    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 740.4k Views 27 Watching
      Hello Lucy!
        amsuvarna27 @Mykle1
        @Mykle1
        I have installed Hello Lucy.
        My microphone and speakers are working correctly.
        And Hello Lucy logo also appears on the magic mirror screen,But when I give command like Hello Lucy it won’t respond.
        Only temperature module is showing and not working.
        I’m using Raspberry pi 3 B plus model.
          rrussis82
          How would I be able to add the ability to hide all modules if the trigger word isn’t spoken after a determined amount of time, say 2 minutes? Then I can issue the voice command to show all modules to wake it.
          I’ve tried using a pi-camera to detect motion to turn on the screen and turn off the screen, but i get the “HDMI not connected” symbol and the pi-camera is flaky where it doesn’t always work. I’ve tried multiple modules for the camera and don’t like any of them, as they can create multiple instance of the camera opening and then cause it lock up. I like how you can hide all modules to blank screen by voice command without disconnecting the HDMI output. until I can figure out a way to do this with motion, I’d like to be able to do this automatically, like a time-out.
          I’ve tried-MMM-NotificationTrigger to try to fire the HIDE_MODULE notification in your code, but I have not successfully found a decent notification trigger to make it happen. If i get a USB Webcam in the future maybe i can use motion as a trigger to fire the notification, but like I said, i haven’t had luck using motion on the pi-cam so i doubt i would on a webcam.
          Also for page navigation, I like to use MMM-Carousel by shbatm, the navigation buttons to go from one page to the other will be instrumental to when I add touch ability to my mirror, so i set up Hello-Lucy with just one page showing MMM-Carousel, is there anyway to incorporate voice activation on Hello-Lucy to work with changing the pages on MMM-Carousel? I think they are called slides on MMM-Carousel.
          S Mykle1M 2 Replies Last reply Reply Quote 0
            sdetweil @rrussis82
            @rrussis82 i have a module, MMM-SleepWake that uses module hiding to darken the screen… (all of my TV’s have the dreaded no signal problem).
            it requires some out of MM source (external) to signal motion or not…
            I use the github motion project with my webcams to get that external to MM event info
            sudo apt-get install motion
            edit the /etc/motion/motion.conf
            and set the external start/stop exits to trigger the script I provide to inform my module of the motion
            (all in the instructions of the module)
            motion project can also record video, pictures and a lot more… with all kinds of config for what motion means
            (how long from end of actual motion before signal, it is motion if the room lights are turned on and there is a sudden flash of light for the camera… etc.etc…)
            I didn’t want to write all that (and based on the audience here, config is important)…
            I have not tried motion with the pi camera…
              Mykle1 Project Sponsor Module Developer @amsuvarna27
              @amsuvarna27 said in Hello-Lucy:
              Have you followed all the instructions in the readme? There is a file just for setting up your microphone.
                Mykle1 Project Sponsor Module Developer @rrussis82
                @rrussis82 said in Hello-Lucy:
                Hello-Lucy will do pages without Carousel.
                In any event, I’ve put further development of Lucy on a shelf.
                  rrussis82 @sdetweil
                  @sdetweil Tried it, too confusing.
                    sdetweil @rrussis82
                    @rrussis82 if u have time and are willing, I would be interested in what you found difficult and try to find ways to make it easier. we can work thru email or chat…
                    thank you for your consideration
                      Minor update
                      By git user @escapestudio3’s request, four modules have been added to the default modules that will work upon installation of Lucy.
                      • MMM-CalendarExt2
                      • MMM-AVStock
                      • MMM-lichess-daily
                      • MMM-Remote-Control
                      Also added
                      • MMM-BMW-CC (using ClimaCell)
                      • MMM-BMW-DS (using Darksky)
                      • MMM-BMW-OW (Using OpenWeather)
                      Total default modules = 73
                      • cowboysdudeC Offline
                        @Mykle1 said in Hello-Lucy:
                        Hello Lucy!
                        That poor kid having to be related to you LOL I hope she doesn’t need therapy later in life
                          @cowboysdude
                          Haha!
                            snikolaidis
                            Hey @Mykle1 first off great module, but I’m having a little difficulty, A ) I have no video at all now, B ) the mic works but constantly shows error, and C ) so far MMM-BMW-CC hides and shows but stays a loading climacell data. Any advice/pointers??
                              Mykle1 Project Sponsor Module Developer @snikolaidis
                              @snikolaidis
                              I’m confused a bit
                              1. You have no video at all? I’m not sure what that means.
                              2. I’ve never seen Lucy work when the microphone reports ‘error’.
                              3. BMW-CC sounds like a different issue.
                              Start MM using npm start dev and report any errors in red after choosing the ‘Console’ tab in the window that opens.
                              Also, paste your config entry for BMW-CC (in a code block) here so I can look at it.
