    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 765.0k Views 27 Watching
      snikolaidis @snikolaidis
      @Mykle1 Yup sorry to bother you, but I defintely fried it, i put the sd card in my pi4b and got video, my other problems must be from that
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @snikolaidis
        @snikolaidis
        So everything is ok now?
          snikolaidis
          @Mykle1 gonna do a fresh install and copy my config onto the 4b because something messed up happened to all that hardware
          It booted but right to a completely blank black dashboard
          • Mykle1M
            @snikolaidis
            ok, good luck
              snikolaidis @Mykle1
              @Mykle1 turns out I just messed up the screen location like an idiot which fixed the blank dashboard and the mic error went away as well as the BMW_CC not loading. but I still get no hdmi output on this 3b+ I wonder what the heck that could be could I have burned that out if everything else on the pi is running fine?
                snikolaidis
                @Mykle1 I FIXED IT!!! Sorry lol But it goes to 720x480
                if i change it to 1920x1080 like i had it no video output on the hdmi any more
                  snikolaidis
                  @Mykle1 got 1080P back by setting
                  hdmi_group=1
                  hdmi_mode=16
                  hdmi_boost > 6
                  hdmi_ignore_edid = 0xa5000080
                  hdmi_edid_file = 1
                  in /boot/config.txt
                  but now i get green flecks everywhere
                  • Mykle1M
                    @snikolaidis
                    Stop breaking shit. :-)
                      snikolaidis
                      :face_with_tears_of_joy: but thats what i do for a living, I build it or someone else does, then i break it and i fix it, lol
                      on another note, i guess i said too many unkown commands or somethings and a list of all the commands possible popped up and wont go away, any thoughts other than rebooting :grinning_face_with_smiling_eyes:
                      Mykle1M 2 Replies Last reply
                      • Mykle1M
                        @snikolaidis
                        In the terminal?
                        Type clear and enter
                        or
                        Close the terminal and open a new one
                          snikolaidis
                          @Mykle1 Sorry to be bothering you again, decided to switch to my pi4b to see how it performs, and now the usb camera I had working on the pi3b+ will not work now, arecord -l lists it as card 2 device 0 and it still says error. Im at a lost npm start dev shows no errors and if I take the same config over to the 3b+ with the proper mapping it works fine
                          pi@MagicMirror:~ $ arecord test.wav
                          ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM input
                          arecord: main:828: audio open error: No such file or directory
                            sdetweil @snikolaidis
                            @snikolaidis on you pi3 you have a file ~/.asoundrc
                            did u build one on pi4 ? with the right info?
                              snikolaidis
                              @sdetweil said in Hello-Lucy:
                              ~/.asoundrc
                              Pi3 file doesnt exist - mic shows error but works
                              pi4 file exists - mic shows error still doesn’t work
                                snikolaidis
                                @sdetweil also weirdly enough
                                pi@MagicMirror:~ $ arecord -D hw:2,0 test.wav
                                Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
                                arecord: set_params:1339: Sample format non available
                                Available formats:
                                - S16_LE
                                but
                                pi@MagicMirror:~ $
                                  @snikolaidis before we get to MM with lucy, arecord must work
                                  Available formats:
                                  - S16_LE
                                  yes, it didn’t record cause it can’t do the default
                                  arecord --format=S16-LE test.wav
                                    snikolaidis
                                    pi@MagicMirror:~ $ arecord --format=S16_LE test.wav
                                    pi@MagicMirror:~ $ arecord -D hw:2,0 --format="S16_LE" test.wav
                                    Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
                                    ^CAborted by signal Interrupt...
                                    pi@MagicMirror:~ $ ls
                                    Bookshelf  Desktop  Documents  Downloads  MagicMirror  Pictures  pocketsphinx  Public  sphinxbase  Templates  test.wav  Videos
                                    pi@MagicMirror:~ $
                                    if i specify the USB camera it works, if i leave it to defaults audio open error
                                      @snikolaidis and aplay test.wav do you hear what you said?
                                        @sdetweil >if i specify the USB camera it works,
                                        ok, so, how do you update lucy to use the usb camera config ?
                                          snikolaidis
                                          yes on both i hear what i said and changing the microphone line in config is all i’ve ever done to get it working, flash raspbian -> install MM and modules -> run arecord -l and change the mic config line to what my pi reflects
                                          Pi4b
                                          disabled: false,
                                          module: "Hello-Lucy",
                                          position: "bottom_bar",
                                              keyword: 'JARVIS',              // keyword to activate listening for a command/sentence
                                              timeout: 5,                        // timeout listening for a command/sentence
                                              standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                                              microphone: "2,0",                  // run "arecord -l" card # and device # mine is "0,0"
                                              sounds: ["intro.mp3"],        // welcome sound at startup. Add several for a random greetings
                                              confirmationSound: "ding.mp3",      // name and extension of sound file
                                              startHideAll: false,                 // All modules start as hidden EXCEPT PAGE ONE
                                              // *** Page One is your default startup page *** This overrides startHideAll: true,
                                              pageOneModules: ["Hello-Lucy","MMM-AfterShip"],                     // default modules to show on page one/startup
                                              pageTwoModules: ["Hello-Lucy", "MMM-BMW-OW"], // modules to show on page two
                                              pageThreeModules: ["Hello-Lucy", "MMM-Systemstats"],                 // modules to show on page three
                                          Pi3b+
                                          disabled: false,
                                              sounds: ["yourang.mp3"],        // welcome sound at startup. Add several for a random greetings
                                            snikolaidis
                                            @sdetweil i specified the mic in ~.asoundrc so now arecord goes directly to the usb mic but still throws the format code, lucy still wont pick it up tho
                                            pcm.!default {
                                              type asym
                                              playback.pcm {
                                                type plug
                                                slave.pcm "output"
                                              capture.pcm "hw:2,0"
                                            pcm.output {
                                              type hw
                                              card 1
                                            ctl.!default {
                                              type hw
                                              card 1
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
