    My first Magic Mirror build in an old imac
    14 Posts 6 Posters 9.0k Views 6 Watching
    • swvalentiS
      swvalenti Project Sponsor
      Very cool, even though I despise Apple. Ha
      Reply Quote -1
        sonicgoose
        I’ve been doing the same thing with a 20" white Intel iMac, but have had one helluva time. None of the display controllers work with the native LG 1600x1050 display Apple put in these things, so I’ve basically gutted the iMac and am putting in a new display, etc.
        D S 2 Replies Last reply
          diemen112 @sonicgoose
          @sonicgoose i think this is the one you need.
          https://www.ebay.com/itm/HDMI-DVI-VGA-LCD-Lvds-Driver-Controller-Board-for-LM201W01-SLC1-LM201W01-SL-C1/313112850369?hash=item48e6faefc1:g:FakAAOSww2he4gaG
          • BKeyportB
            BKeyport Module Developer
            nicely done.
              sonicgoose @diemen112
              @diemen112 Tried four different ones, all allegedly specific to the LM201W01 SL A3 that was in the iMac. None worked.
                sonicgoose @sonicgoose
                @sonicgoose said in My first Magic Mirror build in an old imac:
                Not to hijack the thread, but this is how mine turned out.
                B 1 Reply Last reply
                Reply Quote 3
                  banbutcher @sonicgoose
                  also not wanting to hijack thread… but what weather module are you using? :)
                  thanks
                  Richie
                    diemen112 @banbutcher
                    @banbutcher
                    And the calander module with the colors?!
                    BKeyportB S 2 Replies Last reply
                    • BKeyportB
                      BKeyport Module Developer @diemen112
                      @diemen112 Honestly, that all looks like CSS
                        sonicgoose @banbutcher
                        @banbutcher MMM-DarkSkyForecast
                          @diemen112 That’s default calendar module that comes with MagicMirror.
                          • K
                            keaghoul
                            First off, apologies for the necrobump — didn’t see a rule against it & did see the prompt but didn’t feel this warranted a new topic. Apologies if this is a breach of rules or etiquette here.
                            Anyway, @sonicgoose, I just came into an incredibly similar model (2006 iMac per the box, not sure of the specific model yet — diving into it tomorrow) without a motherboard, and my immediate thought was to turn it into an MM, leading me here. Wondering if you’d be down to do a quick rundown of your build or would be open to any question I might have after I take it apart tomorrow?
                            Thanks much!
                            D 1 Reply Last reply
                              diemen112 @keaghoul
                              @keaghoul first of all you need check the model nr. of the screen. its probably an LG screen, but i don’t know the model nr.
                              with that you can look on Ebay for a display controller for that particular screen.
                              if the PSU is still oke you kan use that one. you have to check which outlet is 12V+ continue is. and you can power the screen with that.
                              also you need a inverter from 12v to 5v for the Raspberry.
                              if you wan’t to use the the speakers u need also en simple AMP i use the TDA7297, i used a other one before but that one gives a white noise.
