    Advent Module not working for me...?
    8 Posts 3 Posters 4.7k Views 3 Watching
    • lolobyteL Offline
      lolobyte @valid8r
      @valid8r
      Maybe this will help you.
      It’s my part of config with the Advent module after updating by the developer with the possibility to implement 4 candles.:
                          module: 'MMM-Advent',
                          position: 'bottom_center',
                                  updateInterval: 10 * 60 * 1000,
                                  marks: 0, //default is 24
                                  height: 400,
                                  showFlameBeforeStart: false,
                                  start: ["2016-11-27 00:00:01", "2016-12-11 00:00:01", "2016-12-18 00:00:01", "2016-12-04 00:00:01"],
                                  end: ["2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59"],
          //                      start: "2016-11-25 00:00:01", //Geburtstag Anfang
          //                      end: "2016-11-25 23:59:59", //Geburtstag Ende
          //                      start: "2016-12-01 00:00:01", //Eine Kerze; default is "2016-12-01 08:00:00"
          //                      end: "2016-12-24 23:59:59", //Eine Kerze; default is "2016-12-24 22:00:00"
                                  enableAnimation: true,
                                  fontColor: "#000000", //default is #000000 (black)
                                  candleColor: "#FFFFFF", //default is #FFFFFF (white)
        Jopyth Moderator
        @valid8r Did you copy and paste the example config from the readme? The section should work as is. If you did not copy it exactly, pay attention to the braces and commas, maybe you have got a syntax error.
        Full disclosure: I am the author of the module.
        • V Offline
          valid8r
          Thanks guys - I’m embarrassed to admit that I had typed “bottom-center” instead of “bottom_center”!
          lolobyteL 1 Reply Last reply Reply Quote 1
          • lolobyteL Offline
            lolobyte @valid8r
            @valid8r
            have u tried the snow module?
            looks nice with advent together.
            https://github.com/nhubbard/MagicPlugins/tree/master/snow
            • V Offline
              valid8r @lolobyte
              @lolobyte Thanks!!! This helped. I saw from this that I had mis-typed “bottom_center” as “bottom-center”!
              You would think that as an Engineer, details would be something I would excel at, apparently that is not the case!
              @lolobyte said in Advent Module not working for me...?:
              @valid8r
              I’m having trouble using git clone with the https:// link you provided. can you confirm that is the correct fork? Also does the module use position: ?
              • lolobyteL Offline
                lolobyte
                @valid8r
                Hi, thats the web link. There is no fork link.
                Create a folder “snow” in your module folder.
                Copy snow.js and snow.css in this folder.
                Edit your config.js an put folowing code into
                    module: 'snow',
                restart your mm with
                pm2 restart mm
                Good luck
                • V Offline
                  valid8r @lolobyte
                  @lolobyte Got it! Thanks! Wife love it.
