    MMM-DHT22 Humidity and Temperature Module
    47 Posts 14 Posters 51.6k Views 14 Watching
      Bangee Module Developer
      Here is my MMM-DHT22 Module.
      Temperature and Humidity monitoring Module for MagicMirror2 that works for DHT22 and AM2302 sensors.
      https://github.com/Bangee44/MMM-DHT22/
      It’s analog to @psk’s Module: https://forum.magicmirror.builders/topic/726/mmm-temperature-humidity-module-dht11-dht22-and-am2302-sensors
      But I don’t want to run MagicMirror as Root with sudo.
      Bangee
      J 1 Reply Last reply Reply Quote 3
        MxBln
        Does it also work with the DHT-11?
          Jopyth Moderator @Bangee
          @Bangee Just me being confused: this needs sudo rights, doesn’t it? You just do not want to start the mirror with sudo?
            @MxBln I did not check this.
            @Jopyth yes, it needs a sudo command inside the app.
            • T
              trividar
              Hi guys
              I have some problems with this module. I test it with two DHT22 and I have always the same strange thing. Please look my short clip: [Youtube](video: https://youtu.be/gvuq6A13fw8). Sometimes it shows quickly the exact Temp and sometimes strange values but most of the time it shows undefined. I try to made a skipt outside of the MM and in this picture (link) you can see , at the same time my skript shows the right value but in MM its undefined.
              Can someone test this module or help me to find the fault? THX a lot for any help!
                What’s the result when you try this command directli in your terminal:
                go to cd MagicMirror/modules/MMM-DHT22/
                sudo ./dht_var 2
                Replace 2 with your sensor Pin
                I’ve tested this on two different Pi’s
                • T
                  trividar
                  @Bangee ok, now I’m confused ;o)
                  Bild Text
                  The first 5 lines I tried during my MM was working but nothing happend, i had to wait 2 minutes and it shows just a new comment line. After i stopped my MM it was working like a charm (last two lines). What I’m doing wrong?..
                    I don’t now atm :-)
                    it looks like something is blocking the dht_var script when your MM is running
                    Do you have error in your MM logs?
                    • T
                      trividar
                      I just checkt it and I don’t have any errors …;o(
                        I’ve tried this on an other pi and it works …
                        can you uncomment line 33 in node_helper.js to check if he tries to write something in to the logs?
                        	console.log("Log: " + temp + " - " + hum);
                        • T
                          trividar
                          THX @Bangee for your help. Now i got this error:
                          Error
                          • Y
                            yawns Moderator
                            Right. Please replace the word temp with arr[1] and hum with arr[0] in line 33 in node_helper.js
                            • T
                              trividar
                              Now my logs looks like this after I changed line 33:
                              Bild Text
                              • Y
                                yawns Moderator
                                Okay, so it definitely fails retrieving data from the sensor, but the error handling does not catch this failure.
                                • T
                                  trividar
                                  I have test it with two dht22. One was mine and one I received from @Bangee who was so kind to test it before sending it and it was working at his home, but when I tried it at my home it wasn’t working. So I have no Idea what can be the failure.
                                  • T
                                    trividar
                                    Hi ,
                                    so I just figure it out, that the motiondetector by alexyak blocking the DHT22 script. If I disable this module my DHT 22 works perfect. Somebody knows what make this problem?
                                      that’s very strange!?!
                                      Is this module working with a PIR Sensor or a Webcam?
                                      Im using Paviro’s PIR Sensor to turn on an off my monitor.
                                      • T
                                        trividar
                                        With picamera. I installed MM on my other pi (completely new installation) and i got the same problem after i installed the motion detector. So I disabled on my MM the motion detector and it works fine on both pi’s. It’s very strange ;o(
                                        • T
                                          trividar
                                          No one an idea?
                                            I am using a PIR sensor.
                                            So i can’t reproduce it.
