    Is there a way to temporarily disable a module?
    27 Posts 6 Posters 16.0k Views 6 Watching
    • T
      teitlebot @sdetweil
      @sdetweil how would I extend the module? I’m not really a coder but I can follow a guide.
        sdetweil @teitlebot
        @teitlebot you would have to add some code the check the current time against a stat/stop time you would add to the configuration.
          BigDanT
          Did anyone find a solution to this ?
          I’m looking to use a PIR so that if it detects motion it “Deactivates” the “MMM-PlexSlideshow” module.
          Then when it doesnt detect motion it will reactivate the “MMM-PlexSlideshow” module to create a digital picture frame when someone doesnt step in front of the mirror.
          Cheers
          D
            sdetweil @BigDanT
            @BigDanT i have not seen such a thing…
            also, most of the image displaying modules display in the background ‘under’ the other modules,
            you appear to want it ABOVE the other modules, hiding them… not seen any capable of doing that
              @BigDanT it might not be too hard…
              the PIR type modules send a notification 'USER_PRESENCE true/false when a user is detected or not
              so, if u can change the image handler module to position:‘foreground’, and add a tiny bit of code,
              in the notificationRecieved function add a handler for the user_presence message, if true, this.hide() (allow other module content to show thru)
              otherwise this.show() (hide everything behind)
                @BigDanT I tried moving MMM-ImagesPhotos to the fullscreen_above position, and it hides all the content behind, but… on each image transition it exposes the stuff behind… so it will be a bit more involved to make a module out front that does what u want.
                sorry, there was an intentional delay between pics… removing that keeps the stuff hidden behind, so it might work
                  RIKKO14
                  @teitlebot
                  I am not a coder but if you comment you config.js like this the module doen’t work :
                  	disabled: true,
                  	module: "MMM-KitchenTimer",
                  	position: "top_center",
                  		volume: 1
                  but
                  but this may not be the answer you want…
                    sdetweil @RIKKO14
                    @RIKKO14 said in Is there a way to temporarily disable a module?:
                    disabled: true,
                    you don’t need any comments if you have
                    disabled: true,
                    you can’t disable a module WHILE it is running… you could ‘hide’ it
                      RIKKO14
                      ok, sorry…
                        @BigDanT
                        by changing ImagesPhotos and my SleepWake, it does want u described… so it is possible
                        • wishmaster270W
                          wishmaster270 Module Developer
                          I use profiles to implement pages on my mirror. I also modified my screensaver module MMM-Screen-Powersave-Notification to change to a specific profile instead of hiding the modules or shut off the screen. So it should be possible to just configure the behavior you like instead of coding stuff.
                          Edit: Just saw that the code had been in the development branch and not in the master. Drafted a new release a few minutes ago.
                          The module also supports changing the timeout during runtime or disable screensave
                            BigDanT
                            Hi @sdetweil,
                            That’s not really what I mean, but thanks for the explanation/ investigation.
                            What I mean is this.
                            The MMM-Plexslideshow fills the back ground with an image rather than blank/black background.
                            This means the two way Perspex is not a mirror (as there’s an image rather than black background)
                            What I want to do is if the pir detects motion to deactivate the “mmm-plexslideshow” whilst the magic mirror is running. Or to select a black/blank background (which ever works)
                            That way when someone approaches the mirror the slideshow will stop and The mirror shown (due to the black background)
                            When the pir doesn’t detect someone then the slideshow starts up again.
                            I hope this makes more sense ??
                            Cheers
                            D
                              sdetweil @BigDanT
                              @BigDanT yes, and I said, (not using your modules) I did that exact thing with my camera based motion sensor module and a full screen image show module… to prove it would work…
                                BigDanT
                                Hi @sdetweil,
                                That’s great! Any chance you could point me in the direction of some instructions?
                                Cheers
                                D.
