    Help for a newbie
    6 Posts 3 Posters 1.3k Views 3 Watching
    • T Offline
      trix2k
      Hello all
      I am very new to all of this but I am still learning. I have ran into a little snag I do not know what I did or how to fix it.
      I have been slowly programming my Pi device and everything has been going good, until I turned it on yesterday and everything looked a little crazy. The last thing I did is at the module for my horoscope, and everything seem to be fine. I rebooted the device many times and it was still working. When I came back Sunday and turned everything on that’s when things started to get strange. It looks Like the resolution is off but I do not know how to fix it any help would be greatly appreciated
      ![0_1607470651029_after.jpg](Uploading 100%)
      for some reason i can not upload the second picture showing the problem, but everyting is overlapping on top of each other
      • T Offline
        trix2k
          I would disable the Horoscope module to see if things go back to normal. You don’t have to delete anything. Simply add disabled: true, to the config entry for the horoscope module. Save and run MM and see what happens.
          EXAMPLE:
              disabled: true,
              module: "MMM-YourHoroscopeModule",
              position: "top_center",
                  maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                  style: '1',            // Style number or use ownImagePath to override style
                 ownImagePath: '',
          • T Offline
            trix2k @Mykle1
            @Mykle1 thanks for the suggestion. but it was a no go still. i should point out also but its not just the MM that seams like its over lapping and just large its also the deskop
            • lavolp3L Offline
              lavolp3 Module Developer
              you’re looking at a vnc viewer here. I think (!) they create their own resolution. Is the mirror itself behaving the same?
              Have you adjusted resolution of the desktop?
              Menu (raspberry icon top left)-> Preferences -> Screen Configuration
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • T Offline
                trix2k @lavolp3
                @lavolp3 yes the mirror is the same. I did check that and it’s set for 1024x768
