    Advent Module not working for me...?
    8 Posts 3 Posters 4.6k Views 3 Watching
    • V Offline
      valid8r
      Thanks guys - I’m embarrassed to admit that I had typed “bottom-center” instead of “bottom_center”!
      lolobyteL 1 Reply Last reply Reply Quote 1
      • lolobyteL Offline
        lolobyte @valid8r
        @valid8r
        have u tried the snow module?
        looks nice with advent together.
        https://github.com/nhubbard/MagicPlugins/tree/master/snow
        • V Offline
          valid8r @lolobyte
          @lolobyte Thanks!!! This helped. I saw from this that I had mis-typed “bottom_center” as “bottom-center”!
          You would think that as an Engineer, details would be something I would excel at, apparently that is not the case!
          @lolobyte said in Advent Module not working for me...?:
          @valid8r
          I’m having trouble using git clone with the https:// link you provided. can you confirm that is the correct fork? Also does the module use position: ?
          • lolobyteL Offline
            lolobyte
            @valid8r
            Hi, thats the web link. There is no fork link.
            Create a folder “snow” in your module folder.
            Copy snow.js and snow.css in this folder.
            Edit your config.js an put folowing code into
                module: 'snow',
            restart your mm with
            pm2 restart mm
            Good luck
            • V Offline
              valid8r @lolobyte
              @lolobyte Got it! Thanks! Wife love it.
