    Save performance when rotating screen e.g. on Raspberry Pi
    Scheduled Pinned Locked Moved Showcase
    19 Posts 11 Posters 31.6k Views 14 Watching
    • evroomE Offline
      evroom
      Okay, found it.
      In my /boot/config.txt I had the width and height set to 900 and 1600 and this has to be now 1600 and 900.
      This is working:
      display_hdmi_rotate=0
      framebuffer_width=1600
      framebuffer_height=900
      Works now.
      Only need to modify the omxplayer lines to have those streams rotated too.
      MagicMirror version: 2.37.0
      • T Offline
        thedk
        Didnt work that easy for me.
        1. You have to take the resolution of your display/monitor in the config.txt, not just 1600,900.
        2. I had to enable overscan, cause the picture was to big.
        3. If you’re using the MMM-Remote_Control the picture is rotated when you have a look at your MagicMirror.
        I switched back to the fake KMS driver.
          Great hack!! I’m going to add this to my CSS 101 guide if that’s OK. I think this is incredibly useful.
            ptrk95 Module Developer @j.e.f.f
            @j-e-f-f thank you! Of course you can :)
              Joern
              Iam struggeling on my PI3 to rotate by 90deg to right. Monitor has 1920x1080.
              But I see only black screen at any other position than -90deg!!
              As I need to change to 90deg or -270deg I got only black screen (also 180deg even) …
              So I changed config.txt to:
              framebuffer_width=1920
              framebuffer_height=1080
              & custom.css to:
              body {
                      margin: 0;
                      position: absolute;
                      transform: rotate(90deg);
                      transform-origin: top left;
                      width: 100vh;
                      height: 100vw;
                      object-fit: cover;
                      top: 100vh;
                      visibility: visible;
              What is missing?
              Worse case I change physical mounting way, but not preferred :face_with_stuck-out_tongue_winking_eye:
                Joern
                transform-origin: top right;
                works at least see have screen, but only half screen is used, so no option…
                • H Offline
                  hdez
                  Warning! Extreme newbie here. This is only my second day playing with Magic Mirror css.
                  I changed my css file and boot/config.txt following @evroom’s instructions above and although I was able to rotate the screen with these instructions, like @Joern, the Magic Mirror modules only fill the bottom half of the screen.
                  My CSS file is as follows (sorry, I don’t know how to put this in a separate box):
                  body {
                  margin: 0px; If I omit “px”, Magic Mirror does not display correctly.
                  position: absolute;
                  width: 100vh;
                  height: 100vh; If I change this to “100vw”, Magic Mirror does not display correctly.
                  object-fit: cover;
                  top: 100vh;
                  background: #000;
                  color: #aaa;
                  font-family: “Roboto Condensed”, san-serif;
                  font-weight: 400;
                  font-size: 2em;
                  line-height: 1.5em;
                  -webkit-font-smoothing: antialiased;
                  .MMM-HTMLBox {
                  font-size: 18px;
                  line-height: 22px;
                  .MMM-RTSPStream header {
                  text-align: left;
                  .MMM-RTSPStream .innerWrapper {
                  border-style: none;
                  …a few more entries after these ones.
                  My boot/config.txt contains the following entry:
                  Any entries shown here that were not included in @evroom’s instructions, are from the original installation of Magic Mirror.
                  I’m running Magic Mirror latest software on a Pi4 with an Acer 24" monitor.
                  Any ideas as to what I should change in order for the modules to fill the entire screen?
                  Any help will be greatly appreciated.
                    sdetweil @hdez
                    @hdez said in Save performance when rotating screen e.g. on Raspberry Pi:
                    after you paste the text, select it, and then push the button above the editor that looks like </>
                    • H Offline
                      hdez @sdetweil
                      @sdetweil Thanks. Next time.
                      • H Offline
                        hdez
                        Never mind guys I was able to get it to work by following the instructions here
                        After all it wasn’t the css file that I needed to change, but the Pi autostart file in the /etc/xdg/lxsession/LXDE-pi/ folder.
                        • G Offline
                          Goeste
                          Thank you @ptrk95, that just came in handy while playing around with fullpageos and the magic mirror in my docker setup!
                          • F Offline
                            floydrexdime
                            Hi there! thanks for the easy fix! Is there a way to reposition the modules on the mirror? when I rotate the screen 90 degrees the bottom module (the newsfeed) its completely cut out.
