    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 243.5k Views 39 Watching
      sdetweil @popeye2002
      @popeye2002 something is messed up…
      I suggest you erase the MMM-Jast folder and git clone again
      do
      cd ~/MagicMirror/modules
      rm -rf MMM-Jast
      git clone https://github.com/jalibu/MMM-Jast.git
      cd MMM-Jast
      npm install
      then restart mm
      pm2 restart 0
      popeye2002P 2 Replies Last reply Reply Quote 0
      • popeye2002P
        popeye2002 @sdetweil
        @sdetweil much much better!!!
        and now I do see the errors for to many calls
        0|MagicMirror  | [2020-04-28 11:05:25.153] [ERROR]
        0|MagicMirror  | Error processing Stock response {
        0|MagicMirror  |   Note: 'Thank you for using Alpha Vantage! Our standard API call frequency is 5 ' +
        0|MagicMirror  |     'calls per minute and 500 calls per day. Please visit ' +
        0|MagicMirror  |     'https://www.alphavantage.co/premium/ if you would like to target a higher ' +
        0|MagicMirror  |     'API call frequency.'
        0|MagicMirror  | }
        0|MagicMirror  | [2020-04-28 11:05:25.167] [ERROR]
        0|MagicMirror  | }
        0|MagicMirror  | [2020-04-28 11:05:25.460] [LOG]
        0|MagicMirror  | Sending Stock result: { symbol: 'SBUX', current: 77.74, last: 75.58 }
        0|MagicMirror  | [2020-04-28 11:05:25.482] [LOG]
        0|MagicMirror  | Sending Stock result: { symbol: 'MSFT', current: 174.05, last: 174.55 }
        0|MagicMirror  | [2020-04-28 11:05:25.555] [LOG]
        0|MagicMirror  | Sending Stock result: { symbol: 'JD', current: 45.58, last: 45.05 }
        0|MagicMirror  | [2020-04-28 11:05:25.649] [LOG]
        0|MagicMirror  | Sending Stock result: { symbol: 'VZ', current: 58.22, last: 57.81 }
        0|MagicMirror  | [2020-04-28 11:05:25.683] [LOG]
        0|MagicMirror  | Sending Stock result: { symbol: 'PFE', current: 38.1199, last: 38.33 }
        0|MagicMirror  | [2020-04-28 11:05:28.263] [ERROR]
        • popeye2002P
          Can’t thank you enough!!!
          You really made my day a whole lot better! no idea how I may pass it along but you can belive i will pass it forward one way or another.
          Cheers
          Scott
            @popeye2002 cool, thats the idea around here… we all work together
            • W
              wilbur245
              Hello I have installed Jast, everything is fine.
              I just don’t see a share.
              Biontech
              FRA: 22UA
              there is zero also 22UA.DE does not work.
              how can i “https://www.stockdio.com/”
              insert as API?
              JalibuJ 1 Reply Last reply Reply Quote 0
                MisterTFM
                What “symbol” should I use for the Dow Jones Industrial Average? I tried DJI and .DJI
                  RIKKO14
                  does this module work for french stocks on euronext ?
                  • W
                    wilbur245
                    Hello, what do I have to do so that the values ​​are shown up to date to some extent. It is currently only queried once a day or the value renewed.
                    I sometimes have values ​​for 2 days even though they have fallen or increased
                      DJ6sTep @Jalibu
                      @Jalibu Is there a way to have the ticker scroll all the way across the screen? Mine gets about 85% across the screen, doesn’t show all the stocks, just 4 stocks & then restarts from the beginning again.
                        DJ6sTep @DJ6sTep
                        @Jalibu also, how can I increase the font size?
                        • JalibuJ
                          Jalibu Module Developer @MisterTFM
                          @MisterTFM said in [MMM-JaST] Just another Stock Ticker:
                          Hi @MisterTFM,
                          as you can read here, the Alphavantage API does not provide stock indices. You could try using “DIA”.
