    MMM-Events : nothing to display on my Magic Mirror
    20 Posts 3 Posters 3.9k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @RIKKO14
      @RIKKO14
      In theory, yes, but it does not seem to accept Caen, France.
      From the api documentation:
      location string
      A location name to use in filtering the search results. Locations in the form “San Diego”, “San Diego, TX”, “London, United Kingdom”, and “Calgary, Alberta, Canada” are accepted, as are postal codes (“92122”) and venue IDs (“V0-001-000268633-5”). Common geocoordinate formats (“32.746682, -117.162741”) are also accepted, but the “within” parameter is required in order to set a search radius. (optional)
        RIKKO14
        @Mykle1
        and how to put the «within» parameter with the Common geocoordinate formats (“32.746682, -117.162741”) ? it’s more easier with this.
        (optional) = it’s a eventful option ? I’m not a developper so I can’t modify the module.
          @RIKKO14
          I will take a look at it when I have the time.
            @RIKKO14
            Ok, I’ve updated the module and tested it for your area. Run git pull in the MMM-Events directory. Things to mention:
            1. Use the new config entry. I used the coordinates for Caen, France.
            2. There are not many ‘hits’ for your area. Try using different eventType’s in the config.
            3. Increase the radius for possibly more events. I set it to 100km.
            4. There is a placeholder image for when the api does not provide an image for the event.
              Mykle1 Project Sponsor Module Developer @Mykle1
              @Mykle1
              Regarding item #4 in my previous post. If you would rather use a placeholder image of your own (for when the api does not provide an image) you can make or find one and name it ‘go.jpg’. Put that in the modules ‘icons’ folder. However, I caution you to make the replacement image the same dimensions as the default image. Otherwise, the formatting of the module may get screwed up.
                RIKKO14
                I 've made a mistacke but I don’t know where :
                As you said I run git pull
                pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ cd ~/MagicMirror/modules/MMM-Events
                pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ git pull
                Mise à jour 2522a1a..384b255
                Fast-forward
                 MMM-Events.js | 85 +++++++++++++++++++++++++++++++----------------------------
                 README.md     | 52 ++++++++++++++++++------------------
                 2 files changed, 71 insertions(+), 66 deletions(-)
                pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ pm restart mm
                bash: pm : commande introuvable
                pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ pm2 restart mm
                I change in my config.js :
                city:"49.1811, -0.375565",
                but I have this : it is not events for Caen :
                [url=https://zupimages.net/viewer.php?id=20/37/65ps.png][img]https://zupimages.net/up/20/37/65ps.png[/img][/url]
                if i change config.js :
                city:"Caen, France", : it’s doesn’t work
                and how to Increase the radius ?
                Mykle1M S 3 Replies Last reply Reply Quote 0
                  @RIKKO14
                  Using your city:"49.1811, -0.375565", I get this:
                  If the api has no data (events) for Caen, that can not be helped.
                  When I use city:"Caen, France", I get this:
                  So, the module is working. I added the ability to use coordinates for you. If the api does not give back events for those coordinates it means the api does not have data in the free api for that location. I suggested you increase the radius and you asked, ‘and how to Increase the radius ?’ My answer to that is, Look at the new config in the readme. I mentioned that 2 posts above.
                  No, you haven’t. You showed me that the module is working. You’re just not seeing the results you expected
                    sdetweil @RIKKO14
                    @RIKKO14 from the code
                    city: "", // Your City or lat,long ex "40.123456,-74.123456",
                    radius: "", // search radius
                    radiusDistance:"",
                    so in config.js for this module in it config section
                    radius:???
                    radiusDistance: “km”, or “miles”
                        @RIKKO14
                        This is what you should have used. From the readme:
                        module: 'MMM-Events',
                            position: 'top_right',
                                city: "49.1829,0.3707", // "new york", or lat,long ex "40.123456,-74.123456",
                                radius: "100", // search radius
                                radiusDistance: "km", // mi or km
                                eventType: "music,movies_film,art,sports", // Choose from Events List below
                                when: "This Week",  // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months
                                mode: "noFrame",   // "Frame" or "noFrame" (around picture)
                                apikey: "YOUR API KEY",
                                rotateInterval: 5 * 60 * 1000,     // New Event Appears every 5 minutes
                                useHeader: true,	           // Set to true if you want a header
                                header: "Spectacle a proximité",
                                animationSpeed: 3000,              // Event fades in and out
                                picture: true,                     // true, false = no image
                          RIKKO14
                          this is my config.js :
                          				disabled: false,
                          				position: 'top_left',
                          					city: "caen, france", // "new york", or lat,long ex "40.123456,-74.123456",
                          					radius: "50", // search radius
                          					eventType: "music", // Choose from Events List below
                          					apikey: "Pq4n9Vh5zbshSVfS",
                          					rotateInterval: 15 * 1000,     // New Event Appears every 5 minutes
                          					picture: false,                     // true, false = no image
                          and the problem still here…
                          when I use the gps coordinates of caen (49.1811, -0.3712) it’s the same …
                          I uninstalled and reinstalled the module, + git pull and nmp install: still the same …
                          I tried with the gps coordinates of several cities: Las Vegas, Baltimore, New york, Paris, Lyon, Toulouse it works, with Marseille (the 2nd city in France in population it does not work …), the same for Rouen a city 130 kms from Caen and larger that does not work …
                          If I put 200 km of radius the module comes to look for concerts in Paris.
                          However on the Eventful site there are many concerts of music displayed (even if there are not many posted concerning the largest concert hall compared to the concerts displayed on the concert hall’s website. ).
                          it’s incomprehensible and crazy …
                          There is indeed an error when you put “Caen, France” because on your photo posted above it says “Brussel Ouderenplatform” and Brussel is the capital of Belgium so nothing to do with demand …
                          same, when you using : “49.1811, -0.375565” for Caen,
                          the sainte thérèse basilica is in Lisieux (town 67 km from Caen) with a population of 20,771 inhabitants while CAEN has a population of over 100,000 inhabitants.
                            @RIKKO14
                            Copy and pasted from my earlier post.
                              RIKKO14
                              So if I understand correctly we can consult the various concerts (not exhaustive) in caen for free on the eventful site, but that this is not available with the free API. it would take a paid API to do it … Thank you for your feedback, I understand better even if I find it a little weird.
                              thanks you.
                                @RIKKO14 said in MMM-Events : nothing to display on my Magic Mirror:
                                Not necessarily. Possible. I would inquire with them before paying anything.
                                It IS weird but the module can only display the data that is given.
                                  RIKKO14
                                  Great, thank you for your approach. Please keep me posted when you get a response from them.
                                    Uhhhhhhhh
