    MMM-WeatherOrNot
    21 Posts 3 Posters 5.8k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @Jarhead96097
      @Jarhead96097
      Well, there are no guarantees.
      You’re using a separate location and locationCode for each instance? (by following the readme instructions)
      You could try staggering the updateInterval on each instance as well (so they’re not updating at the same time)
      I’ve never used more than one instance
      Jarhead96097J 1 Reply Last reply Reply Quote 0
      • Jarhead96097J Offline
        Jarhead96097 @Mykle1
        @Mykle1 Sure… my mileage may vary… completely understood.
        Yes, I’ve configured them with three different sets of location and locationCode information.
        I wondered about staggering the updateInterval, so I’ll try that next.
        Thanks!
        Jarhead96097
          @Jarhead96097
          I’m testing. I’ll let it run for a while.
          Jarhead96097J S 2 Replies Last reply Reply Quote 1
            @Mykle1 Thanks for all the help! I love the module… just wish I could figure out why the information goes stale.
            Jarhead96097
              sdetweil @Mykle1
              @Mykle1 does the module rebuild the display or does it locate the dom elements and update those?
              document.getElementbyId() … if so, you probably have duplicate IDs w 2 versions running
              in my modules I use the module identifier as part of the item id to avoid this
              this.identifer in the modulename.js
                It’s an iframe that is being updated via the url
                Mykle1M S 2 Replies Last reply Reply Quote 1
                  Mykle1 Project Sponsor Module Developer @Mykle1
                  @Mykle1 is out for a smoke.
                    sdetweil @Mykle1
                    @Mykle1 iframe. gotcha
                      sdetweil @Mykle1
                      @Mykle1 hey hey. you didn’t tell me!
                        The hell I didn’t! My last post was a broadcast notification. :-)
                          @Jarhead96097
                          I am experiencing the same issue.
                          Jarhead96097J 2 Replies Last reply Reply Quote 0
                            @Mykle1 Well, glad to hear it isn’t related to my individual setup. If there’s anything I can help test, please let me know.
                            Jarhead96097
                              @Mykle1
                              Would I need to edit the MMM-WeatherOrNot2.js and MMM-WeatherOrNot3.js code to somehow reference different iframes? Is there a different way to reference multiple iframes running on MM?
                              Jarhead96097
                                @Jarhead96097
                                I tried that. No luck. If you wanted to try for yourself, do:
                                Make copy of module folder
                                Rename copy folder to MMM-WeatherOrNot2
                                Open the MMM-WeatherOrNot2 folder
                                Rename the css file to MMM-WeatherOrNot2,css
                                Rename the MMM_WeatherOrNot.js file to MMM-WeatherOrNot2,js
                                Open the MMM-WeatherOrNot2,js file
                                Change line 8 to Module.register("MMM-WeatherOrNot2",{
                                Change line 49 return ["MMM-WeatherOrNot2.css"];
                                Make new entry in config for MMM-WeatherOrNot2
                                Jarhead96097J 1 Reply Last reply Reply Quote 1
                                  @Mykle1 said in MMM-WeatherOrNot:
                                  @Jarhead96097
                                  Yes, unfortunately, I had the same result. Is there a way to create an array and display all of the configured locations?
                                  Jarhead96097
                                    @Jarhead96097
                                    You could always give it a try. :-)
