    installing mm
    23 Posts 3 Posters 6.4k Views 3 Watching
    • G Offline
      geo
      hi thx for that but as i have said before i have no idea how to copy and paste from pi
      geo
        sdetweil @geo
        @geo open an ssh session from your pc to pi.
        or slow way, open a browser on pi, and terminal window, and copy. paste that way
        • G Offline
          geo
          hi installed the scripts but cant open the mirror.
            sdetweil @geo
            @geo you don’t install the scripts… u execute one line
            to install you copy/paste this line
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
            which will execute the install process
            • G Offline
              geo
              hi yes i havs done that but how do i open the mirror
              • G Offline
                geo
                npm start command not found
                  sdetweil @geo
                  @geo show me the ~/install.log file
                  something is missing
                  • G Offline
                    geo
                    hi,finally got my numb brain partially working and installed scripts,easy when you know how,thankyou.now how do i open mm cos npm start does not work.
                    would still like to know why the original command did not work.thx again,geocd MgicMirror
                    hi when i tried to find the install.log file permission was denied
                      sdetweil @geo
                      @geo I don’t understand.
                      to start mm after install, you navigate to the MagicMirror folder and execute npm start
                      npm start
                        sdetweil @geo
                        @geo >would still like to know why the original command did not work.
                        because u copied some old instructions.
                        the install scripts were removed 2 releases ago, because they require constant updating, which the project felt was not in the core mission of MagicMirror.
                        I have taken over maintenance and updates for the scripts, and this is mentioned on the project GitHub site, as alternative install methods
                        see after
                        https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