                                  sdetweil @BigDanT
                                  @BigDanT I had to change code in both modules…
                                  someone else @wishmaster270 says if you use THIS module, then you can configure what you want, no coding changes…
                                  https://forum.magicmirror.builders/topic/9986/is-there-a-way-to-temporarily-disable-a-module/18?page=2
                                  I don’t know anything about that module
                                    BigDanT
                                    @wishmaster270 this looks great !!!
                                    I’m going to start to tinker tonight with the PIR thats just arrived.
                                    I dont suppose you have an example config file you could share that shows how you set-up profiles across the other modules ??
                                    Cheers
                                    D.
                                    • wishmaster270W
                                      wishmaster270 Module Developer @BigDanT
                                      @BigDanT Hi, sorry but I don’t use the modules in exact this configuration so I do not have a config that contains all parts. But I included an example folder to my GPIO module which contains instructions of how to setup an PIR. Maybe it is a good start: examples
                                        BigDanT @wishmaster270
                                        @wishmaster270 Thanks for the link.
                                        Using your instructions ive gotten the PIR up and running using your example config’s.
                                        It would be ace to see how you have set-up profiles across a number of modules (doesnt matter which one) and how they are switched using MMM-Screen-Powersave-Notification ??
                                        I understand the principles but cant for the life of me find ANY examples of how this is set-up in the config file to experiment with.
                                        Any help/exmaples would be great ?
                                        D.
                                          BigDanT @BigDanT
                                          @wishmaster270
                                          I’ve had a crack at writing an example config file to show you what im trying to do:-
                                          I’ve taken out anything that is sensitive.
                                          In short i want it to show every module, unless the PIR detects motion then it will disable the “Digital-Pictureframe” profile.
                                          I assume if you use “classes” thats a profile ? and if it doesnt have a “classes” set then its considered default.
                                          var config = {
                                              address: '0.0.0.0',
                                              electronOptions: {},
                                              ipWhitelist: [],
                                                  //Screen on & off timer{
                                                      module: 'MMM-ModuleScheduler',
                                                          notification_schedule: [
                                                              // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
        notification: 'REMOTE_ACTION',
        schedule: '00 07 * * *',
        payload: {
        action: "MONITORON"
                                                              // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY DAY
        schedule: '30 22 * * *',
        payload: {
        action: "MONITOROFF"
                                                      module: 'alert',
                                                      config: {}
                                                      module: 'updatenotification',
                                                      position: 'top_bar',
                                                          ignoreModules: []
                                                      module: 'clock',
                                                      position: 'top_left',
                                                      config: {}
                                                  // top Right Calenar
                                                      module: 'calendar',
                                                      header: 'Family Calendar',
                                                          calendars: [{
        symbol: 'calendar-check',
        url: 'https://calendar.google.com/calendar/ical/xxx.ics',
                                                  // Weather Section
                                                      module: 'currentweather',
                                                      position: 'top_right',
                                                          locationID: 'xxx',
                                                          appid: 'xxx',
                                                      module: 'weatherforecast',
                                                      header: 'Weather Forecast',
                                                          locationID: 'xxx',
                                                          appid: 'xxx',
                                                  //Screencast
                                                      module: 'MMM-Screencast',
                                                      position: 'bottom_right',
                                                          position: 'center',
                                                          height: 600,
                                                          width: 800,
                                                          castName: 'MagicMirror',
                                                  //PLex Slideshow
                                                      module: 'MMM-PlexSlideshow',
                                                      classes: 'Digital-Pictureframe',
                                                      position: 'fullscreen_below',
                                                          plex: {
                                                              hostname: '192.168.1.123',
                                                              port: 32400,
                                                              username: 'xxx@xxx.com',
                                                              password: 'password',
                                                          transitionImages: true,
                                                  //MM Remote Control
                                                      module: 'MMM-Remote-Control',
                                                      header: '',
                                                          customCommand: {},
                                                          customMenu: 'custom_menu.json',
                                                          showModuleApiMenu: true,
                                                          apiKey: ''
                                                  //News Headlines
                                                  module: 'newsfeed',
                                                  header: '',