                          @RIKKO14 said in [MMM-JaST] Just another Stock Ticker:
                          HI @RIKKO14,
                          the question should better be “does the Alphavantage API work with french stocks on euronext”. To be honest: I just don’t know :-)
                          I just googled that list of Symbols for Alphavantage: https://github.com/prediqtiv/alpha-vantage-cookbook/blob/master/symbol-lists.md
                          You can easily test your Symbols by pasting this url in your browser and change the symbol value on its end:
                          https://www.alphavantage.co/query?function=TIME_SERIES_INTRADAY&interval=5min&apikey=3JJ4NFIVSE57V6NB&symbol=YOUR_SYMBOL_HERE
                          If you get a response like this, your symbol is valid and offered by the API:
                          Meta Data: {
                            Information: "Daily Prices (open, high, low, close) and Volumes",
                            Symbol: "BAS.DE",
                            Last Refreshed: "2021-01-05",
                            Output Size: "Compact",
                            Time Zone: "US/Eastern"
                          Time Series (Daily): {
                           2021-01-05: {
                            open: "64.3000",
                            high: "65.4700",
                            low: "63.2600",
                            close: "64.4000",
                            volume: "2770107"
                          @wilbur245 said in [MMM-JaST] Just another Stock Ticker:
                          Hi @wilbur245 ,
                          the module always requests the latest values from the Alphavantage API. If they are not up to date, I’m afraid there is nothing we can do ¯\(ツ)/¯
                          The update interval between the MMM-Jast module and the Alphavantage API can be configured
                          config{
                            updateIntervalInSeconds: 1800
                          @DJ6sTep said in [MMM-JaST] Just another Stock Ticker:
                          Hi @DJ6sTep , perhaps that’s a bug. I’ll have a look on that.
                          By modifying the modules/MMM-Jast/MMM-Jast.css
                          • JalibuJ
                            Jalibu Module Developer @wilbur245
                            Biontech
                            FRA: 22UA
                            insert as API?
                            I just checked the stockdio API. It is great, but unfortunately its free plan is limited to 500 requests per month.
                              DJ6sTep @Jalibu
                              @Jalibu Thank you, editing the .css file did the trick. Please let me know when you’ve had a chance to investigate this bug. This module is exactly what I was looking for man, just need to to scroll all the way across & display all my stocks :) Appreciate your work.
                              • JalibuJ
                                I have refactored this module from scratch. It now should also support DepotGrowth calculation in currencies other than EUR. A few internal and UI bugs were also fixed.
                                Please let me know if you are facing any issues with the latest version.
                                • K
                                  Koert 0 @Jalibu
                                  @jalibu I’m facing some problems with displaying the correct value of my stocks.
                                  module: "MMM-Jast",
                                  position: "fullscreen_above",
                                  maxWidth: "100%",
                                  updateIntervalInSeconds: 0,
                                  fadeSpeedInSeconds: 90.5,
                                  scroll: "horizontal",
                                  defaultCurrency: "EUR",
                                  showDepotGrowth: false,
                                  apiKey: "MY API KEY",
                                  stocks: [
                                  	{ name: "Porsche", symbol: "PAH3.DE" },
                                  	{ name: "STS", symbol: "SF3.DE"},
                                  	{ name: "Haier", symbol: "690D.DE" },
                                  	{ name: "Siemens Energy", symbol: "ENR.DE" },
                                  	{ name: "TUI", symbol: "TUI1.DE" },
                                  	{ name: "HochTief", symbol: "HOT.DE" },
                                  	{ name: "Siemens", symbol: "SIE.DE" },
                                  	{ name: "Allianz", symbol: "ALV.DE" },
                                  Problem 1: The ticker is showing me Values. But also a value for BTC (which isn’t mentioned in the code?!?!)
