    MMM-WeatherOrNot
    21 Posts 3 Posters 4.8k Views 3 Watching
    • Jarhead96097J Offline
      Jarhead96097
      Hi all - I’ve updated my MM to use the responsive layout and animated icons available in MMM-WeatherOrNot. I love it and it looks great! However, as I’m displaying three locations, it seems as though only the last location (listed in config.js) is receiving updates throughout the day. I end up having to stop MM and restart it (pm2 restart MagicMirror --update-env) to get current information for the first two locations. Any ideas to help me troubleshoot?
      Thanks in advance!
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "imperial",
      			     // starts serveronly and then starts chrome browser
      			     // false, default for all  NON-armv6l devices
      			disabled: false,
      			module: "alert",
      			disabled: false,
      			module: "updatenotification",
      			position: "top_bar"
      			disabled: false,
      			module: "MMM-ModuleScheduler",
      				// Sets the schedule for the display
      				// Displays 100% bright between 0630 and 2100
      				// All "daytime_scheduler" modules go to 0% brightness between 2100 and 0630
      				global_schedule: [
      					{from: "00 6 * * *", to: "30 21 * * *", groupClass: "daytime_scheduler"},
      			disabled: false,
      			module: "MMM-Globe",
      			position: "top_bar",
      			classes: "daytime_scheduler",
      				style: "geoColor",	// options: "natColor", "geoColor", "airMass", "fullBand", "europeDiscNat", "europeDiscSnow", "centralAmericaDiscNat"
      				imageSize: "400",
      				updateInterval: 10 * 60 * 1000, // every ten minutes
      			disabled: false,
      			module: "clock",
      			classes: "scheduler",
      				lat: "XX.xxxxxxx",
      				long: "-XXX.xxxxxxxx",
      				clockBold: false,
      				dateFormat: "dddd, MMM D, YYYY",
      				showWeek: true,
      				showSunTimes: true,
      				showMoonTimes: true,
      				timezone: "America/Los_Angeles",
      				module_schedule: {from: "30 21 * * *", to: "30 6 * * *", dimLevel: "100"}
      			disabled: true,
      			module: "MMM-NHL",
      				colored: "true",
      				focus_on: ["BOS", "MTL", "CHI", "TOR"],
      				matches: "6",
      			disabled: false,
      			module: "MMM-Pollen",
      			header: "Pollen Forecast for XXXXX",
      				updateInterval: 6 * 60 * 60 * 1000, // every six hours
      				zip_code: "XXXXX",
      			disabled: false,
      			header: "Holidays",
      				maximumEntries: "1",
      				colored: true,
      				fade: false,
      					{color: "#FF0033", symbol: "calendar-check", url: "https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"},
      			disabled: false,
      			header: "xxxxx",
      				maximumEntries: "20",
      				colored: true,
      				fade: false,
      					{color: "#6666FF", symbol: "calendar-check", url: "https://xxxx.xxx/xxxxxxx/calendar.ics"},
      			disabled: false,
      			header: "xxxxx",
      				maximumEntries: "17",
      				colored: true,
      				fade: false,
      					{color: "#FF00FF", symbol: "calendar-check", url: "https://xxxxx.xxx/xxxxxxxxx/basic.ics"},
      			disabled: false,
      			module: "MMM-WeatherOrNot",
      				locationCode: "xxxxxxxxxx",             // See instructions
      				languages: "en",                          // See Languages list
      				tempUnits: "F",                           // F or C
      				font: "Tahoma",                           // See Font list
      				textColor: "#ffffff",                     // Hex color codes.
      				htColor: "#ffffff",                       // high temp color. Hex color codes.
      				ltColor: "#00dfff",                       // low temp color. Hex color codes.
      				sunColor: "#febc2f",                      // Hex color codes.
      				moonColor: "#dfdede",                     // Hex color codes.
      				cloudColor: "#dfdede",                    // Hex color codes.
      				cloudFill: "#1f567c",                     // Hex color codes.
      				rainColor: "#93bffe",                     // Hex color codes.
      				snowColor: "#dfdede",                     // Hex color codes.
      				height: "230px",                          // module is responsive to changes
      				width: "400px",                          // module is responsive to changes
      				label: "xxxxx",		                 // Location seems logical . .
      				days: "7",                                // 3, 5 or 7
      				theme: "dark",                            // See Themes list *** theme overrides bgColor. ***
      				bgColor: "#000000",                       // theme overrides bgColor.
      				icons: "Climacons Animated",              // Iconvault, Climacons or Climacons Animated
      				animationSpeed: 3000,
      			disabled: false,
      				locationCode: "xxxxxxxxxxxx",           // See instructions
      				label: "xxxxxxxx",	                 // Location seems logical . .
      			disabled: false,
      				height: "220px",                          // module is responsive to changes
      				label: "xxxx",		                 // Location seems logical . .
      			disabled: false,
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Fox News",
      						url: "http://feeds.foxnews.com/foxnews/latest"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      Jarhead96097
        Mykle1 Project Sponsor Module Developer @Jarhead96097
        @Jarhead96097
        You may have to rename the 2nd and 3rd instances. I never tried more than one at the same time.
