    MMM-Parcel
    24 Posts 11 Posters 16.6k Views 12 Watching
      martinkooij @twosquirrels
      @twosquirrels Basically the most radical way is to remove everything MMM-Parcel from both …/config and from …/modules and make a clean install with clone. I sent you a PM, let me know if it works for you.
      twosquirrelsT 1 Reply Last reply
      • twosquirrelsT
        twosquirrels @martinkooij
        @martinkooij
        I installed the update and used the new module code. It worked, although the “hideDelivered” doesn’t seem to be working. I have it set for “3” and as of April 5, I still have a March 28 delivery showing as delivered.
          hideDelivered: 3, // Hide delivered parcels after 15 days.
        M 1 Reply Last reply
          @twosquirrels Hi. I am sorry it doesn’t work for you. I must have missed a date format from aftership I think, because on my parcels upto now it works like a charm. If you can help me debug, can you please send me (via my personal mail, I sent you a PM) the console output after putting debug: true in the module config. This spits out a lot of info into the console output / log files.
          luisestradaL 1 Reply Last reply
            Mike111111
            This site is not bad for tracking parcels. The site can be viewed at https://parceltrackingapp.com/en.
            • luisestradaL
              luisestrada @martinkooij
              @martinkooij said in MMM-Parcel:
              onsole outpu
              did you guys come up with a solution? I get that “Loading Parcel Module” and even when I delete and redo anything, it doesn’t work
              J 1 Reply Last reply
                JohnBachini @luisestrada
                @luisestrada
                it works for me. But sure for how much longer as had email from them saying they are making some changes to there API. So that may well break it.
                B 1 Reply Last reply
                  bhepler Module Developer @JohnBachini
                  @JohnBachini - As a developer, you can probably ask them for a preview of their upcoming API changes. They may be running it on a test server somewhere that you can hit and work out the necessary modifications to your code.
                  • luisestradaL
                    luisestrada
                    This is my error message
                    [ERROR]  TypeError: aftershipSDK is not a constructor
                        at Class.fetchShipments (/home/pi/MagicMirror/modules/MMM-Parcel/node_helper.js:91:22)
                        at Class.startUpdateNext (/home/pi/MagicMirror/modules/MMM-Parcel/node_helper.js:126:8)
                        at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Parcel/node_helper.js:116:9)
                        at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:113:11)
                        at Socket.emit (events.js:200:13)
                        at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                        at processTicksAndRejections (internal/process/task_queues.js:82:9)
                      PH1TCH
                      Are there any news on this topic? Unfortunately I can’t get it to work either …
                        BlackZero
                        I have installed the module today and somehow the Module just says “Loading Parcel module…” for quite a while and nothing will happen… is there any solution for this?
                        Thank you very much :)
                          BlackZero
                          I found a solution for this on the issues tab on GitHub of MMM-Parcel.
                          But now I have the text stated “No Shipment Data” although I have some shipments listed on AfterShip.
                          Has anyone an idea for a solution of this problem?
                          G 1 Reply Last reply
                          • G
                            gtodd @BlackZero
                            @BlackZero I have spoken to AfterShip’s support and they verified that they no longer offer API keys for end-user accounts. You would have to have a merchant account, which does not support importing from amazon and gmail and all those nice features.
                            So, basically, this module is dead. :(