                                  Problem 2: Values from the stock list are old Values from the beginning of the Day (or maybe last value of the day before)
                                  maybe a Log can help you:
                                  0|mm       | [25.03.2021 16:08.16.922] [LOG]   Sending Stock result: { symbol: 'PAH3.DE', current: 84.68, last: 87.42 }
                                  0|mm       | [25.03.2021 16:08.16.936] [LOG]   Sending Stock result: { symbol: '690D.DE', current: 1.832, last: 1.9368 }
                                  0|mm       | [25.03.2021 16:08.16.971] [LOG]   Sending Stock result: { symbol: 'TUI1.DE', current: 4.396, last: 4.133 }
                                  0|mm       | [25.03.2021 16:09.18.891] [LOG]   Sending Stock result: { symbol: 'HOT.DE', current: 73.35, last: 73 }
                                  0|mm       | [25.03.2021 16:09.18.913] [LOG]   Sending Stock result: { symbol: 'SIE.DE', current: 135.56, last: 135.98 }
                                  0|mm       | [25.03.2021 16:09.18.974] [LOG]   Sending Stock result: { symbol: 'ALV.DE', current: 212.55, last: 211.45 }
                                  0|mm       | [25.03.2021 16:09.19.845] [LOG]   Sending Crypto result: { symbol: 'BTC', current: 52417.17, last: 52303.65 }
                                  0|mm       |
                                  0|mm       | > magicmirror@2.14.0 start /home/pi/MagicMirror
                                  0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                  0|mm       |
                                  0|mm       | [25.03.2021 16:26.45.698] [LOG]   Starting MagicMirror: v2.14.0
                                  0|mm       | [25.03.2021 16:26.45.712] [LOG]   Loading config ...
                                  0|mm       | [25.03.2021 16:26.45.733] [LOG]   Loading module helpers ...
                                  0|mm       | [25.03.2021 16:26.46.100] [LOG]   Initializing new module helper ...
                                  0|mm       | [25.03.2021 16:26.46.105] [LOG]   Module helper loaded: updatenotification
                                  0|mm       | [25.03.2021 16:26.46.111] [LOG]   No helper found for module: helloworld.
                                  0|mm       | [25.03.2021 16:26.46.112] [LOG]   All module helpers loaded.
                                  0|mm       | [25.03.2021 16:26.46.305] [LOG]   Starting server on port 8080 ...
                                  0|mm       | [25.03.2021 16:26.46.329] [LOG]   Server started ...
                                  0|mm       | [25.03.2021 16:26.46.331] [LOG]   Connecting socket for: updatenotification
                                  0|mm       | [25.03.2021 16:26.46.332] [LOG]   Sockets connected & modules started ...
                                  0|mm       | [25.03.2021 16:26.46.743] [LOG]   Launching application.
                                  0|mm       |
                                  0|mm       |
                                  0|mm       | [25.03.2021 16:27.41.491] [LOG]   Starting MagicMirror: v2.14.0
                                  0|mm       | [25.03.2021 16:27.41.506] [LOG]   Loading config ...
                                  0|mm       | [25.03.2021 16:27.41.519] [LOG]   Loading module helpers ...
                                  0|mm       | [25.03.2021 16:27.41.524] [LOG]   No helper found for module: clock.
                                  0|mm       | [25.03.2021 16:27.42.080] [LOG]   Initializing new module helper ...
                                  0|mm       | [25.03.2021 16:27.42.082] [LOG]   Module helper loaded: MMM-Jast
                                  0|mm       | [25.03.2021 16:27.42.084] [LOG]   All module helpers loaded.
                                  0|mm       | [25.03.2021 16:27.42.238] [LOG]   Starting server on port 8080 ...
                                  0|mm       | [25.03.2021 16:27.42.269] [LOG]   Server started ...
                                  0|mm       | [25.03.2021 16:27.42.271] [LOG]   Connecting socket for: MMM-Jast
                                  0|mm       | [25.03.2021 16:27.42.273] [LOG]   MMM-Jast helper method started...
