    MMM-BM-OW when 'no rain' for forecast undefined message received.
    14 Posts 3 Posters 4.5k Views 3 Watching
      scumbelly
      I added + forecast.daily[0].rain + “/mm Rain” to the MMM-BM-OW module and if there is rain the amount is returned. If there is no rain I receive “undefined”. I would like to show " 0 " (zero) or at least something, but I haven’t been able to as yet figure out how to do it. Anyone have some pointers?
      Cheers.
      • cowboysdudeC Offline
        cowboysdude Module Developer @scumbelly
        @scumbelly said in MMM-BM-OW when 'no rain' for forecast undefined message received.:
        MMM-BM-OW
        I can take a look at it if you’d like.
          scumbelly
          Sure, thanks.
          I tried a bunch of things and was just thinking about “null” being returned and how to handle it. If rain worked completely then I could try snow and that would cover everything ( I think) I’d want the module to do.
            Mykle1 Project Sponsor Module Developer @scumbelly
            @scumbelly
            Just to be clear, the module works but not after you modified it?
              scumbelly
              The module works just fine. It’s only when you do not receive a forecasted rain amount . So if Tuesday has 2 returned ( for mm of rain) and Wednesday has no rain then Wednesday displays undefined as a value.
              The code is …
              moment.unix(forecast.daily[X].sunrise).local().format(‘ddd’) + " &nbsp" + “<img class = image src=./modules/MMM-BMW-OW/icons/” + forecast.daily[X].weather[0].main + “.png>” + " &nbsp" + Math.round(forecast.daily[X].temp.max) + “/” + Math.round(forecast.daily[X].temp.min) + " &nbsp &nbsp &nbsp &nbsp &nbsp" + forecast.daily[X].rain + “/mm Rain” + “&nbsp &nbsp &nbsp &nbsp &nbsp”+ until 6 terminates with no + but with ;
              Hope that helps.
              is 0 to 6.
                scumbelly @scumbelly
                That check mark is supposed to be X for 0 to 6.
                  scumbelly
                  I changed the string a bit. I added Math.round to forecast.daily[X].rain + “/mm Rain”
                  Math.round (forecast.daily[X].rain) + “/mm Rain”
                  and instead of undefind/mm Rain I now receive NaN/mm Rain.
                  Cool.
                    @scumbelly this needs some css help but… is this what you’re after?
                      scumbelly @cowboysdude
                      @cowboysdude
                      Exceptional. That’s it! What’s the solution? I started to go down an isNAN() rabbit hole but as yet haven’t been successful.
                      Great job.
                        @scumbelly It takes rewriting parts of the entire module to make it work…
                          scumbelly
                          @cowboysdude
                          I don’t know if I’m headed in the right way but I’ve tried to make showRain a config option - true/false.
                          Right now it kinda loads - at least I get Openweather data… on the screen instead of a blank “dead zone”.
                          Gotta play more… Gotta learn more.
                          Cheers
                            @cowboysdude said in MMM-BM-OW when 'no rain' for forecast undefined message received.:
                            Uhhhh . . .
                              @scumbelly Have at it… it’s how you learn.
                                @cowboysdude
                                @Mykle1
                                I’m going to move onto another module for now. I’ll revisit this in the future when I am more experienced. Right now I’m just self immolating.
                                Thanks for your time and effort.
