    Home Assistant integration
    9 Posts 6 Posters 5.8k Views 7 Watching
      daniel_svk
      I have clean and unused Raspberry Pi 4 + old screen from notebook and HDMI adapter for this screen.
      I would like to create a magic mirror to show info from my Xiaomi smart ecosystem (temperatues, lights, etc.)
      In what order should I install MagicMirror² and Home Assistant?
      I have also PIR sensor - how can I turn on/off screen of magic mirror with this sensor?
      Thank you in advance
      D 1 Reply Last reply
        daniel_svk @daniel_svk
        Or may I use Openhab and not Home Assistant?
        F 1 Reply Last reply
        • F
          fribse @daniel_svk
          @daniel_svk I’ve written some guides on the HA forum about the integration, by using the MQTTBridge and Mosquitto on HA. You can find the post here
          • E
            Egnos
            Hi @fribse, do you use physical Google Home or do you run Google Assistant on the RPI? Thanks
            R F 2 Replies Last reply
              raf @Egnos
              @egnos
              is it possible to use the physical Google Home with MagicMirror, I use the google assistant on the rpi but would like to know how to use the google home on the mirror
              • E
                Egnos
                @raf Also I’m trying to understand how to use a physical GoogleHome to control the MM.
                It is also discussed in this topic of 2019, but I do not know if it is still valid as a method or new solutions have come out today …
                • F
                  fribse @Egnos
                  @egnos I had plans on activating the voice assistant in the mirror directly, but I’ve not found a good setup yet.
                  SergeS 1 Reply Last reply
                    sdetweil @Egnos
                    @egnos did u try that setup?
                    • SergeS
                      Serge @fribse
                      @fribse mmm-googleassistant maintained by Mr.@bugsounet works well)
