MMM-WeatherOrNot
21 Posts 3 Posters 2.7k Views 3 Watching
    Jarhead96097
    Hi all - I’ve updated my MM to use the responsive layout and animated icons available in MMM-WeatherOrNot. I love it and it looks great! However, as I’m displaying three locations, it seems as though only the last location (listed in config.js) is receiving updates throughout the day. I end up having to stop MM and restart it (pm2 restart MagicMirror --update-env) to get current information for the first two locations. Any ideas to help me troubleshoot?
    Thanks in advance!
    /* Magic Mirror Config Sample
     * MIT Licensed.
    var config = {
    	port: 8080,
    	language: "en",
    	timeFormat: 24,
    	units: "imperial",
    			     // starts serveronly and then starts chrome browser
    			     // false, default for all  NON-armv6l devices
    			disabled: false,
    			module: "alert",
    			disabled: false,
    			module: "updatenotification",
    			position: "top_bar"
    			disabled: false,
    			module: "MMM-ModuleScheduler",
    				// Sets the schedule for the display
    				// Displays 100% bright between 0630 and 2100
    				// All "daytime_scheduler" modules go to 0% brightness between 2100 and 0630
    				global_schedule: [
    					{from: "00 6 * * *", to: "30 21 * * *", groupClass: "daytime_scheduler"},
    			disabled: false,
    			module: "MMM-Globe",
    			position: "top_bar",
    			classes: "daytime_scheduler",
    				style: "geoColor",	// options: "natColor", "geoColor", "airMass", "fullBand", "europeDiscNat", "europeDiscSnow", "centralAmericaDiscNat"
    				imageSize: "400",
    				updateInterval: 10 * 60 * 1000, // every ten minutes
    			disabled: false,
    			module: "clock",
    			classes: "scheduler",
    				lat: "XX.xxxxxxx",
    				long: "-XXX.xxxxxxxx",
    				clockBold: false,
    				dateFormat: "dddd, MMM D, YYYY",
    				showWeek: true,
    				showSunTimes: true,
    				showMoonTimes: true,
    				timezone: "America/Los_Angeles",
    				module_schedule: {from: "30 21 * * *", to: "30 6 * * *", dimLevel: "100"}
    			disabled: true,
    			module: "MMM-NHL",
    				colored: "true",
    				focus_on: ["BOS", "MTL", "CHI", "TOR"],
    				matches: "6",
    			disabled: false,
    			module: "MMM-Pollen",
    			header: "Pollen Forecast for XXXXX",
    				updateInterval: 6 * 60 * 60 * 1000, // every six hours
    				zip_code: "XXXXX",
    			disabled: false,
    			header: "Holidays",
    				maximumEntries: "1",
    				colored: true,
    				fade: false,
    					{color: "#FF0033", symbol: "calendar-check", url: "https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"},
    			disabled: false,
    			header: "xxxxx",
    				maximumEntries: "20",
    				colored: true,
    				fade: false,
    					{color: "#6666FF", symbol: "calendar-check", url: "https://xxxx.xxx/xxxxxxx/calendar.ics"},
    			disabled: false,
    			header: "xxxxx",
    				maximumEntries: "17",
    				colored: true,
    				fade: false,
    					{color: "#FF00FF", symbol: "calendar-check", url: "https://xxxxx.xxx/xxxxxxxxx/basic.ics"},
    			disabled: false,
    			module: "MMM-WeatherOrNot",
    				locationCode: "xxxxxxxxxx",             // See instructions
    				languages: "en",                          // See Languages list
    				tempUnits: "F",                           // F or C
    				font: "Tahoma",                           // See Font list
    				textColor: "#ffffff",                     // Hex color codes.
    				htColor: "#ffffff",                       // high temp color. Hex color codes.
    				ltColor: "#00dfff",                       // low temp color. Hex color codes.
    				sunColor: "#febc2f",                      // Hex color codes.
    				moonColor: "#dfdede",                     // Hex color codes.
    				cloudColor: "#dfdede",                    // Hex color codes.
    				cloudFill: "#1f567c",                     // Hex color codes.
    				rainColor: "#93bffe",                     // Hex color codes.
    				snowColor: "#dfdede",                     // Hex color codes.
