    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 753.3k Views 27 Watching
      rrussis82 @sdetweil
      @sdetweil Tried it, too confusing.
        sdetweil @rrussis82
        @rrussis82 if u have time and are willing, I would be interested in what you found difficult and try to find ways to make it easier. we can work thru email or chat…
        thank you for your consideration
        • Mykle1M
          Minor update
          By git user @escapestudio3’s request, four modules have been added to the default modules that will work upon installation of Lucy.
          • MMM-CalendarExt2
          • MMM-AVStock
          • MMM-lichess-daily
          • MMM-Remote-Control
          Also added
          • MMM-BMW-CC (using ClimaCell)
          • MMM-BMW-DS (using Darksky)
          • MMM-BMW-OW (Using OpenWeather)
          Total default modules = 73
          • cowboysdudeC
            @Mykle1 said in Hello-Lucy:
            Hello Lucy!
            That poor kid having to be related to you LOL I hope she doesn’t need therapy later in life
            • Mykle1M
              @cowboysdude
              Haha!
                snikolaidis
                Hey @Mykle1 first off great module, but I’m having a little difficulty, A ) I have no video at all now, B ) the mic works but constantly shows error, and C ) so far MMM-BMW-CC hides and shows but stays a loading climacell data. Any advice/pointers??
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @snikolaidis
                  @snikolaidis
                  I’m confused a bit
                  1. You have no video at all? I’m not sure what that means.
                  2. I’ve never seen Lucy work when the microphone reports ‘error’.
                  3. BMW-CC sounds like a different issue.
                  Start MM using npm start dev and report any errors in red after choosing the ‘Console’ tab in the window that opens.
                  Also, paste your config entry for BMW-CC (in a code block) here so I can look at it.
                    snikolaidis
                    @Mykle1
                    1 there is no HDMI output of anything not raspbian, not the magic mirror, nothing, it used to default to the magic mirror dashboard monitor receives signal but is black
                    1. Now even though I’ve changed nothing, my magic mirror wont show any modules just loads a black page
                    3.```
                    disabled: false,
                    module: "MMM-BMW-CC",
                    position: "bottom_bar", // designed for bottom_bar(best) thirds should be good too
                        apiKey: "XXX_Santized_XXX", // Get at https://www.climacell.co/weather-api/pricing/
                        ownTitle: "Current Conditions",
                        tempUnits: "us", // us = F or si = C
                        lat: '39.321940', // Your latitude
                        lon: '-74.604440', // Your longitude
                        css: "1", // 1-6
                        playSounds: "no",
                        useHeader: false, // true if you want a header
                        header: "Your header",
                        maxWidth: "100%",
                        updateInterval: 5 * 60 * 1000,
                    no errors with npm start dev at all
                    > magicmirror@2.11.0 start /home/pi/MagicMirror
                    > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                    [2020-05-27 20:27:05.311] [LOG]    Starting MagicMirror: v2.11.0
                    [2020-05-27 20:27:05.325] [LOG]    Loading config ...
                    [2020-05-27 20:27:05.336] [LOG]    Loading module helpers ...
                    [2020-05-27 20:27:08.368] [LOG]    Initializing new module helper ...
                    [2020-05-27 20:27:08.369] [LOG]    Module helper loaded: Hello-Lucy
                    [2020-05-27 20:27:08.430] [LOG]    Initializing new module helper ...
                    [2020-05-27 20:27:08.431] [LOG]    Module helper loaded: updatenotification
                    [2020-05-27 20:27:08.433] [LOG]    No helper found for module: clock.
                    [2020-05-27 20:27:08.976] [LOG]    Initializing new module helper ...
                    [2020-05-27 20:27:08.977] [LOG]    Module helper loaded: MMM-AfterShip
                    [2020-05-27 20:27:09.095] [LOG]    Initializing new module helper ...
                    [2020-05-27 20:27:09.096] [LOG]    Module helper loaded: calendar
                    [2020-05-27 20:27:09.118] [LOG]    Initializing new module helper ...
                    [2020-05-27 20:27:09.119] [LOG]    Module helper loaded: MMM-SystemStats
                    [2020-05-27 20:27:09.121] [LOG]    No helper found for module: currentweather.
                    [2020-05-27 20:27:09.124] [LOG]    Initializing new module helper ...
