    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 248.2k Views 20 Watching
    • K Offline
      KirAsh4 Moderator @paviro
      @paviro, but but but … @MichMich said … he said … he said node 6.1.0 is now supported. Dependencies be damned, they need to catch up.
      MichMichM 1 Reply Last reply Reply Quote 0
      • MichMichM Offline
        MichMich @KirAsh4
        @KirAsh4 Yeah, MM supports Node 6.1.0 @paviro apparently still live in the stone age with his modules … 😈
        • K Offline
          KirAsh4 Moderator @MichMich
          @MichMich, I have a laser … let’s tie him up and put his hand under the beam. That’ll teach him!
          • MichMichM Offline
            MichMich
            He is from the stone age. He doesn’t know what a laser is. 😱
            • K Offline
              KirAsh4 Moderator
                paviro
                Ha, ha :laughing:
                Will change my dependencies when I have some spare time.
                – The Doctor
                  Patrick
                  At first: Thank you very much.
                  This module is great and works fine for me.
                  When it’s allowed to make some suggestion…
                  you maybe could add a possibility to switch wireless sockets.
                  The effort for this shouldn’t be much, when you can use xkonni’s remote control.
                  https://github.com/xkonni/raspberry-remote
                  This would be a great possibity for those, who don’t feel comfortable to use a 230V relais… (I studied Mechatronics, so i don’t care :P)
                    paviro
                    Feel free to send a pull request! :)
                    – The Doctor
                      MechMatt @paviro
                      @paviro any suggestions on what relay to get for use with this? There are lots of choices on amazon
                        Patrick
                        Ok. When I’ve time, I will get a wireless transmitter.
                        Would be embarrasing if it wouldnt work because I’ve never tried :anguished:
                        • I Offline
                          IngmarSwart @paviro
                          @paviro I finally found some time to look into the problem I had some more. The exact origin is still unclear to me, but I did figure out that my problem, it is not related to your module, or the MM software in general. I got the same behaviour over ssh: tvservice -o switches the monitor connected to the Pi off, tvservice -p switches it back on, but the screen would appear black. After fiddling around a little bit, I found another solution that does not require root rights. Instead of using the sudo chvt 7 && sudo chvt 9 command, the problem can also be solved using fbset. My modified version of the activateMonitor function file node_helper.js:
                          activateMonitor: function () {
                              if (this.config.relayPIN != false) {
                                gpio.digitalWrite(this.config.relayPIN, this.config.relayOnState)
                              else if (this.config.relayPIN == false){
                                exec("/opt/vc/bin/tvservice -p", null);
                                exec("/bin/fbset -depth 8 && /bin/fbset -depth 16 ", null);
                                exec("/usr/bin/xrefresh",null);
                          For the command xrefresh to work when given via ssh, the correct display variable has to be set (in my case):
                          export DISPLAY=:0 I have added this line to my .profile file in the /home/pi directory so that I don’t have to type it every time I log in via ssh.
                          • I Offline
                            IngmarSwart @MechMatt
                            @MechMatt Have a look at the PowerSwitch Tail. If you live in the US, you can buy an assembled version from Adafruit. If you’re in 240V land (like me), you will have to do some (basic) soldering. Works like a charm for me. :-)
                            • K Offline
                              KirAsh4 Moderator
                              That’s really odd that you have to go through all of that. On my rPi-3 with the most recent Raspbian Jessie release, I can use 'tvservice -o' and 'tvservice -p' and it just works. I don’t have to do anything else. It’s all running as the unprivileged user 'pi' (and without issuing 'sudo' before each command.) I wonder if it has something to do with the monitor and what it responds with when a signal is sent … Glad you figured it out though.
                              • I Offline
                                IngmarSwart @KirAsh4
                                @KirAsh4 I agree, it’s very strange. Like you, I am using a rPi-3 with the most recent version of Raspbian Jessie and run everything as user pi. So maybe it is the monitor (Philips 273V5l). Which one do you use?
                                Although the problem is fixed, I would like to know what is going on.
                                • K Offline
                                  KirAsh4 Moderator
                                  Let me get home and get you the details on it. It a monitor we had sitting around at the office, some high end graphic Pro monitor that wasn’t being used anymore. I also have a test I want to perform on it, see if that makes a difference in what I’m seeing. Stay tuned.
                                    joerod @paviro
                                    @paviro I donwloaded to node 5.0.0 and I know get the following error
                                    Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                                      paviro @joerod
                                      @joerod That’s all? Not a failure of my plugin. Any more logs?
                                      – The Doctor
                                      • T Offline
                                        Try2Fly
                                        For people who are not confortable with programming this, or need to buy a pir sensor anyway
                                        You can also buy a pir with motionsensor like this
                                          joerod @paviro
                                          @paviro
                                              9 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
                                              9 verbose stack Exit status 1
                                              9 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:214$
                                              9 verbose stack     at emitTwo (events.js:87:13)
                                              9 verbose stack     at EventEmitter.emit (events.js:172:7)
                                              9 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
                                              9 verbose stack     at ChildProcess.emit (events.js:172:7)
                                              9 verbose stack     at maybeClose (internal/child_process.js:817:16)
                                              9 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
                                          I’ve tested my PIR sensor with a Python script to make sure I’m using the proper GPIO and its functioning as it should. I do see 1 & 0 when I move near the sensor so I don’t think its the hardware.
                                          I’d love to use this module, I was going to do it in python but since you have it in JS I figured why not use that.
                                            paviro @joerod
                                            @joerod please use Markdown on code snippets so it is easier to read! :) have you installed all the dependencies (also for the mirror itself?)
                                            @MichMich any idea?
                                            – The Doctor
                                            • 4 / 7
