    MMM-DHT22 Humidity and Temperature Module
    47 Posts 14 Posters 51.6k Views 14 Watching
      MxBln
      Does it also work with the DHT-11?
        Jopyth Moderator @Bangee
        @Bangee Just me being confused: this needs sudo rights, doesn’t it? You just do not want to start the mirror with sudo?
          Bangee Module Developer
          @MxBln I did not check this.
          @Jopyth yes, it needs a sudo command inside the app.
          • T
            trividar
            Hi guys
            I have some problems with this module. I test it with two DHT22 and I have always the same strange thing. Please look my short clip: [Youtube](video: https://youtu.be/gvuq6A13fw8). Sometimes it shows quickly the exact Temp and sometimes strange values but most of the time it shows undefined. I try to made a skipt outside of the MM and in this picture (link) you can see , at the same time my skript shows the right value but in MM its undefined.
            Can someone test this module or help me to find the fault? THX a lot for any help!
              What’s the result when you try this command directli in your terminal:
              go to cd MagicMirror/modules/MMM-DHT22/
              sudo ./dht_var 2
              Replace 2 with your sensor Pin
              I’ve tested this on two different Pi’s
              • T
                trividar
                @Bangee ok, now I’m confused ;o)
                Bild Text
                The first 5 lines I tried during my MM was working but nothing happend, i had to wait 2 minutes and it shows just a new comment line. After i stopped my MM it was working like a charm (last two lines). What I’m doing wrong?..
                  I don’t now atm :-)
                  it looks like something is blocking the dht_var script when your MM is running
                  Do you have error in your MM logs?
                  • T
                    trividar
                    I just checkt it and I don’t have any errors …;o(
                      I’ve tried this on an other pi and it works …
                      can you uncomment line 33 in node_helper.js to check if he tries to write something in to the logs?
                      	console.log("Log: " + temp + " - " + hum);
                      • T
                        trividar
                        THX @Bangee for your help. Now i got this error:
                        Error
                        • Y
                          yawns Moderator
                          Right. Please replace the word temp with arr[1] and hum with arr[0] in line 33 in node_helper.js
                          • T
                            trividar
                            Now my logs looks like this after I changed line 33:
                            Bild Text
                            • Y
                              yawns Moderator
                              Okay, so it definitely fails retrieving data from the sensor, but the error handling does not catch this failure.
                              • T
                                trividar
                                I have test it with two dht22. One was mine and one I received from @Bangee who was so kind to test it before sending it and it was working at his home, but when I tried it at my home it wasn’t working. So I have no Idea what can be the failure.
                                • T
                                  trividar
                                  Hi ,
                                  so I just figure it out, that the motiondetector by alexyak blocking the DHT22 script. If I disable this module my DHT 22 works perfect. Somebody knows what make this problem?
                                    that’s very strange!?!
                                    Is this module working with a PIR Sensor or a Webcam?
                                    Im using Paviro’s PIR Sensor to turn on an off my monitor.
                                    • T
                                      trividar
                                      With picamera. I installed MM on my other pi (completely new installation) and i got the same problem after i installed the motion detector. So I disabled on my MM the motion detector and it works fine on both pi’s. It’s very strange ;o(
                                      • T
                                        trividar
                                        No one an idea?
                                          I am using a PIR sensor.
                                          So i can’t reproduce it.
                                            PaulB
                                            Dear guys,
                                            Ive tried to run this skript,nevertheless it’s showing me ‘undefined’ when I am running it in MM-Mode.
                                            Ive already checked the Pin setup and it should be right. Furthermore Ive checked your advises in the posts above me.
                                            Do you have an idea how to fix this error or even how to get an idea where the error is? :D
                                            Kind regards :)