                    [2020-05-27 20:27:09.125] [LOG]    Module helper loaded: MMM-BMW-CC
                    [2020-05-27 20:27:09.127] [LOG]    No helper found for module: MMM-Modulebar.
                    [2020-05-27 20:27:09.127] [LOG]    All module helpers loaded.
                    [2020-05-27 20:27:09.317] [LOG]    Starting server on port 8080 ...
                    [2020-05-27 20:27:09.327] [INFO]   You're using a full whitelist configuration to allow for all IPs
                    [2020-05-27 20:27:09.337] [LOG]    Server started ...
                    [2020-05-27 20:27:09.339] [LOG]    Connecting socket for: Hello-Lucy
                    [2020-05-27 20:27:09.340] [LOG]    Starting module helper: Hello-Lucy
                    [2020-05-27 20:27:09.342] [LOG]    Connecting socket for: updatenotification
                    [2020-05-27 20:27:09.343] [LOG]    Connecting socket for: MMM-AfterShip
                    [2020-05-27 20:27:09.344] [LOG]    Starting node_helper for: MMM-AfterShip
                    [2020-05-27 20:27:09.346] [LOG]    Connecting socket for: calendar
                    [2020-05-27 20:27:09.347] [LOG]    Starting node helper for: calendar
                    [2020-05-27 20:27:09.348] [LOG]    Connecting socket for: MMM-SystemStats
                    [2020-05-27 20:27:09.349] [LOG]    Connecting socket for: MMM-BMW-CC
                    [2020-05-27 20:27:09.351] [LOG]    Starting node_helper for: MMM-BMW-CC
                    [2020-05-27 20:27:09.351] [LOG]    Sockets connected & modules started ...
                    [2020-05-27 20:27:09.501] [LOG]    Launching application.
                    [2020-05-27 20:27:14.160] [LOG]    Create new calendar fetcher for url:
                      snikolaidis @snikolaidis
                      @Mykle1 Maybe I fried my 3b+ when I also added this RPI HiFi AMP HAT TAS5713 Amplifier Audio Module 25W Class-D?
                        @Mykle1 Yup sorry to bother you, but I defintely fried it, i put the sd card in my pi4b and got video, my other problems must be from that
                        • Mykle1M
                          @snikolaidis
                          So everything is ok now?
                            snikolaidis
                            @Mykle1 gonna do a fresh install and copy my config onto the 4b because something messed up happened to all that hardware
                            It booted but right to a completely blank black dashboard
                            • Mykle1M
                              @snikolaidis
                              ok, good luck
                                snikolaidis @Mykle1
                                @Mykle1 turns out I just messed up the screen location like an idiot which fixed the blank dashboard and the mic error went away as well as the BMW_CC not loading. but I still get no hdmi output on this 3b+ I wonder what the heck that could be could I have burned that out if everything else on the pi is running fine?
                                  snikolaidis
                                  @Mykle1 I FIXED IT!!! Sorry lol But it goes to 720x480
                                  if i change it to 1920x1080 like i had it no video output on the hdmi any more
                                    snikolaidis
                                    @Mykle1 got 1080P back by setting
                                    hdmi_group=1
                                    hdmi_mode=16
                                    hdmi_boost > 6
                                    hdmi_ignore_edid = 0xa5000080
                                    hdmi_edid_file = 1
                                    in /boot/config.txt
                                    but now i get green flecks everywhere
                                    • Mykle1M
                                      @snikolaidis
                                      Stop breaking shit. :-)
                                        snikolaidis
                                        :face_with_tears_of_joy: but thats what i do for a living, I build it or someone else does, then i break it and i fix it, lol
                                        on another note, i guess i said too many unkown commands or somethings and a list of all the commands possible popped up and wont go away, any thoughts other than rebooting :grinning_face_with_smiling_eyes:
                                        • Mykle1M
                                          @snikolaidis
                                          In the terminal?
                                          Type clear and enter
                                          or
                                          Close the terminal and open a new one
                                            snikolaidis
                                            @Mykle1 Sorry to be bothering you again, decided to switch to my pi4b to see how it performs, and now the usb camera I had working on the pi3b+ will not work now, arecord -l lists it as card 2 device 0 and it still says error. Im at a lost npm start dev shows no errors and if I take the same config over to the 3b+ with the proper mapping it works fine
                                            pi@MagicMirror:~ $ arecord test.wav
                                            ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM input
                                            arecord: main:828: audio open error: No such file or directory
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