                                                  feeds: [{
                                                  title: 'BBC News',
                                                  url: 'http://feeds.bbci.co.uk/news/rss.xml'
                                                  startTags: [],
                                                  endTags: [],
                                                  prohibitedWords: []
                                                      module: 'MMM-GPIO-Notifications',
                                                          '4': {
                                                              gpio_state: 1,
                                                              gpio_debounce: 0,
                                                              delay: 30000,
                                                              notifications: [{
        notification: 'SCREEN_ON',
        payload: {
        'forced': false
                                                      module: 'MMM-Screen-Powersave-Notification',
                                                          delay: 60,
                                                          profiles: {
                                                              "Digital-Pictureframe": 600
                                                      module: 'MMM-ViewNotifications',
                                                      position: 'bottom_left',
                                                      header: 'Notifications',
                                                          timeout: 0,
                                                          format: '{time}: "{module}" sent "{notification}" with {payloadData}', // See below for configurable options
                                                          includeModules: ["MMM-GPIO-Notifications", "MMM-Screen-Powersave-Notification"]
                                          if (typeof module !== 'undefined') {
                                              module.exports = config;
                                          I just need to understand how to add a module to a profile and then using your example PIR code how to transition from one profile to another
                                          • wishmaster270W
                                            @BigDanT
                                            you need another module to get it work: MMM-ProfileSwitcher
                                            The idea is to define a “normal” class to which all modules do belong that will be displayed if motion is detected. The Slideshow will be in class “slideshow”.
                                            The Screensave module is configured to not shutoff the monitor but change to the “slideshow” profile.
                                            If SCREEN_ON is triggered the Screensave module will change back to the profile that was used before the screensave (in our case “nomal”).
                                            I updated the config example to do the job (but i could not test it at the moment):
                                            var config = {
                                                address: '0.0.0.0',
                                                ipWhitelist: [],
        payload: {
        'forced': true
        notification: 'SCREEN_OFF',
        payload: {
        'forced': true
                                                        module: 'alert',
                                                        config: {},
                                                        classes: 'normal'
                                                            ignoreModules: []
                                                        classes: 'normal'
                                                        module: 'clock',
                                                        config: {},
                                                        classes: 'normal'
                                                        module: 'calendar',
                                                            calendars: [{
                                                        classes: 'normal'
                                                    // Weather Section
                                                            locationID: 'xxx',
                                                            appid: 'xxx',
                                                        classes: 'normal'
                                                            locationID: 'xxx',
                                                            appid: 'xxx',
                                                        classes: 'normal'
                                                    //Screencast
                                                            position: 'center',
                                                            height: 600,
                                                            width: 800,
                                                        classes: 'normal'
                                                    //PLex Slideshow
                                                        position: 'fullscreen_above',
                                                            plex: {
        port: 32400,
                                                        classes: 'slideshow'
                                                    //MM Remote Control
                                                        header: '',
                                                            customCommand: {},
                                                            apiKey: ''
                                                    //News Headlines
                                                        module: 'newsfeed',
                                                        header: '',
                                                            feeds: [
        title: 'BBC News',
                                                            startTags: [],
                                                            endTags: [],
                                                            prohibitedWords: []
                                                        classes: 'normal'
                                                            '4': {
        gpio_state: 1,
        gpio_debounce: 0,
        delay: 30000,
        notifications: [{
        payload: {
        'forced': false
                                                            delay: 60,
                                                            hideInsteadShutoff: true, //do not shutoff the screen
                                                            changeToProfile: "slideshow" //change to this profile instead of hiding the modules
                                                            timeout: 0,
                                                        classes: 'normal'
                                                        //https://github.com/tosti007/MMM-ProfileSwitcher
                                            			module: "MMM-ProfileSwitcher",
                                            				defaultClass: "normal",
                                            				ignoreModules: [
        "MMM-ModuleScheduler",
        "MMM-Remote-Control",
                                            • S sletrabf referenced this topic on