                                snikolaidis
                                @Mykle1
                                1 there is no HDMI output of anything not raspbian, not the magic mirror, nothing, it used to default to the magic mirror dashboard monitor receives signal but is black
                                1. Now even though I’ve changed nothing, my magic mirror wont show any modules just loads a black page
                                3.```
                                disabled: false,
                                module: "MMM-BMW-CC",
                                position: "bottom_bar", // designed for bottom_bar(best) thirds should be good too
                                    apiKey: "XXX_Santized_XXX", // Get at https://www.climacell.co/weather-api/pricing/
                                    ownTitle: "Current Conditions",
                                    tempUnits: "us", // us = F or si = C
                                    lat: '39.321940', // Your latitude
                                    lon: '-74.604440', // Your longitude
                                    css: "1", // 1-6
                                    playSounds: "no",
                                    useHeader: false, // true if you want a header
                                    header: "Your header",
                                    maxWidth: "100%",
                                    updateInterval: 5 * 60 * 1000,
                                no errors with npm start dev at all
                                > magicmirror@2.11.0 start /home/pi/MagicMirror
                                > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                                [2020-05-27 20:27:05.311] [LOG]    Starting MagicMirror: v2.11.0
                                [2020-05-27 20:27:05.325] [LOG]    Loading config ...
                                [2020-05-27 20:27:05.336] [LOG]    Loading module helpers ...
                                [2020-05-27 20:27:08.368] [LOG]    Initializing new module helper ...
                                [2020-05-27 20:27:08.369] [LOG]    Module helper loaded: Hello-Lucy
                                [2020-05-27 20:27:08.430] [LOG]    Initializing new module helper ...
                                [2020-05-27 20:27:08.431] [LOG]    Module helper loaded: updatenotification
                                [2020-05-27 20:27:08.433] [LOG]    No helper found for module: clock.
                                [2020-05-27 20:27:08.976] [LOG]    Initializing new module helper ...
                                [2020-05-27 20:27:08.977] [LOG]    Module helper loaded: MMM-AfterShip
                                [2020-05-27 20:27:09.095] [LOG]    Initializing new module helper ...
                                [2020-05-27 20:27:09.096] [LOG]    Module helper loaded: calendar
                                [2020-05-27 20:27:09.118] [LOG]    Initializing new module helper ...
                                [2020-05-27 20:27:09.119] [LOG]    Module helper loaded: MMM-SystemStats
                                [2020-05-27 20:27:09.121] [LOG]    No helper found for module: currentweather.
                                [2020-05-27 20:27:09.124] [LOG]    Initializing new module helper ...
                                [2020-05-27 20:27:09.125] [LOG]    Module helper loaded: MMM-BMW-CC
                                [2020-05-27 20:27:09.127] [LOG]    No helper found for module: MMM-Modulebar.
                                [2020-05-27 20:27:09.127] [LOG]    All module helpers loaded.
                                [2020-05-27 20:27:09.317] [LOG]    Starting server on port 8080 ...
                                [2020-05-27 20:27:09.327] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                [2020-05-27 20:27:09.337] [LOG]    Server started ...
                                [2020-05-27 20:27:09.339] [LOG]    Connecting socket for: Hello-Lucy
                                [2020-05-27 20:27:09.340] [LOG]    Starting module helper: Hello-Lucy
                                [2020-05-27 20:27:09.342] [LOG]    Connecting socket for: updatenotification
                                [2020-05-27 20:27:09.343] [LOG]    Connecting socket for: MMM-AfterShip
                                [2020-05-27 20:27:09.344] [LOG]    Starting node_helper for: MMM-AfterShip
                                [2020-05-27 20:27:09.346] [LOG]    Connecting socket for: calendar
                                [2020-05-27 20:27:09.347] [LOG]    Starting node helper for: calendar
                                [2020-05-27 20:27:09.348] [LOG]    Connecting socket for: MMM-SystemStats
                                [2020-05-27 20:27:09.349] [LOG]    Connecting socket for: MMM-BMW-CC
                                [2020-05-27 20:27:09.351] [LOG]    Starting node_helper for: MMM-BMW-CC
                                [2020-05-27 20:27:09.351] [LOG]    Sockets connected & modules started ...
                                [2020-05-27 20:27:09.501] [LOG]    Launching application.
                                [2020-05-27 20:27:14.160] [LOG]    Create new calendar fetcher for url:
                                  snikolaidis @snikolaidis
                                  @Mykle1 Maybe I fried my 3b+ when I also added this RPI HiFi AMP HAT TAS5713 Amplifier Audio Module 25W Class-D?
                                    @Mykle1 Yup sorry to bother you, but I defintely fried it, i put the sd card in my pi4b and got video, my other problems must be from that
                                      @snikolaidis
                                      So everything is ok now?
                                        snikolaidis
                                        @Mykle1 gonna do a fresh install and copy my config onto the 4b because something messed up happened to all that hardware
                                        It booted but right to a completely blank black dashboard
                                          @snikolaidis
                                          ok, good luck
                                            snikolaidis @Mykle1
                                            @Mykle1 turns out I just messed up the screen location like an idiot which fixed the blank dashboard and the mic error went away as well as the BMW_CC not loading. but I still get no hdmi output on this 3b+ I wonder what the heck that could be could I have burned that out if everything else on the pi is running fine?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
