    Minimal depth of a frame for the magic mirror
    12 Posts 8 Posters 6.3k Views 8 Watching
      stepan
      Hello everyone, glad to found this forum! I’m about to build my first mirror and I would like to know what is the possible minimal depth of a frame for the mirror. Can I get some ideas here please?
      (I tried to go through the samples of built mirrors, but only a minority of folks provide this particar information)
      SergeS thedoorsfanaticT 2 Replies Last reply
      • SergeS
        Serge @stepan
        @stepan minimal depth is limited by the depth of the LCD monitor behind it
          stepan @Serge
          @Serge said in Minimal depth of a frame for the magic mirror:
          Thanks @Serge :-) Would you mind to share what was the depth of the frame of your MM?
          lavolp3L 1 Reply Last reply
          • BKeyportB
            BKeyport Module Developer
            Mine is around 2" deep (5cm) - I could go thinner if I modify the monitor’s circuit board layout a bit and reduce dead space… but I’m not going to mess with that.
              bhepler Module Developer
              Some users have created fairly thin magic mirrors by using laptop screens and driver boards. The laptop screens are thinner than conventional LCD monitors.
              The downside is that you’re limited to the display size of a laptop screen.
              • uros76U
                uros76
                I am planning to go for 2cm depth with the Samsung monitor I took apart. I will need to move monitors mainboard on the side and use angled hdmi cable. Once I receive mirror glass will sum up whole setup.
                • lavolp3L
                  lavolp3 Module Developer @stepan
                  @stepan I have 6-7 cm depth with shortwired power supply for the monitor and angled hdmi cable.
                  If you want to go thinner, look for a monitor that has it’s HDMI port in the same plane/direction as the screen. There are some that have this. Mine unfortunately not.
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                  • thedoorsfanaticT
                    thedoorsfanatic @stepan
                    @stepan mine is framless
                    My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
                      retroflex Project Sponsor Module Developer
                      My brother cut a hole in the wall for the mirror and now it only builds a few millimeters. Looks really nice. See here:
                      https://www.planet4.se/magic-mirror-deluxe/
                      Text in Swedish, but you can look at the images.
                      Reply Quote 3
                        stepan
                        Thanks everyone for your answers!
                        The plan is to have MM placed on a wooden wall. The apartment was refurbished and there is electricity prepared in the wall, so there won’t be any cables hanging. The aim is to reduce the depth of the frame as much as possible so the ‘passage’ from room to room is affected minimally.
                        wall for the mirror (sorry for the link, the picture upload in this forum just does not work :()
                        Mulling over on the question, the mirror is going to be quite big - would that mean the ‘glass’ of the mirror itself would need to be more deeper?
                        @uros76 Can you please explain how difficult is “move monitors mainboard on the side and use angled hdmi cable.” for someone who has almost 0 experience with electronics?
                        @BKeyport Would you mind to share a link with description how you achieved that?
                        uros76U BKeyportB 2 Replies Last reply
                        • uros76U
                          uros76 @stepan
                          @stepan it really depends on monitor. My 24" Samsung S24D330H screen without mainboard is max depth like 17mm. The screen’s mainboard is connected with 3 cables to the screen. One is for screen data, second for screen lighting inverter, and third for touch buttons panel.
                          Luckily screen data cable is long enough so I can move the mainboard around. The inverter power cable is not long enough for maneuvering but its only few wires so I will just extend those wires to the desired location. The touch panel cable I don’t care about since I won’t be manipulating with buttons at all.
                          One more good thing about this monitor is the power supply. It uses an external brick-style power supply which gives only 14V to monitor. I guess that’s why they managed to make monitor so thin, no need for internal power supply electronics. Saying that it will make my life easier to just solder on +/- power wires directly on the mainboard.
                          Anyway, that’s my plan for my first MM. Now I am waiting for the glass mirror to be produced and delivered. Then I plan to summarize complete build.
                          • BKeyportB
                            BKeyport Module Developer @stepan
                            @stepan I got lucky, I guess. The circuit boards don’t take up so much room, and they’re in a case that’s way too big for them. If I move the boards a bit, I can get it down to the depth of the monitor itself… of course, that’s playing with stuff that’s at line voltage, and you might not not want to do that.
