    MMM-BM-OW when 'no rain' for forecast undefined message received.
    14 Posts 3 Posters 4.6k Views 3 Watching
      scumbelly
      The module works just fine. It’s only when you do not receive a forecasted rain amount . So if Tuesday has 2 returned ( for mm of rain) and Wednesday has no rain then Wednesday displays undefined as a value.
      The code is …
      moment.unix(forecast.daily[X].sunrise).local().format(‘ddd’) + " &nbsp" + “<img class = image src=./modules/MMM-BMW-OW/icons/” + forecast.daily[X].weather[0].main + “.png>” + " &nbsp" + Math.round(forecast.daily[X].temp.max) + “/” + Math.round(forecast.daily[X].temp.min) + " &nbsp &nbsp &nbsp &nbsp &nbsp" + forecast.daily[X].rain + “/mm Rain” + “&nbsp &nbsp &nbsp &nbsp &nbsp”+ until 6 terminates with no + but with ;
      Hope that helps.
      is 0 to 6.
        scumbelly @scumbelly
        That check mark is supposed to be X for 0 to 6.
          scumbelly
          I changed the string a bit. I added Math.round to forecast.daily[X].rain + “/mm Rain”
          Math.round (forecast.daily[X].rain) + “/mm Rain”
          and instead of undefind/mm Rain I now receive NaN/mm Rain.
          Cool.
          • cowboysdudeC
            cowboysdude Module Developer @scumbelly
            @scumbelly this needs some css help but… is this what you’re after?
              scumbelly @cowboysdude
              @cowboysdude
              Exceptional. That’s it! What’s the solution? I started to go down an isNAN() rabbit hole but as yet haven’t been successful.
              Great job.
              • cowboysdudeC
                @scumbelly It takes rewriting parts of the entire module to make it work…
                Mykle1M 1 Reply Last reply
                  scumbelly
                  @cowboysdude
                  I don’t know if I’m headed in the right way but I’ve tried to make showRain a config option - true/false.
                  Right now it kinda loads - at least I get Openweather data… on the screen instead of a blank “dead zone”.
                  Gotta play more… Gotta learn more.
                  Cheers
                  • Mykle1M
                    @cowboysdude said in MMM-BM-OW when 'no rain' for forecast undefined message received.:
                    Uhhhh . . .
                    • cowboysdudeC
                      @scumbelly Have at it… it’s how you learn.
                        @cowboysdude
                        @Mykle1
                        I’m going to move onto another module for now. I’ll revisit this in the future when I am more experienced. Right now I’m just self immolating.
                        Thanks for your time and effort.
