    Can"t get wind speed shown in KMPH why?
    9 Posts 6 Posters 2.8k Views 6 Watching
      carlderdritte @Mykle1
      @mykle1 no changes without the quotes :(
      • T Offline
        thisistheplace
        Sry, if this thread is too old to answer but I had the same question and had problems to find a solution for this. But it seems like I have one.
        In my config I only set useKMPHwind to true and that didn’t work but after I also changed the useBeaufort from its default true value to false it seems to work.
        At this moment openweathermap shows 1,5m/s and magicmirror shows 5 as windspeed. 1,5m/s are actually 5,4km/h so I think its an rounded value.
          MajorC Project Sponsor
          I’ll have to dig up this old thread again. I too do not get the wind speed displayed in km/h.
          My config says:
          			module: "currentweather",
          				locationID: "2950159", //Location ID from http://bulk.openweathermap.org/sample/city.list.json.gz
          				appid: "***MYKEY***", //openweathermap.org API key.
          				useBeaufort: false,
          				useKMPHWind: true
          • thgmirrorT Offline
            thgmirror
            Hi @MajorC,
            without using this module, I saw you wrote
            seBeaufort: false, instead of
            useBeaufort: false,
            May be that is the reason.
            Greetings from Bonn
            Thomas
              Thank you, this was just a copy & paste error. On the MM I have use with a u.
              @carlderdritte or @thisistheplace have you guys found a solution?
                MaXi-XCeL Project Sponsor
                Re: Can"t get wind speed shown in KMPH why?
                Turns out the variable (useKMPHWind) in your “config.js” should be with a lowercase w for useKMPHwind.
                				locationID: "2744118", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				appid: "12345678901234567890",
                				roundTemp: true,
                				useBeaufort: false,
                				useKMPHwind: true,
                  Thank you @MaXi-XCeL that was the problem. Case sensitive variables? Come on… :-(
                  And you need the useBeaufort: false to have it work.
                  useBeaufort: false,
                  useKMPHwind: true,
                  Thank you again, on step closer.
