    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 765.1k Views 27 Watching
      snikolaidis
      @sdetweil said in Hello-Lucy:
      ~/.asoundrc
      Pi3 file doesnt exist - mic shows error but works
      pi4 file exists - mic shows error still doesn’t work
        snikolaidis
        @sdetweil also weirdly enough
        pi@MagicMirror:~ $ arecord -D hw:2,0 test.wav
        Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
        arecord: set_params:1339: Sample format non available
        Available formats:
        - S16_LE
        but
        pi@MagicMirror:~ $ arecord  test.wav
        arecord: main:828: audio open error: No such file or directory
        pi@MagicMirror:~ $
          sdetweil @snikolaidis
          @snikolaidis before we get to MM with lucy, arecord must work
          Available formats:
          - S16_LE
          yes, it didn’t record cause it can’t do the default
          arecord --format=S16-LE test.wav
            snikolaidis
            pi@MagicMirror:~ $ arecord --format=S16_LE test.wav
            pi@MagicMirror:~ $ arecord -D hw:2,0 --format="S16_LE" test.wav
            Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
            ^CAborted by signal Interrupt...
            pi@MagicMirror:~ $ ls
            Bookshelf  Desktop  Documents  Downloads  MagicMirror  Pictures  pocketsphinx  Public  sphinxbase  Templates  test.wav  Videos
            pi@MagicMirror:~ $
            if i specify the USB camera it works, if i leave it to defaults audio open error
              @snikolaidis and aplay test.wav do you hear what you said?
                @sdetweil >if i specify the USB camera it works,
                ok, so, how do you update lucy to use the usb camera config ?
                  snikolaidis
                  yes on both i hear what i said and changing the microphone line in config is all i’ve ever done to get it working, flash raspbian -> install MM and modules -> run arecord -l and change the mic config line to what my pi reflects
                  Pi4b
                  disabled: false,
                  module: "Hello-Lucy",
                  position: "bottom_bar",
                      keyword: 'JARVIS',              // keyword to activate listening for a command/sentence
                      timeout: 5,                        // timeout listening for a command/sentence
                      standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                      microphone: "2,0",                  // run "arecord -l" card # and device # mine is "0,0"
                      sounds: ["intro.mp3"],        // welcome sound at startup. Add several for a random greetings
                      confirmationSound: "ding.mp3",      // name and extension of sound file
                      startHideAll: false,                 // All modules start as hidden EXCEPT PAGE ONE
                      // *** Page One is your default startup page *** This overrides startHideAll: true,
                      pageOneModules: ["Hello-Lucy","MMM-AfterShip"],                     // default modules to show on page one/startup
                      pageTwoModules: ["Hello-Lucy", "MMM-BMW-OW"], // modules to show on page two
                      pageThreeModules: ["Hello-Lucy", "MMM-Systemstats"],                 // modules to show on page three
                  Pi3b+
                  disabled: false,
                      sounds: ["yourang.mp3"],        // welcome sound at startup. Add several for a random greetings
                    snikolaidis
                    @sdetweil i specified the mic in ~.asoundrc so now arecord goes directly to the usb mic but still throws the format code, lucy still wont pick it up tho
                    pcm.!default {
                      type asym
                      playback.pcm {
                        type plug
                        slave.pcm "output"
                      capture.pcm "hw:2,0"
                    pcm.output {
                      type hw
                      card 1
                    ctl.!default {
                      type hw
                      card 1
                    M 1 Reply Last reply
                      mine is
                      pcm.!default {
                          type hw
                          card 0
                      ctl.!default {
                          type hw
                          card 1
                      so I would guess yours would be
                      pcm.!default {
                          type hw
                          card 2
                      ctl.!default {
                          type hw
                          card 1
                        snikolaidis
                        @sdetweil yeah still not working with lucy even though arecord works, would it have anything to do with that i went beta with the pi4?
                          @snikolaidis said in Hello-Lucy:
                          what beta? the 64bit pi os?
                            snikolaidis
                            @sdetweil the beta firmware & bootloader that lets you boot from usb
                            sudo apt update
                            sudo apt full-upgrade
                            Sudo nano /etc/default/rpi-eeprom-update
                            sudo rpi-eeprom-update -d -f /lib/firmware/raspberrypi/bootloader/beta/pieeprom-2020-05-27.bin
                              @snikolaidis oh… that won’t affect sound
                                snikolaidis @sdetweil
                                @sdetweil Sorry trying to think of anything possible
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @snikolaidis
                                  on another note, i guess i said too many unkown commands or somethings and a list of all the commands possible popped up and wont go away, any thoughts other than rebooting
                                  Oh, did you mean commands to Lucy? The Command List appeared? You can say “Hide Help” or “Close Help”.
                                  • Mykle1M
                                    Thank you @sdetweil for doing the troubleshooting on this one. :thumbsup:
                                      majik655 @snikolaidis
                                      @snikolaidis Did you ever figure this out? I have a pi4 and have a logitech webcam c920 … it shows as card 2 and should be 2,0 … I can record and play back in arecord Everything from what I can see works fine except when in MM Lucy talks and then when waiting for command her icon goes to ERROR.
                                      I have gotten this to work with a sunfounder usb mic (just a crappy mic) and I was hoping the lag would be better using the webcam mic. (waiting for my new 3.5 jack microphone which should help the lag).
                                      In any case I just do not know why Lucy doesn’t pick up the webcam mic??
                                      @Mykle1 does it make sense it doesn’t work?
                                        majik655 @majik655
                                        @majik655 said in Hello-Lucy:
                                        Well I THOUGHT I had the crappy usb microphone working on my RPI 4 but I am wrong …Same issue as with webcam.
                                        I do know I had this working on my RPI3 last night with crappy usb microphone… The only difference I can see is on the RPI3 it put the usb mic on CARD 1 . on the rpi4 no matter what I put in as a usb mic…it puts it as CARD 2 device 0. On the RPI4 I have “headphones” as card1 and HDMI as 0. I get sound out of both hdmi and 3.5 jack (headphones)…Arecord does record using either usb mic I use. For whatever reason Lucy just keeps throwing ERROR when trying to initialize the mic
                                          majik655 @majik655
                                          @majik655 @Mykle1 @snikolaidis
                                          Well I am unsure exactly why everything all of a sudden works now but I did the following and it seemed to work.
                                          sudo apt update
                                          sudo reboot
                                          Before I was always doing apt-get and never did FULL-upgrade always did apt-get upgrade
                                          When I did the apt full-upgrade it then told me at the end that I had 200 or so items that were not being used and could remove them using autoremove…
                                          I then rebooted and did not change a thing in my .asoundrc or anything and it all started working.
                                          Again I am unsure what exactly fixed it… oh I also removed the usb mouse and usb keyboard (again not sure if any of this matters) but if anyone wants to see my .asoundrc config I will post it.
                                          Currently working with Logitech c920 webcam for mic and 3.5 jack for sound out (I want to change this to HDMI but I am afraid something will break.)
                                          Mykle1M 1 Reply Last reply
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @majik655
                                            @majik655
                                            Well, perhaps something was corrected in the update. Hard to tell, really. Glad you got it working.
                                            Am I missing something here? 3.5 jack mic on a Pi?
                                            M 2 Replies Last reply
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
