    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 765.1k Views 27 Watching
    • Mykle1M
      Description:
      Hello-Lucy.
      Off-Line voice control.
      Hide/Show all, individual, or pages of modules, using voice commands. (With sound)
      Example:
      A screenshot won’t really do here. You should watch and listen. Makes more sense.
      https://youtu.be/bKHEXPzVb2A
      Download:
      [card:mykle1/Hello-Lucy]
      Version 1.0.0
      A 1 Reply Last reply
      Reply Quote 9
      • cruunnerrC
        cruunnerr
        I am full of admiration for your work. This is a great addition to anyone who already uses or wants to use voice commands.
        AWESOME :D
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @cruunnerr
          @cruunnerr
          Thanks, mate. I’m just having as much fun as one old man can possibly have. When I’m not watching my grandchildren, that is. :-)
          Peace!
          • Mykle1M
            Adding some things that seem relevant. I made a quick background module that will work by default with Hello-Lucy. It works as a stand alone module, as well. Anyway . . . .
            https://youtu.be/2cedXKk1Alw
            Reply Quote 2
            • cruunnerrC
              cruunnerr
              That is really lovely :)
              Another suggestion could be to say “Go to standby” and it will turn off the Monitor or something like that. Just for the need to say 1 command instead of 2 or 3 commands.
              And “Wake up” will show the last used configuration.
              But anyway a wonderful addition :D
              Mykle1M 3 Replies Last reply
              • Mykle1M
                @cruunnerr
                That’s on my to-do list. MMM-voice has “GO TO SLEEP” and “WAKE UP” commands that work on a Pi (I think) but not on this laptop running ubuntu. So, I have some homework to do. Any suggestions?
                • Mykle1M
                  @cruunnerr said in Hello-Lucy:
                  Ok, this is done. I’ve modified the original command “GO TO SLEEP” so that it will turn off the display of my laptop and “WAKE UP” to turn the display on. I don’t know if this will work with a monitor that is connected thru HDMI as the original commands do so I’m not updating Hello-Lucy until I can have that tested. This weekend, likely.
                  Huge shout out to @Cowboysdude for directing me to the site where the code came from. Freakin Guru! :-)
                  For those that might be trying this with an external monitor connected thru HDMI, it should already work by default, without today’s changes.
                  Reply Quote 3
                  • Mykle1M
                    Just tested with a desktop machine with a monitor connected through DVI and a laptop. In both cases, displays immediately were turned off (standby) and on.
                    https://youtu.be/3ldlUPkw2nM
                      pepebc
                      Great job, beautiful and very practical.
                      Would it be possible to adapt it to alexyak / voicecontrol module? is the voice module that I use.
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @pepebc
                        @pepebc said in Hello-Lucy:
                        Probably. You’re only talking about adding send and receive notifications that trigger hide and show events. However, if i remember correctly, alexyak’s voice requires training (snowboy?) for each command. That would turn into a lot of extra work and time for you. MMM-voice requires no voice training at all and is largely the reason I chose it for the Hello-Lucy enhancement.
                        P 1 Reply Last reply
                          pepebc @Mykle1
                          @Mykle1
                          OK, just same with MMM-voice but with snowboy - voicecontrol.
                          Pocketsphinx does not have a good Spanish language model, and I would have to create my own with Julia and HTK.
                          I have already created the phrases with snowboy, with a 100% success.
                          I have a script to automate and train the words and receive the .pmdl files from snowboy server.
                          A good microphone and the right profile do miracles;)
                          • Mykle1M
                            @pepebc
                            In that case, take a look at the README of Hello-Lucy. There are instructions on how to add any module. You can adapt that to the voice module you are using and enhance any other module to work with it. Let me know how you make out. Good luck.
                            Peace!
                            • Mykle1M
                              UPDATE:
                              The biggest hurdle for Pi users with Hello-Lucy is the lag placed upon the Pi by the use of the animated face.gif. This is not an issue for people using PC boards. A simple work-around for this is not using the animated face.gif. The face is cool but voice was the reason for Hello-Lucy.
                              I’ve updated the repo with 2 static images of Lucy for Pi users. You can also use any image file you like, or none. Also, the use of a microphone that has a 3.5mm jack significantly improves response (tested). USB introduces too much lag, evident even on an i7 Quad Core (tested). The difference is staggering.
                              I’ve also provided a 25MB version of the animated face.gif in the repo. You can still acquire the original via the link in the readme if you so desire. That file is 60+MB.
                              Peace!
                              • cowboysdudeC
                                https://www.youtube.com/watch?v=1n0pM-7v0pc&feature=youtu.be
                                Reply Quote 2
                                • Mykle1M
                                  @cowboysdude
                                  Ahhhh, nicely done dude! :-)
                                  • Mykle1M
                                    I added the MM default calendar, compliments and newsfeed modules. They will now work with Hello-Lucy by simply replacing your current module.js files with the module.js files provided in the Hello-Lucy repo. This assumes you are using the most current MM and that you clone the Hello-Lucy repo and follow the simple installation instructions. That’s a total of 30 modules that will work by default with Hello-Lucy. I’ll leave the rest to you. :-)
                                    Peace!
                                    • Mykle1M
                                      @cowboysdude
                                      Special thanks to @cowboysdude for randomizing sound files to the “SHOW LUCY” command. It’s audible “compliments” for your mirror. Great freakin idea dude. Thanks much!
                                      Peace!
                                      • Mykle1M
                                        Some of the custom responses/compliments I’ve created for my own Hello-Lucy. There are some that are inappropriate for public consumption so I left those out. :-)
                                        https://www.youtube.com/watch?v=u9LzQygE8Qo
                                        Reply Quote 2
                                          pepebc
                                          I am installing some modules that I like very much.
                                          The MMM-Art module is impressive, if it worked for me, it gives me this error:
                                          API key is correctc.
                                          MMM-Art.js:84 Uncaught TypeError: Cannot read property ‘url’ of undefined ----> img.src = Art.WebImage.url;
                                          Mykle1M 2 Replies Last reply
                                          • Mykle1M
                                            Wow. I never thought anyone would be using this. I haven’t loaded it in ages but you are correct, it is not functioning. I will take a look at the cause this evening. Thank you for your interest. :-)
                                            • 14
                                            • 15
                                            • 1 / 15
