    Black screen after 2.13 update - tentatively resolved
    53 Posts 9 Posters 24.8k Views 9 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      Correct, only pokemon had 2.1.0 I didnt see 2.1.0 in darksky just 2.2.0
        sdetweil @swvalenti
        @swvalenti and u commented it out in darksky, yes?
        show errors
          Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-YvJxUhUeeIN7m4Y4YEc1FVS+YDCNVK6VsHIHx5z29EE='), or a nonce ('nonce-...') is required to enable inline execution.
          main.js:487 Initializing MagicMirror.
          translator.js:129 Loading core translation file: translations/en.json
          translator.js:154 Loading core translation fallback file: translations/en.json
          loader.js:176 Load script: modules/default/alert//alert.js
          module.js:513 Module registered: alert
          loader.js:148 Bootstrapping module: alert
          loader.js:176 Load script: modules/default/alert/notificationFx.js
          loader.js:153 Scripts loaded for: alert
          loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
          loader.js:195 Load stylesheet: vendor/css/font-awesome.css
          loader.js:155 Styles loaded for: alert
          translator.js:102 alert - Load translation fallback: translations/en.json
          /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
            protocols.This exposes users of this app to unnecessary security risks.
            Consider loading the following resources over HTTPS or FTPS.
           - http://0.0.0.0:8080/css/main.css
          - http://0.0.0.0:8080/fonts/roboto.css
          - http://0.0.0.0:8080/socket.io/socket.io.js
          - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
          - http://0.0.0.0:8080/js/defaults.js
          - http://0.0.0.0:8080/config/config.js
          - http://0.0.0.0:8080/vendor/vendor.js
          - http://0.0.0.0:8080/modules/default/defaultmodules.js
          - http://0.0.0.0:8080/js/logger.js
          - http://0.0.0.0:8080/translations/translations.js
          - http://0.0.0.0:8080/js/translator.js
          - http://0.0.0.0:8080/js/class.js
          - http://0.0.0.0:8080/js/module.js
          - http://0.0.0.0:8080/js/loader.js
          - http://0.0.0.0:8080/js/socketclient.js
          - http://0.0.0.0:8080/js/main.js
          - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
          - http://0.0.0.0:8080/translations/en.json
          - http://0.0.0.0:8080/modules/default/alert//alert.js
          - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
          - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
          - http://0.0.0.0:8080/vendor/css/font-awesome.css
          - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
          - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
          For more information and help, consult
          https://electronjs.org/docs/tutorial/security.
           This warning will not show up
          once the app is packaged.
          loader.js:157 Translations loaded for: alert
          0.0.0.0/:4 Uncaught SyntaxError: Unexpected token / in JSON at position 44
              at JSON.parse (<anonymous>)
              at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
            sdetweil @swvalenti
            @swvalenti let me work on it. is that a pi0 perhaps, running chrome instead of electron?
              No sir it is a pi3b+ running buster
                sdetweil @swvalenti
                @swvalenti after looking at my dev console I see the same content security warning, but it is not fatal… just a warning…
                I added the
                requiresVersion: "2.1.0",
                to the calendar and it worked fine,
                then commented out
                //requiresVersion: "2.1.0",
                still worked ok…
                and didn’t need that meta tag…
                so, there must be something else going on…
                can u rename the config.js out of the way (config.js.save)
                and copy the sample
                cp config.js.sample config.js
                and try MM again
                • spitzlbergerjS Offline
                  spitzlbergerj Project Sponsor Module Developer @m0bed
                  @m0bed said in Black screen after 2.13 update - tentatively resolved:
                  @m0bed So, I changed my config found out that this modules dont work at the moment:
                  MMM-Homematic-Heaters
                  The problem are the comments in the two translation files . Remove the comments and it will work again.
                  Since MMM-Homematic-Heaters seems to be no longer maintained, I have forked the module MMM-Homematic-Thermostats from it and developed it further. There the error is fixed. Maybe changing the module will help :-)
                  Regards
                  Josef
                  http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                    Somehow it was the MMM-DailyPokemon jacking all things up. Removed and all is working fine again.
                      sdetweil @swvalenti
                      @swvalenti probably the comments in the translation files, en and fr
                        Yes that is the error it was showing but I didn’t know how to proceed in fixing.
                          sdetweil @swvalenti
                          @swvalenti edit the json files in the translations folder and remove the comment. one of the others does not have a comment for example
                            Outstanding, that worked! My son thanks you
                            • K Offline
                              Klinge @sdetweil
                              I run npm install in the …\MagicMirror Folder
                              Ok, in future I will use your script
                                sdetweil @Klinge
                                @Klinge is this on windows? as you did \MagicMirror
                                • 3 / 3