    				height: "230px",                          // module is responsive to changes
    				width: "400px",                          // module is responsive to changes
    				label: "xxxxx",		                 // Location seems logical . .
    				days: "7",                                // 3, 5 or 7
    				theme: "dark",                            // See Themes list *** theme overrides bgColor. ***
    				bgColor: "#000000",                       // theme overrides bgColor.
    				icons: "Climacons Animated",              // Iconvault, Climacons or Climacons Animated
    				animationSpeed: 3000,
    			disabled: false,
    				locationCode: "xxxxxxxxxxxx",           // See instructions
    				label: "xxxxxxxx",	                 // Location seems logical . .
    			disabled: false,
    				height: "220px",                          // module is responsive to changes
    				label: "xxxx",		                 // Location seems logical . .
    			disabled: false,
    			module: "newsfeed",
    			position: "bottom_bar",
    				feeds: [
    						title: "Fox News",
    						url: "http://feeds.foxnews.com/foxnews/latest"
    				showSourceTitle: true,
    				showPublishDate: true,
    				broadcastNewsFeeds: true,
    				broadcastNewsUpdates: true
    Jarhead96097
    M 1 Reply Last reply Jun 18, 2020, 1:26 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @Jarhead96097
      @Jarhead96097
      You may have to rename the 2nd and 3rd instances. I never tried more than one at the same time.
      J 1 Reply Last reply Jun 18, 2020, 3:17 PM Reply Quote 1
        Jarhead96097 @Mykle1
        @Mykle1 Interesting idea… but being the relative noob that I am, would I simply copy and rename the folders and make appropriate config changes, or are there more steps? Do I need to do an npm install --productive in each renamed folder?
        Thanks for your help!
        Jarhead96097
        J 1 Reply Last reply Jun 18, 2020, 7:51 PM Reply Quote 0
          Jarhead96097 @Jarhead96097
          @Mykle1
          I found another post that describes using multiple instances of a module. I’ve copied and renamed the second and third instance, and updated the *.js, *.css and config.js files. Everything seems to be updating and working correctly now. I’ll check again in another hour to make sure.
          Thanks for the idea!
          Jarhead96097
          J 1 Reply Last reply Jun 18, 2020, 11:35 PM Reply Quote 0
            @Mykle1
            Well, I spoke too quickly. It seems that renaming the three instances helped but didn’t eliminate the problem. The data still grows stale after some period of time.
            Any other ideas? Other than copying/pasting/renaming, editing the .js and .css files and doing the npm install, is there anything else I should be doing to ensure the three modules work independently and continue to retrieve weather data?
            Thanks,
            Jarhead96097
            M 1 Reply Last reply Jun 19, 2020, 12:33 AM Reply Quote 0
              @Jarhead96097
              Well, there are no guarantees.
              You’re using a separate location and locationCode for each instance? (by following the readme instructions)
              You could try staggering the updateInterval on each instance as well (so they’re not updating at the same time)
              I’ve never used more than one instance
              J 1 Reply Last reply Jun 19, 2020, 12:36 AM Reply Quote 0
                @Mykle1 Sure… my mileage may vary… completely understood.
                Yes, I’ve configured them with three different sets of location and locationCode information.
                I wondered about staggering the updateInterval, so I’ll try that next.
                Thanks!
                Jarhead96097
                M 1 Reply Last reply Jun 19, 2020, 12:45 AM Reply Quote 0
                  @Jarhead96097
                  I’m testing. I’ll let it run for a while.
                  J S 2 Replies Last reply Jun 19, 2020, 12:47 AM Reply Quote 1
                    @Mykle1 Thanks for all the help! I love the module… just wish I could figure out why the information goes stale.
                    Jarhead96097
                    M 1 Reply Last reply Jun 19, 2020, 1:41 AM Reply Quote 0
                      sdetweil @Mykle1
                      @Mykle1 does the module rebuild the display or does it locate the dom elements and update those?
                      document.getElementbyId() … if so, you probably have duplicate IDs w 2 versions running
                      in my modules I use the module identifier as part of the item id to avoid this
                      this.identifer in the modulename.js
                      M 1 Reply Last reply Jun 19, 2020, 12:53 AM Reply Quote 2
                      1 / 3
