    Home Assistant integration
    9 Posts 6 Posters 5.3k Views 7 Watching
      daniel_svk @daniel_svk
      Or may I use Openhab and not Home Assistant?
      • F Offline
        fribse @daniel_svk
        @daniel_svk I’ve written some guides on the HA forum about the integration, by using the MQTTBridge and Mosquitto on HA. You can find the post here
        • E Offline
          Egnos
          Hi @fribse, do you use physical Google Home or do you run Google Assistant on the RPI? Thanks
          R F 2 Replies Last reply Reply Quote 0
            raf @Egnos
            @egnos
            is it possible to use the physical Google Home with MagicMirror, I use the google assistant on the rpi but would like to know how to use the google home on the mirror
            • E Offline
              Egnos
              @raf Also I’m trying to understand how to use a physical GoogleHome to control the MM.
              It is also discussed in this topic of 2019, but I do not know if it is still valid as a method or new solutions have come out today …
              • F Offline
                fribse @Egnos
                @egnos I had plans on activating the voice assistant in the mirror directly, but I’ve not found a good setup yet.
                SergeS 1 Reply Last reply Reply Quote 0
                  sdetweil @Egnos
                  @egnos did u try that setup?
                  • SergeS Offline
                    Serge @fribse
                    @fribse mmm-googleassistant maintained by Mr.@bugsounet works well)