                                  0|mm       | [25.03.2021 16:27.42.274] [LOG]   Sockets connected & modules started ...
                                  0|mm       | [25.03.2021 16:27.42.755] [LOG]   Launching application.
                                  0|mm       | [25.03.2021 16:27.47.791] [LOG]   Sending Stock result: { symbol: 'ALV.DE', current: 212.55, last: 211.45 }
                                  0|mm       | [25.03.2021 16:27.47.868] [LOG]   Sending Stock result: { symbol: 'SF3.DE', current: 7.88, last: 7.68 }
                                  0|mm       | [25.03.2021 16:27.47.890] [LOG]   Sending Stock result: { symbol: 'ENR.DE', current: 29.38, last: 30.03 }
                                  0|mm       | [25.03.2021 16:27.47.916] [LOG]   Sending Stock result: { symbol: '690D.DE', current: 1.832, last: 1.9368 }
                                  0|mm       | [25.03.2021 16:27.47.960] [LOG]   Sending Stock result: { symbol: 'PAH3.DE', current: 84.68, last: 87.42 }
                                  For Example Porsche received the same value twice
                                  Greetings from BW to RP ;)
                                  • JalibuJ
                                    Jalibu Module Developer @Koert 0
                                    Hi @koert-0 ,
                                    thank you for your message.
                                    Problem 1:
                                    There was a hidden sample crypto entry in the default settings. I removed that and improved the Readme, to avoid this confusion in the future.
                                    Problem 2:
                                    The problem for this is more likely to be found with the data provider than with the module.
                                    The module displays what it gets. If the values are not up to date, then unfortunately I can’t influence that.
                                    In general, I am rather dissatisfied with Alphavantage. Unfortunately, I don’t know a free alternative. I am open for suggestions.
                                    • JalibuJ
                                      I refactored this module again to use Yahoo’s financial API instead of Alphavantage and need some voluntary testers.
                                      It should now support many more Symbols and be more accurate and much simpler.
                                      Please check out this Feature Branch:
                                      https://github.com/jalibu/MMM-Jast/tree/feat/useYahoo
                                        BravoOscar @Jalibu
                                        @jalibu
                                        I will test it later today, but I need to know of this is this a upgrade or is it a new install.
                                        I use the originale MMM-JaST, should this be removed before a new install?
                                        • JalibuJ
                                          Jalibu Module Developer @BravoOscar
                                          @bravooscar
                                          Well, the word “install” is fuzzy…
                                          You don’t need to uninstall your old one and even your configuration is compatible.
                                          You can switch between them by just changing the branch.
                                          In your modules/MMM-Jast folder execute
                                          Switch to Yahoo test branch:
                                          git fetch
                                          git checkout feat/useYahoo
                                          npm i
                                          Switch back to stable master:
                                          git checkout master
                                            BravoOscar @Jalibu
                                            @jalibu
                                            pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ git fetch
                                            From https://github.com/jalibu/MMM-Jast
                                               1cd91dc..c18758f  master        -> origin/master
                                             * [new branch]      feat/useYahoo -> origin/feat/useYahoo
                                             * [new tag]         v1.1.0        -> v1.1.0
                                             * [new tag]         v1.2.0        -> v1.2.0
                                            pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ git checkout feat/useYahoo
                                            error: Your local changes to the following files would be overwritten by checkout:
                                            	MMM-Jast.css
                                            	MMM-Jast.js
                                            Please commit your changes or stash them before you switch branches.
                                            Aborting
                                            pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ npm i
                                            > magicmirror@2.14.0 install /home/pi/MagicMirror
                                            " && cd vendor && npm install --loglevel=error
                                            audited 24 packages in 1.694s
                                            It looks like there is a error when using “git checkout feat/useYahoo”.
                                            Now the alert message on MM says there is a update for MMM-Jast
                                            • 2 / 9
