    installing mm
    23 Posts 3 Posters 8.2k Views 3 Watching
    • G Offline
      geo
      hi yes i havs done that but how do i open the mirror
      • G Offline
        geo
        npm start command not found
          sdetweil @geo
          @geo show me the ~/install.log file
          something is missing
          • G Offline
            geo
            hi,finally got my numb brain partially working and installed scripts,easy when you know how,thankyou.now how do i open mm cos npm start does not work.
            would still like to know why the original command did not work.thx again,geocd MgicMirror
            hi when i tried to find the install.log file permission was denied
              sdetweil @geo
              @geo I don’t understand.
              to start mm after install, you navigate to the MagicMirror folder and execute npm start
              npm start
                sdetweil @geo
                @geo >would still like to know why the original command did not work.
                because u copied some old instructions.
                the install scripts were removed 2 releases ago, because they require constant updating, which the project felt was not in the core mission of MagicMirror.
                I have taken over maintenance and updates for the scripts, and this is mentioned on the project GitHub site, as alternative install methods
                see after
                https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
                • G Offline
                  geo
                  hi thx for that.
                  i now have mm installed as per your instructions i can open the config and everything else but still cant get the mm display.you asked to see the install log but permission was denied.
                  i am finding it difficult to understand why matters seem more complicated which makes everything more daunting especially after having an up and running mm which was ruined by me installing out of date info.
                  i am at a loss as to what to do next other than to sell everything.
                  regards,
                  geo
                  S Mykle1M 2 Replies Last reply Reply Quote 0
                    sdetweil @geo
                    @geo are you running MagicMirrorOS? and not the raw MagicMirror app on raspian?
                    you did NOT use sudo when u ran the install, correct?
                    • G Offline
                      geo
                      hi i loaded the mm from your script
                        sdetweil @geo
                        @geo so, it still makes no sense
                        you open a terminal window, ctrl-alt-t, and the install.log should be right there
                        u have to edit it,
                        nano install.log
                        or type it
                        cat install.log
                          Mykle1 Project Sponsor Module Developer @geo
                          @geo said in installing mm:
                          It may take a little time and a few attempts but follow @sdetweil’s directions and he will help you get it running.
                          • G Offline
                            geo
                            nstall starting - Wed Jul 15 11:26:24 BST 2020
                            installing on armv7l processor system
                            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretc$
                            ^[[96mUpdating packages …^[[90m
                            Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB] Hit:$
                            apt-get update completed ok
                            apt-get upgrade started
                            apt upgrade result =rc=100 Reading package lists…
                            Building dependency tree…
                            Reading state information…
                            You might want to run ‘apt --fix-broken install’ to correct these.
                            The following packages have unmet dependencies:
                            apt-utils : Depends: apt (= 1.4.8) but 1.4.10 is installed
                            E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or spec$
                            ^[[96mInstalling helper tools …^[[90m
                            build-essential is already the newest version (12.3).
                            [ Read 415 lines ]
                            ^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
                            ^X Exit ^R Read File ^\ Replace ^U Uncut Text^T To Spell ^_ Go To Line
                              sdetweil @geo
                              @geo can u please try with buster, stretch is too old
                              • G Offline
                                geo @Mykle1
                                @Mykle1 hi again, yes i realise that its more to do with my frustration and lack of understanding.
                                  sdetweil @geo
                                  @geo we’ve all been there, patience.
                                  • G Offline
                                    geo
                                    debian stretch v 9.11.tried to install buster several times and failed.messages unmet depedencies,and try,apt – fixbroken install
                                    hope this makes sense
                                      sdetweil @geo
                                      @geo I understand the words, but don’t understand why you have this problem. I tested 2.12 on buster a couple weeks ago, again.
