    Can"t get wind speed shown in KMPH why?
    9 Posts 6 Posters 2.4k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @carlderdritte
      @carlderdritte said in Can"t get wind speed shown in KMPH why?:
      Remove the quotes from true
       useKMPHWind: true,
       roundTemp: true,
       showRainAmount: true,
       degreeLabel: true
        carlderdritte @Mykle1
        @mykle1 no changes without the quotes :(
        • T Offline
          thisistheplace
          Sry, if this thread is too old to answer but I had the same question and had problems to find a solution for this. But it seems like I have one.
          In my config I only set useKMPHwind to true and that didn’t work but after I also changed the useBeaufort from its default true value to false it seems to work.
          At this moment openweathermap shows 1,5m/s and magicmirror shows 5 as windspeed. 1,5m/s are actually 5,4km/h so I think its an rounded value.
            MajorC Project Sponsor
            I’ll have to dig up this old thread again. I too do not get the wind speed displayed in km/h.
            My config says:
            			module: "currentweather",
            				locationID: "2950159", //Location ID from http://bulk.openweathermap.org/sample/city.list.json.gz
            				appid: "***MYKEY***", //openweathermap.org API key.
            				useBeaufort: false,
            				useKMPHWind: true
            • thgmirrorT Offline
              thgmirror
              Hi @MajorC,
              without using this module, I saw you wrote
              seBeaufort: false, instead of
              useBeaufort: false,
              May be that is the reason.
              Greetings from Bonn
              Thomas
                Thank you, this was just a copy & paste error. On the MM I have use with a u.
                @carlderdritte or @thisistheplace have you guys found a solution?
                  MaXi-XCeL Project Sponsor
                  Re: Can"t get wind speed shown in KMPH why?
                  Turns out the variable (useKMPHWind) in your “config.js” should be with a lowercase w for useKMPHwind.
                  				locationID: "2744118", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  				appid: "12345678901234567890",
                  				roundTemp: true,
                  				useBeaufort: false,
                  				useKMPHwind: true,
                    Thank you @MaXi-XCeL that was the problem. Case sensitive variables? Come on… :-(
                    And you need the useBeaufort: false to have it work.
                    useBeaufort: false,
                    useKMPHwind: true,
                    Thank you again, on step closer.
