, never freezes (have it on for hours with no problems --> we usually shutdown the rpi when going to bed…If I enabled the module and make it visible on the mirror it freezes at some point (maybe minutes, maybe hours…but it freezes indeed). If I start the mirror (remember default RAIN-MAP not visible) and never show the RAIN-MAP never freezes. If I disable the module (disabled: true) in config cpu usage & temperature on the pi are fine but If I enable it goes up to 40-70% at some stages and temperature goes over 70ºC sometimes…(not good)
                                            I increase value of animationSpeed on module config must say improves rpi performance (I’ve set it @800 and its fine for a longer period and maybe if we’re lucky the pi does not freeze). Could be the zoom in/out feature on module itself…don’t know as its hard to catch a useful log to look at. No error at all on pm2 logs.
                                            Here my newbie contribution; hope we can found something as module looks nice on the Mirror!
                                            I will keep an eye on this topic and, indeed, post it here if find something that helps…
                                            Cheers!
                                            • 10
                                            • 1 / 10
