    MMM-News
    55 Posts 15 Posters 58.4k Views 14 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      @Bugsounet still getting the same error in the logs and news not displaying because of it. Below is my config. Any ideas?
        		module: "MMM-News",
        		position: "bottom_bar",
          		apiKey : "XXXXXXXXX",
          		type: "horizontal",
          		query : [
              	sources: "fox-news, fox-sports",
              country: "us",
              className: "redTitle",
      	touchable: false,
      	scanInterval: 1000*60*15
        Not sure what it means but says initialized with 10 query
        /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
        1|MagicMir | [2020-11-22 18:00:23.595] [LOG]    MMM-PGA Retrieving Tounament List
        1|MagicMir | [2020-11-22 18:00:24.198] [LOG]    MMM-PGA retrieving Tournament Data
        1|MagicMir | [2020-11-22 18:05:22.126] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
        1|MagicMir | [2020-11-22 18:05:22.134] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
        1|MagicMir | [2020-11-22 18:05:22.391] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
        1|MagicMir | [2020-11-22 18:05:24.044] [LOG]    MMM-PGA retrieving Tournament Data
        1|MagicMir | [2020-11-22 18:05:24.437] [LOG]    MMM-PGA Retrieving Tounament List
        1|MagicMir | [2020-11-22 18:07:49.476] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
        1|MagicMir | [2020-11-22 18:07:49.477] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
        1|MagicMir | [2020-11-22 18:07:49.481] [LOG]    MMM-PGA config received
        1|MagicMir | [2020-11-22 18:07:49.485] [LOG]    [NEWS] MMM-News Version: 2.1.2
        1|MagicMir | [2020-11-22 18:07:49.486] [LOG]    [NEWS] Initialized with 10 query
        1|MagicMir | [2020-11-22 18:07:49.720] [LOG]    MMM-PGA Retrieving Tounament List
        1|MagicMir | [2020-11-22 18:07:49.804] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
        1|MagicMir | [2020-11-22 18:07:50.969] [LOG]    MMM-PGA retrieving Tournament Data
          A Former User
          limited to 100 query by day and 50 query for 12 hours
          It’s not me who have set this limit but it’s news api
          and sorry, i don’t work in news api too ! :)
          so now just a little calc…
          you have 10 query and refresh is set to 15m
          for one query for one hour (every 15min) => 4 query
          for 10 query for one hour (every 15 min) => 4*10 = 40 query
          in 12 hours with one query => 12 * 4 = 48 query / 50 max
          in 12 hours with 10 query => 12* 40 = 480 query / 50 max
          in 24 hours with one query => 24 * 4 => 96 query / 100 Max
          in 24 hours with 10 query => 24*40 => 960 query / 100 max
          That why you have this error… and I just calc the number of query
          –> result: it take 9 query (take a lot of resource)
             country: "us",
          –> result: it take just one query
          Note: personnaly, i use only redTitle of my country
          Note 2: i will add soon a counter for calc if number of query is correct
            @Bugsounet Ok thanks for the detailed explanation. Here is my config now so hopefully this should resolve it.
              		module: "MMM-News",
                		apiKey : "XXXXXXXXXXXXXXXXXXX",
                		type: "horizontal",
                		query : [
                    country: "us",
            	touchable: false,
            	scanInterval: 1000*60*30
              A Former User
              perfect, it should work perfectly now
                Oddly the sizing of the module just randomly changed and got smaller. How do I make the entire module bigger to fill out the bottom_bar? I went into CSS but nothing I did seem to change anything.
                  I added this to custom css but just doesn’t look right. What could have changed the sizing as nothing was updated from the default install? I uninstalled and re-installed and same thing.
                  body  {
                  transform:scale(1.0);
                  .MMM-News {
                  transform:scale(1,1.75);
                    A Former User
                    “Oddly”, i have not touch to the css code
                    and “Oddly” i don’t touche the main code
                    and “Oddly” I run this module in 3 differents RPI
                    and “Oddly” … this is no problem !
                    so try to disable all module one by one (except this modules), disable custom.css too
                    and “Oddly”, you will see : it works…
                    swvalentiS 1 Reply Last reply Reply Quote -1
                      swvalenti Project Sponsor @Guest
                      @Bugsounet said in MMM-News:
                      You need a snickers bar or something? Take it down a notch keyboard warrior
                      cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 1
                        A Former User
                        bad topic response sorry
                        • cowboysdudeC Offline
                          cowboysdude Module Developer @swvalenti
                          @swvalenti LOL
                            Mykle1 Project Sponsor Module Developer @swvalenti
                            @swvalenti said in MMM-News:
                            Bro, fucking hilarious! :thumbsup:
                            • MorgangaM Offline
                              Morganga
                              Kinda new to this,
                              I have no clue how to install this module ??
                              Could someone please help, I kinda like it
                              Thank you !
                                @Morganga it is all laid out for ya below
                                https://github.com/bugsounet/MMM-News
                                MorgangaM 1 Reply Last reply Reply Quote 1
                                • MorgangaM Offline
                                  Morganga @swvalenti
                                  @swvalenti Thank you very much ! Works just fine
                                  • K Offline
                                    KillK
                                    Hi everyone, newby here… first of all, MMM-news is great, thanks for make it… i am building a MM for my GF Bday.
                                    i want to know 2 things, it is possible to add QR to MMM-news? and anyone knows if there is any API about lifestyle and fashion?
                                      DJBOOB66 @KillK
                                      @killk MMM-NewsFeed it has QR
                                      • K Offline
                                        KillK @DJBOOB66
                                        @djboob66 i have try it, but isn`t possible on windows
                                        swvalentiS 1 Reply Last reply Reply Quote 0
                                          swvalenti Project Sponsor @KillK
                                          Images stopped working the other day. I don’t see anything in the logs or dev window. Any thoughts?
                                            swvalenti Project Sponsor @swvalenti
                                            Seems like the module might not be maintained anymore by developer but seems like they’re several active contributors. How do I fix the image issue when I don’t see much in the logs? Willing to learn and fix this as there are not really any news options for the MM anymore. Thanks, Scott
                                            • 3 / 3
