    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 765.2k Views 27 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @pepebc
      @pepebc said in Hello-Lucy:
      Would it be possible to adapt it to alexyak / voicecontrol module?
      Probably. You’re only talking about adding send and receive notifications that trigger hide and show events. However, if i remember correctly, alexyak’s voice requires training (snowboy?) for each command. That would turn into a lot of extra work and time for you. MMM-voice requires no voice training at all and is largely the reason I chose it for the Hello-Lucy enhancement.
      P 1 Reply Last reply
        pepebc @Mykle1
        @Mykle1
        OK, just same with MMM-voice but with snowboy - voicecontrol.
        Pocketsphinx does not have a good Spanish language model, and I would have to create my own with Julia and HTK.
        I have already created the phrases with snowboy, with a 100% success.
        I have a script to automate and train the words and receive the .pmdl files from snowboy server.
        A good microphone and the right profile do miracles;)
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @pepebc
          In that case, take a look at the README of Hello-Lucy. There are instructions on how to add any module. You can adapt that to the voice module you are using and enhance any other module to work with it. Let me know how you make out. Good luck.
          Peace!
          • Mykle1M
            UPDATE:
            The biggest hurdle for Pi users with Hello-Lucy is the lag placed upon the Pi by the use of the animated face.gif. This is not an issue for people using PC boards. A simple work-around for this is not using the animated face.gif. The face is cool but voice was the reason for Hello-Lucy.
            I’ve updated the repo with 2 static images of Lucy for Pi users. You can also use any image file you like, or none. Also, the use of a microphone that has a 3.5mm jack significantly improves response (tested). USB introduces too much lag, evident even on an i7 Quad Core (tested). The difference is staggering.
            I’ve also provided a 25MB version of the animated face.gif in the repo. You can still acquire the original via the link in the readme if you so desire. That file is 60+MB.
            Peace!
            • cowboysdudeC
              https://www.youtube.com/watch?v=1n0pM-7v0pc&feature=youtu.be
              Mykle1M 3 Replies Last reply
              Reply Quote 2
              • Mykle1M
                @cowboysdude
                Ahhhh, nicely done dude! :-)
                • Mykle1M
                  I added the MM default calendar, compliments and newsfeed modules. They will now work with Hello-Lucy by simply replacing your current module.js files with the module.js files provided in the Hello-Lucy repo. This assumes you are using the most current MM and that you clone the Hello-Lucy repo and follow the simple installation instructions. That’s a total of 30 modules that will work by default with Hello-Lucy. I’ll leave the rest to you. :-)
                  Peace!
                  • Mykle1M
                    @cowboysdude
                    Special thanks to @cowboysdude for randomizing sound files to the “SHOW LUCY” command. It’s audible “compliments” for your mirror. Great freakin idea dude. Thanks much!
                    Peace!
                    • Mykle1M
                      Some of the custom responses/compliments I’ve created for my own Hello-Lucy. There are some that are inappropriate for public consumption so I left those out. :-)
                      https://www.youtube.com/watch?v=u9LzQygE8Qo
                      Reply Quote 2
                        pepebc
                        I am installing some modules that I like very much.
                        The MMM-Art module is impressive, if it worked for me, it gives me this error:
                        API key is correctc.
                        MMM-Art.js:84 Uncaught TypeError: Cannot read property ‘url’ of undefined ----> img.src = Art.WebImage.url;
                        Mykle1M 2 Replies Last reply
                        • Mykle1M
                          Wow. I never thought anyone would be using this. I haven’t loaded it in ages but you are correct, it is not functioning. I will take a look at the cause this evening. Thank you for your interest. :-)
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @cruunnerr
                            @cruunnerr said in Hello-Lucy:
                            Just for the need to say 1 command instead of 2 or 3 commands.
                            And “Wake up” will show the last used configuration.
                            Is this what you meant? Each page command will hide the previous page while still retaining the ability to hide and show individual modules and put the display into standby and wake it up. “Please Wake Up” will show the last used configuration as “Go To Sleep” affects the monitor, not MM. :-)
                            https://youtu.be/2-K5NlT9zgQ
                            cruunnerrC 1 Reply Last reply
                            • Mykle1M
                              Here is where we stand. The API changed how it provides the data. The return from the GET request used to give all the data (including images) I needed for the module (as it is) but they’ve moved the picture files to a web url, outside of the return. I am not ashamed to admit that I don’t know how to move forward to correct this. I’m also humble enough to ask for help. So, if anyone reading this cared to take a look at this and guide me, I would be forever grateful, and so would @pepebc . :-)
                              Peace
                              • cruunnerrC
                                cruunnerr @Mykle1
                                @Mykle1 said in Hello-Lucy:
                                Jap :)
                                This is going to be the alexa for every mirror :D
                                • Mykle1M
                                  There was a problem with the HELP screen. The Commands List would display right off the bottom of the screen. I struggled with a fix for 4 days (because I am old and stupid) but then our friend on the forum, @cowboysdude, took a look at it and fixed it in 5 minutes. I am extremely grateful (and I feel even more stupid) but he did an amazing job. :-)
                                  • Mykle1M
                                    I’m a huge fan of MMM-SystemStats for MM running on the Pi but I’m working almost exclusively on pc/mac boards running ubuntu, now. So, I started a new module for that purpose. So far, it will identify the CPU, the CPU speed, the Total RAM, Free RAM, and each core present with each cores load by percentage. It’s a work in progress but it is functional and available to anyone that cares to try it.
                                    • A
                                      AxLed Module Developer
                                      Hi Miykle1,
                                      do you know, if i can change the language of MMM-voice with Pocketsphinx / Sphinxbase to german?
                                      I found a webseite where i can create .dic and .lm files and they work somehow (i also changed the new words in different .js files of folder MMM-voice).
                                      I am looking forward hearing from you.
                                      Regards
                                      AxLED
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @AxLed
                                        @AxLed said in Hello-Lucy:
                                        Perhaps, but you would have to ask the author of MMM-voice about that.
                                          Damian
                                          @Mykle1
                                          You say that using a usb mic on the pi is not great, because of Latency, how bad is it? Is it such that it would render the user completely disgruntled using it with Lucy?
                                          And you say using a 3.5 jack microphone is better, albeit on a PC, etc… so I take it that this is really the best all round solution, owing to the limitations of the Pi?
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @Damian
                                            @Damian
                                            What I do remember about using voice with a usb microphone on the Pi is not the latency. It was more the limitation of voice module only allowing me to do certain things. I wanted to be able to completely control my mirror by voice. It took me a year to self-learn enough about coding to attempt Hello-Lucy.
                                            I don’t think the latency bothered me on the Pi but it really bothered me as I was developing Hello-Lucy on a Core i7 Quad core with a USB microphone. I couldn’t understand why a 12 year old laptop with an integrated microphone performed better, until I made the realization. A $6, 3.5mm microphone made all the difference in the world. Unfortunately for Pi users. a USB microphone is your only option.
                                            I feel compelled to say that I love the Pi. It is the reason I’ve become so involved with MM and programming, but I am realistic in my expectations of what it can do.
                                            D 1 Reply Last reply
                                            • 14
                                            • 15
                                            • 1 / 15
