    MMM-BM-OW when 'no rain' for forecast undefined message received.
    14 Posts 3 Posters 4.0k Views 3 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @scumbelly
      @scumbelly said in MMM-BM-OW when 'no rain' for forecast undefined message received.:
      MMM-BM-OW
      I can take a look at it if you’d like.
        scumbelly
        Sure, thanks.
        I tried a bunch of things and was just thinking about “null” being returned and how to handle it. If rain worked completely then I could try snow and that would cover everything ( I think) I’d want the module to do.
          Mykle1 Project Sponsor Module Developer @scumbelly
          @scumbelly
          Just to be clear, the module works but not after you modified it?
            scumbelly
            The module works just fine. It’s only when you do not receive a forecasted rain amount . So if Tuesday has 2 returned ( for mm of rain) and Wednesday has no rain then Wednesday displays undefined as a value.
            The code is …
            moment.unix(forecast.daily[X].sunrise).local().format(‘ddd’) + " &nbsp" + “<img class = image src=./modules/MMM-BMW-OW/icons/” + forecast.daily[X].weather[0].main + “.png>” + " &nbsp" + Math.round(forecast.daily[X].temp.max) + “/” + Math.round(forecast.daily[X].temp.min) + " &nbsp &nbsp &nbsp &nbsp &nbsp" + forecast.daily[X].rain + “/mm Rain” + “&nbsp &nbsp &nbsp &nbsp &nbsp”+ until 6 terminates with no + but with ;
            Hope that helps.
            is 0 to 6.
              scumbelly @scumbelly
              That check mark is supposed to be X for 0 to 6.
                scumbelly
                I changed the string a bit. I added Math.round to forecast.daily[X].rain + “/mm Rain”
                Math.round (forecast.daily[X].rain) + “/mm Rain”
                and instead of undefind/mm Rain I now receive NaN/mm Rain.
                Cool.
                  @scumbelly this needs some css help but… is this what you’re after?
                    scumbelly @cowboysdude
                    @cowboysdude
                    Exceptional. That’s it! What’s the solution? I started to go down an isNAN() rabbit hole but as yet haven’t been successful.
                    Great job.
                      @scumbelly It takes rewriting parts of the entire module to make it work…
                        scumbelly
                        @cowboysdude
                        I don’t know if I’m headed in the right way but I’ve tried to make showRain a config option - true/false.
                        Right now it kinda loads - at least I get Openweather data… on the screen instead of a blank “dead zone”.
                        Gotta play more… Gotta learn more.
                        Cheers
