    MMM-DHT22 Humidity and Temperature Module
    47 Posts 14 Posters 46.7k Views 14 Watching
    • BangeeB Offline
      Bangee Module Developer
      @MxBln I did not check this.
      @Jopyth yes, it needs a sudo command inside the app.
      • T Offline
        trividar
        Hi guys
        I have some problems with this module. I test it with two DHT22 and I have always the same strange thing. Please look my short clip: [Youtube](video: https://youtu.be/gvuq6A13fw8). Sometimes it shows quickly the exact Temp and sometimes strange values but most of the time it shows undefined. I try to made a skipt outside of the MM and in this picture (link) you can see , at the same time my skript shows the right value but in MM its undefined.
        Can someone test this module or help me to find the fault? THX a lot for any help!
        • BangeeB Offline
          What’s the result when you try this command directli in your terminal:
          go to cd MagicMirror/modules/MMM-DHT22/
          sudo ./dht_var 2
          Replace 2 with your sensor Pin
          I’ve tested this on two different Pi’s
          • T Offline
            trividar
            @Bangee ok, now I’m confused ;o)
            Bild Text
            The first 5 lines I tried during my MM was working but nothing happend, i had to wait 2 minutes and it shows just a new comment line. After i stopped my MM it was working like a charm (last two lines). What I’m doing wrong?..
            • BangeeB Offline
              I don’t now atm :-)
              it looks like something is blocking the dht_var script when your MM is running
              Do you have error in your MM logs?
              • T Offline
                trividar
                I just checkt it and I don’t have any errors …;o(
                • BangeeB Offline
                  I’ve tried this on an other pi and it works …
                  can you uncomment line 33 in node_helper.js to check if he tries to write something in to the logs?
                  	console.log("Log: " + temp + " - " + hum);
                  • T Offline
                    trividar
                    THX @Bangee for your help. Now i got this error:
                    Error
                    • yawnsY Offline
                      yawns Moderator
                      Right. Please replace the word temp with arr[1] and hum with arr[0] in line 33 in node_helper.js
                      • T Offline
                        trividar
                        Now my logs looks like this after I changed line 33:
                        Bild Text
                        • 1 / 5