        Jarhead96097J 1 Reply Last reply Reply Quote 1
          Jarhead96097 @Mykle1
          @Mykle1 Interesting idea… but being the relative noob that I am, would I simply copy and rename the folders and make appropriate config changes, or are there more steps? Do I need to do an npm install --productive in each renamed folder?
          Thanks for your help!
          Jarhead96097
          Jarhead96097J 1 Reply Last reply Reply Quote 0
            Jarhead96097 @Jarhead96097
            @Mykle1
            I found another post that describes using multiple instances of a module. I’ve copied and renamed the second and third instance, and updated the *.js, *.css and config.js files. Everything seems to be updating and working correctly now. I’ll check again in another hour to make sure.
            Thanks for the idea!
            Jarhead96097
              @Mykle1
              Well, I spoke too quickly. It seems that renaming the three instances helped but didn’t eliminate the problem. The data still grows stale after some period of time.
              Any other ideas? Other than copying/pasting/renaming, editing the .js and .css files and doing the npm install, is there anything else I should be doing to ensure the three modules work independently and continue to retrieve weather data?
              Thanks,
              Jarhead96097
                @Jarhead96097
                Well, there are no guarantees.
                You’re using a separate location and locationCode for each instance? (by following the readme instructions)
                You could try staggering the updateInterval on each instance as well (so they’re not updating at the same time)
                I’ve never used more than one instance
                  @Mykle1 Sure… my mileage may vary… completely understood.
                  Yes, I’ve configured them with three different sets of location and locationCode information.
                  I wondered about staggering the updateInterval, so I’ll try that next.
                  Thanks!
                  Jarhead96097
                    @Jarhead96097
                    I’m testing. I’ll let it run for a while.
                    Jarhead96097J S 2 Replies Last reply Reply Quote 1
                      @Mykle1 Thanks for all the help! I love the module… just wish I could figure out why the information goes stale.
                      Jarhead96097
                        sdetweil @Mykle1
                        @Mykle1 does the module rebuild the display or does it locate the dom elements and update those?
                        document.getElementbyId() … if so, you probably have duplicate IDs w 2 versions running
                        in my modules I use the module identifier as part of the item id to avoid this
                        this.identifer in the modulename.js
                          It’s an iframe that is being updated via the url
                          Mykle1M S 2 Replies Last reply Reply Quote 1
                            Mykle1 Project Sponsor Module Developer @Mykle1
                            @Mykle1 is out for a smoke.
                              sdetweil @Mykle1
                              @Mykle1 iframe. gotcha
                                sdetweil @Mykle1
                                @Mykle1 hey hey. you didn’t tell me!
                                  The hell I didn’t! My last post was a broadcast notification. :-)
                                    @Jarhead96097
                                    I am experiencing the same issue.
                                    Jarhead96097J 2 Replies Last reply Reply Quote 0
                                      @Mykle1 Well, glad to hear it isn’t related to my individual setup. If there’s anything I can help test, please let me know.
                                      Jarhead96097
                                        @Mykle1
                                        Would I need to edit the MMM-WeatherOrNot2.js and MMM-WeatherOrNot3.js code to somehow reference different iframes? Is there a different way to reference multiple iframes running on MM?
                                        Jarhead96097
                                          @Jarhead96097
                                          I tried that. No luck. If you wanted to try for yourself, do:
                                          Make copy of module folder
                                          Rename copy folder to MMM-WeatherOrNot2
                                          Open the MMM-WeatherOrNot2 folder
                                          Rename the css file to MMM-WeatherOrNot2,css
                                          Rename the MMM_WeatherOrNot.js file to MMM-WeatherOrNot2,js
                                          Open the MMM-WeatherOrNot2,js file
                                          Change line 8 to Module.register("MMM-WeatherOrNot2",{
                                          Change line 49 return ["MMM-WeatherOrNot2.css"];
                                          Make new entry in config for MMM-WeatherOrNot2
                                            @Mykle1 said in MMM-WeatherOrNot:
                                            @Jarhead96097
                                            Yes, unfortunately, I had the same result. Is there a way to create an array and display all of the configured locations?
                                            Jarhead96097
