    Bathroom Magic Mirror
    67 Posts 25 Posters 104.6k Views 27 Watching
    • hedmikH
      hedmik
      Very nice design and crafts!!! I’ve just built my two first mirrors and i’m now also planning a bath mirror :-)
      Thanks for sharing all detaild pictures as a guidance!
      • O
        otto
        I was think about, maybe build something similar, and got an idea.
        Do u think a rpi move sensor can see through the glas?
        Think if u have an eye behind the screen, and when it’s noticed movement the MM will show up on the screen.
        I don’t own any senor to try it
        qu1queQ FoziF 2 Replies Last reply
        • qu1queQ
          qu1que Project Sponsor @otto
          @otto
          I’ve tried that with a PIR motion sensor, and really doesn’t work very well. So I’ve finally decided to put it outside mirror.
          Anyway, you can try it by yourself.
          Hope it helps.
          • spitzlbergerjS
            spitzlbergerj Project Sponsor Module Developer
            Hi, I’ve tried several options:
            • Motion detector in the mounting arm of the lamp
            • Radar sensor behind the glass
            • Radar sensor inside near the frame
            • Radar sensor outside on the lower frame
            Actually, only the latter works well. And that’s how it’s stayed now. The foil of the mirror shields just about everything. Actually the motion detector in the lamp arm should do the job. But apparently it is also shielded by the aluminium so that it didn’t work.
            So not yet an optimal solution …
            Regards
            Josef
            http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
            • FoziF
              Fozi Project Sponsor @otto
              @otto I put a microwave sensor behind the Glas and it works reliably. You can find my tutorial if you follow the link in my signature.
                secdude
                Hallo Josef,
                how happy are you with the chrome spy mirror glas? is the reflected image brigth enough or is it too dark to operate as the main bathroom mirror? Any comments from the wife?;) I’m about to order the same from glas star.
                Beste Grüsse,
                Mat
                • spitzlbergerjS
                  Hi, Mat,
                  my wife and I are very happy with our mirror and we would both not want to miss it anymore. The mirror is a little darker than a normal mirror. But it is perfectly adequate as a bathroom mirror. My wife has never complained about the (missing) brightness. And I myself am also very satisfied.
                  But before I bought the mirror, I had built a “sample mirror” for my wife from the sample glasses that you can get from the supplier. At that time the direct comparison was possible and the conversion was officially “approved”. :-)
                  Grüße
                  Sepp
                  Regards
                  Josef
                    secdude
                    Thanks for that!
                    • E
                      evgeniy88
                      Impressive work. How many cans of silicone did you use?
                      spitzlbergerjS 1 Reply Last reply
                      • spitzlbergerjS
                        spitzlbergerj Project Sponsor Module Developer @evgeniy88
                        Hi @evgeniy88,
                        I probably needed a lot less than half a can. The relief of the milling helps to save material and still guarantee stability.
                        Soon I will start building a bathroom mirror cabinet with a magic mirror. I will post the details in this forum again. :-)
                        Best regards
                        Josef
                        Regards
                        Josef
                        • E
                          evgeniy88
                          Thanks for your posts. At first I was skeptical about the idea of gluing a mirror on silicone, but now I want to use your design.
                          • spitzlbergerjS
                            Thanks a lot
                            Josef
                            Regards
                            Josef
                            • T
                              tootiemac3
                              Thank you for all this info.
                              I am at the very start of my magic mirror journey and came across you mirror which is simply fantastic.
                              I noticed you had metal LED buttons on the side of your frame which I would like to install one in mine for powering opn/off.
                              Having looked at button tutorials I see most are just 2 jumper wires to the GIPO is this the same for your buttons?
                              How is the LED powered?
                              thanks!
                              Vicki
                              • spitzlbergerjS
                                please forgive the late reply. It slipped through.
                                I use these buttons: https://smile.amazon.de/gp/product/B00JSEX1A0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
                                These have separate connections for “nomaly closed” NC and “normaly open” NO. And there are also the connections for the button LED.
                                But I did not connect the LEDs. Otherwise, besides the LED of the toothbrush and the LED of the mouthwash and the LED of the razor and … another LED would burn. Then I could slowly save the ceiling lighting in the bathroom :-)
                                Regards
                                Josef
                                  PeterKatana
                                  Hi Josef,
                                  Looks very impressive. Which source do you use for the wooden frame?
                                  Thanks a lot
                                  Peter
                                  • spitzlbergerjS
                                    spitzlbergerj Project Sponsor Module Developer @PeterKatana
                                    Hi @PeterKatana,
                                    What do you mean by source?
                                    The frame is made of beech wood. You can buy it from a wood dealer or carpenter. I have taken solid wood shelf savior made of beech from the hardware store. These are glued rod-wise and therefore torsion-resistant.
                                    Regards
                                    Josef
                                    Regards
                                    Josef
                                    P 1 Reply Last reply
                                      PeterKatana @spitzlbergerj
                                      @spitzlbergerj said in Bathroom Magic Mirror:
                                      Hi Josef,
                                      thanks for the recommendation. I will search here for a carpenter. A miter saw I should have. Before I lived in Aschheim, that was easier. Now I am jobwise in Göppingen. Will search around.
                                      I am curious for your next project you announced.
                                      Stay safe !
                                      Br Peter
                                      • spitzlbergerjS
                                        Hallo @PeterKatana,
                                        Ich kann dir den Rahmen auch zuschneiden, wenn du mir die Maße sagst. Vielleicht kommst du ja mal nach Oberschleißheim oder in die Nähe.
                                        Grüße
                                        Sepp
                                        Regards
                                        Josef
                                          SuneRadich
                                          Your mirror looks amazing, but I am wondering. How is the electronics holding up, being put in a bathroom with alot of moisture? I cant see you did anything extra to keep moisture out of the mirror?
                                          • spitzlbergerjS
                                            spitzlbergerj Project Sponsor Module Developer @SuneRadich
                                            Hi @SuneRadich ,
                                            all electrical connections are clamped together in junction boxes for damp locations. The Raspberry Pi is also in such a box. Only the connections of the screen are in their original box, which in my view is not specially protected against moisture.
                                            So far, there have been no problems and even if you remove the mirror, you won’t see anything scorched or similar damage.
                                            Regards
                                            Josef
                                            Regards
                                            Josef
                                            • 3 / 4
