    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 692.4k Views 57 Watching
    • O Offline
      OberfragGER @OberfragGER
      @oberfragger ok. Got sunrise working in german. There was a missing config line:
      label_sunriseTimeFormat: "hh:mm",
      and also with the time… also a typo (forgot the “hourly”):
      label_hourlyTimeFormat: "k[h]",
      I edited this to:
      label_hourlyTimeFormat: "k[ Uhr]",
      Still inspecting the storm warning in german…
      • karsten13K Offline
        karsten13 @OberfragGER
        @oberfragger
        same problem here, saw meanwhile some of this warnings in german but mostly in english. Looks like a problem on the provider side, when inspecting the called url in the browser the retrieved data is in english.
        So this can’t be solved by the module.
        • swvalentiS Offline
          swvalenti Project Sponsor
          @j-e-f-f Anyway to hide the special weather advisory? Really jacks up my layout, I took a look at config but nothing stood out.
            dkhorse74 @BKeyport
            @bkeyport said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
            @dkhorse74 That’s the main header… hint…
            :thumbs_up: Thank You
              karsten13 @karsten13
              so now i catched the situation where the alerts are in english and in german:
              the data is coming directly from openweathermap, here the json-part:
                j.e.f.f Project Sponsor Module Developer @dkhorse74
                @dkhorse74 that’s the main header for the module. Change it like this:
                    module: "MMM-OpenWeatherForecast",
                    header: "Forecast",  <— here
                      apikey: "a1b2c3d4e5f6g7h8j9k0", //only string here
                      latitude: 51.490230,            //number works here
                      longitude: "-0.258810"          //so does a string
                  j.e.f.f Project Sponsor Module Developer @shiryu1031
                  @shiryu1031 you can’t do that independently on the main units setting. OpenWeather returns mph for imperial, and m/s for standard and metric.
                    j.e.f.f Project Sponsor Module Developer @swvalenti
                    @swvalenti yes you can. The weather alerts are part of the summary section. OpenWeather returns such a short summary that I didn’t think it necessary to make two separate configure. Two ways to turn off the alerts:
                    • set summary : false
                    • if you want the summary but not the alerts, you can hide them in your custom css as follows:
                    .MMM-OpenWeatherForecast .weather-alert {
                      display: none;
                    I think I’ll look at a way to truncate weather alerts so they don’t take up so much space.
                    swvalentiS 1 Reply Last reply Reply Quote 1
                      j.e.f.f Project Sponsor Module Developer @karsten13
                      @karsten13 I don’t think there is much I can do here. I’ve coded this module to explicitly pass through a language parameter, either whatever is set in your main MM config, or whatever you explicitly set in the module’s config. It seems that OpenWeather doesn’t translate the weather alert, but merely passes them on as-is from whatever source it gets them from. Which is why sometimes you’re getting only English, and other times you’re getting multiple translations.
                        swvalenti Project Sponsor @j.e.f.f
                        @j-e-f-f said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                          display: none;
                        Awesome thanks @j-e-f-f !
                          dkhorse74 @j.e.f.f
                          @j-e-f-f
                          Thanks Jeff!!
                            shiryu1031 @j.e.f.f
                            @j-e-f-f I see, thank you for your help. I thought it can be done because the example picture on Github is in km/h, but for myself, I am only seeing m/s as you mentioned. I guess it can not be change from m/s to km/h?
                              karsten13 @j.e.f.f
                              @j-e-f-f
                              yes, I’m aware of this. Sent a mail to openweathermap.org and will let you know if I ever get a response …
                              • O Offline
                                OberfragGER @karsten13
                                Did anyone have an idea how to chage the timeformat from sundown?
                                Now its displayed: 6:20… i want to have 18:20
                                I already changed the rest.
                                  @oberfragger
                                  label_sunriseTimeFormat: "k:mm",
                                  • O Offline
                                    @karsten13 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                    label_sunriseTimeFormat: “k:mm”,
                                    Not working: :(
                                    			iconset: "3c",
                                    			label_sunsetTimeFormat: "k:mm",
                                    			label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"]
                                    i also tried:
                                    label_sunsetTimeFormat: "hh:mm",
                                    also not working. The sunset on top is still not in german timeformat.
                                    karsten13K J 2 Replies Last reply Reply Quote 0
                                      @oberfragger said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                      there is no property label_sunsetTimeFormat, only label_sunriseTimeFormat, remove the not existing one …
                                        j.e.f.f Project Sponsor Module Developer @OberfragGER
                                        @oberfragger
                                        There is only one property that is used for both sunrise and sunset: label_sunriseTimeFormat. In your example above, you’ve specified hh:mm for this property, which displays 12h time, not 24h time.
                                        Change your config from this:
                                        iconset: "3c",
                                        to this:
                                        iconset: "3c",
                                        label_sunriseTimeFormat: "k:mm",  // change the format for this one
                                        O 1 Reply Last reply Reply Quote 1
                                          @shiryu1031 The screenshots you see in GitHub were incorrect. My old code for Dark Sky was using km/h, and I hadn’t replaced the label with m/s when I took these screen shots. So the screenshots are actually illustrating a bug! The actual speed value shown is m/s, but the label is incorrect as km/h. :beaming_face_with_smiling_eyes:
                                          I thought about it, and it would take me just as much time to fix the screen shots as it would to add the capability to convert m/s into km/h. So now there is a new config parameter: displayKmhForWind. If you add this to your config and set it to true, m/s wind speed will be converted and displayed as km/h. This parameter only works when units is set to "metric" or "standard". If you’re using "imperial" you will always see mph.
                                          Do a git pull in your installed MMM-OpenWeatherForecast directory to get the updated code.
                                            @swvalenti I’ve made a modification that now truncates alerts to no more than 3 lines of description. This is controlled with CSS so if you’ve like to adjust this for more or less lines, you can do so in your custom CSS file as follows:
                                            .MMM-OpenWeatherForecast .weather-alert .weather-alert-description {
                                              -webkit-line-clamp: 3; /* adjust this as desired */
                                            do a git pull in your installed MMM-OpenWeatherForecast directory to get the latest code.
                                            swvalentiS 1 Reply Last reply Reply Quote 0
                                            • 12
                                            • 13
                                            • 2 / 13
