    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 763.2k Views 27 Watching
      snikolaidis
      @Mykle1 gonna do a fresh install and copy my config onto the 4b because something messed up happened to all that hardware
      It booted but right to a completely blank black dashboard
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @snikolaidis
        @snikolaidis
        ok, good luck
          snikolaidis @Mykle1
          @Mykle1 turns out I just messed up the screen location like an idiot which fixed the blank dashboard and the mic error went away as well as the BMW_CC not loading. but I still get no hdmi output on this 3b+ I wonder what the heck that could be could I have burned that out if everything else on the pi is running fine?
            snikolaidis
            @Mykle1 I FIXED IT!!! Sorry lol But it goes to 720x480
            if i change it to 1920x1080 like i had it no video output on the hdmi any more
              snikolaidis
              @Mykle1 got 1080P back by setting
              hdmi_group=1
              hdmi_mode=16
              hdmi_boost > 6
              hdmi_ignore_edid = 0xa5000080
              hdmi_edid_file = 1
              in /boot/config.txt
              but now i get green flecks everywhere
              • Mykle1M
                @snikolaidis
                Stop breaking shit. :-)
                  snikolaidis
                  :face_with_tears_of_joy: but thats what i do for a living, I build it or someone else does, then i break it and i fix it, lol
                  on another note, i guess i said too many unkown commands or somethings and a list of all the commands possible popped up and wont go away, any thoughts other than rebooting :grinning_face_with_smiling_eyes:
                  Mykle1M 2 Replies Last reply
                  • Mykle1M
                    @snikolaidis
                    In the terminal?
                    Type clear and enter
                    or
                    Close the terminal and open a new one
                      snikolaidis
                      @Mykle1 Sorry to be bothering you again, decided to switch to my pi4b to see how it performs, and now the usb camera I had working on the pi3b+ will not work now, arecord -l lists it as card 2 device 0 and it still says error. Im at a lost npm start dev shows no errors and if I take the same config over to the 3b+ with the proper mapping it works fine
                      pi@MagicMirror:~ $ arecord test.wav
                      ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM input
                      arecord: main:828: audio open error: No such file or directory
                        sdetweil @snikolaidis
                        @snikolaidis on you pi3 you have a file ~/.asoundrc
                        did u build one on pi4 ? with the right info?
                          snikolaidis
                          @sdetweil said in Hello-Lucy:
                          ~/.asoundrc
                          Pi3 file doesnt exist - mic shows error but works
                          pi4 file exists - mic shows error still doesn’t work
                            snikolaidis
                            @sdetweil also weirdly enough
                            pi@MagicMirror:~ $ arecord -D hw:2,0 test.wav
                            Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
                            arecord: set_params:1339: Sample format non available
                            Available formats:
                            - S16_LE
                            but
                            pi@MagicMirror:~ $
                              @snikolaidis before we get to MM with lucy, arecord must work
                              Available formats:
                              - S16_LE
                              yes, it didn’t record cause it can’t do the default
                              arecord --format=S16-LE test.wav
                                snikolaidis
                                pi@MagicMirror:~ $ arecord --format=S16_LE test.wav
                                pi@MagicMirror:~ $ arecord -D hw:2,0 --format="S16_LE" test.wav
                                Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
                                ^CAborted by signal Interrupt...
                                pi@MagicMirror:~ $ ls
                                Bookshelf  Desktop  Documents  Downloads  MagicMirror  Pictures  pocketsphinx  Public  sphinxbase  Templates  test.wav  Videos
                                pi@MagicMirror:~ $
                                if i specify the USB camera it works, if i leave it to defaults audio open error
                                  @snikolaidis and aplay test.wav do you hear what you said?
                                    @sdetweil >if i specify the USB camera it works,
                                    ok, so, how do you update lucy to use the usb camera config ?
                                      snikolaidis
                                      yes on both i hear what i said and changing the microphone line in config is all i’ve ever done to get it working, flash raspbian -> install MM and modules -> run arecord -l and change the mic config line to what my pi reflects
                                      Pi4b
                                      disabled: false,
                                      module: "Hello-Lucy",
                                      position: "bottom_bar",
                                          keyword: 'JARVIS',              // keyword to activate listening for a command/sentence
                                          timeout: 5,                        // timeout listening for a command/sentence
                                          standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                                          microphone: "2,0",                  // run "arecord -l" card # and device # mine is "0,0"
                                          sounds: ["intro.mp3"],        // welcome sound at startup. Add several for a random greetings
                                          confirmationSound: "ding.mp3",      // name and extension of sound file
                                          startHideAll: false,                 // All modules start as hidden EXCEPT PAGE ONE
                                          // *** Page One is your default startup page *** This overrides startHideAll: true,
                                          pageOneModules: ["Hello-Lucy","MMM-AfterShip"],                     // default modules to show on page one/startup
                                          pageTwoModules: ["Hello-Lucy", "MMM-BMW-OW"], // modules to show on page two
                                          pageThreeModules: ["Hello-Lucy", "MMM-Systemstats"],                 // modules to show on page three
                                      Pi3b+
                                      disabled: false,
                                          sounds: ["yourang.mp3"],        // welcome sound at startup. Add several for a random greetings
                                        snikolaidis
                                        @sdetweil i specified the mic in ~.asoundrc so now arecord goes directly to the usb mic but still throws the format code, lucy still wont pick it up tho
                                        pcm.!default {
                                          type asym
                                          playback.pcm {
                                            type plug
                                            slave.pcm "output"
                                          capture.pcm "hw:2,0"
                                        pcm.output {
                                          type hw
                                          card 1
                                        ctl.!default {
                                          type hw
                                          card 1
                                          mine is
                                          pcm.!default {
                                              type hw
                                              card 0
                                          ctl.!default {
                                              type hw
                                              card 1
                                          so I would guess yours would be
                                          pcm.!default {
                                              type hw
                                              card 2
                                          ctl.!default {
                                              type hw
                                              card 1
                                            snikolaidis
                                            @sdetweil yeah still not working with lucy even though arecord works, would it have anything to do with that i went beta with the pi4?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
