    Can"t get wind speed shown in KMPH why?
    9 Posts 6 Posters 3.4k Views 6 Watching
    • C
      carlderdritte
      I can get my MM to show me wind speed in KMPH.
      I is also not showing rain.
      What do I do wrong?
      Thanks for the help!
      Carl
                              module: "currentweather",
                              header: "Byron Bay",
                                      locationID: "2172880",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      appid: "XXX",
                                      useKMPHWind: "true",
                                      roundTemp: "true",
                                      showRainAmount: "true",
                                      degreeLabel: "true"
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @carlderdritte
        @carlderdritte said in Can"t get wind speed shown in KMPH why?:
        Remove the quotes from true
         useKMPHWind: true,
         roundTemp: true,
         showRainAmount: true,
         degreeLabel: true
        C 1 Reply Last reply
        • C
          carlderdritte @Mykle1
          @mykle1 no changes without the quotes :(
          • T
            thisistheplace
            Sry, if this thread is too old to answer but I had the same question and had problems to find a solution for this. But it seems like I have one.
            In my config I only set useKMPHwind to true and that didn’t work but after I also changed the useBeaufort from its default true value to false it seems to work.
            At this moment openweathermap shows 1,5m/s and magicmirror shows 5 as windspeed. 1,5m/s are actually 5,4km/h so I think its an rounded value.
            • M
              MajorC Project Sponsor
              I’ll have to dig up this old thread again. I too do not get the wind speed displayed in km/h.
              My config says:
              				locationID: "2950159", //Location ID from http://bulk.openweathermap.org/sample/city.list.json.gz
              				appid: "***MYKEY***", //openweathermap.org API key.
              				useBeaufort: false,
              				useKMPHWind: true
              • thgmirrorT
                thgmirror
                Hi @MajorC,
                without using this module, I saw you wrote
                seBeaufort: false, instead of
                useBeaufort: false,
                May be that is the reason.
                Greetings from Bonn
                Thomas
                • M
                  Thank you, this was just a copy & paste error. On the MM I have use with a u.
                  @carlderdritte or @thisistheplace have you guys found a solution?
                  • M
                    MaXi-XCeL Project Sponsor
                    Re: Can"t get wind speed shown in KMPH why?
                    Turns out the variable (useKMPHWind) in your “config.js” should be with a lowercase w for useKMPHwind.
                    				locationID: "2744118", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    				appid: "12345678901234567890",
                    				roundTemp: true,
                    				useBeaufort: false,
                    				useKMPHwind: true,
                    • M
                      Thank you @MaXi-XCeL that was the problem. Case sensitive variables? Come on… :-(
                      And you need the useBeaufort: false to have it work.
                      useBeaufort: false,
                      useKMPHwind: true,
                      Thank you again, on step closer.
