    Advent Module not working for me...?
    8 Posts 3 Posters 4.6k Views 3 Watching
      Jopyth Moderator
      @valid8r Did you copy and paste the example config from the readme? The section should work as is. If you did not copy it exactly, pay attention to the braces and commas, maybe you have got a syntax error.
      Full disclosure: I am the author of the module.
      • V Offline
        valid8r
        Thanks guys - I’m embarrassed to admit that I had typed “bottom-center” instead of “bottom_center”!
        lolobyteL 1 Reply Last reply Reply Quote 1
        • lolobyteL Offline
          lolobyte @valid8r
          @valid8r
          have u tried the snow module?
          looks nice with advent together.
          https://github.com/nhubbard/MagicPlugins/tree/master/snow
          • V Offline
            valid8r @lolobyte
            @lolobyte Thanks!!! This helped. I saw from this that I had mis-typed “bottom_center” as “bottom-center”!
            You would think that as an Engineer, details would be something I would excel at, apparently that is not the case!
            @lolobyte said in Advent Module not working for me...?:
            @valid8r
            I’m having trouble using git clone with the https:// link you provided. can you confirm that is the correct fork? Also does the module use position: ?
            • lolobyteL Offline
              lolobyte
              @valid8r
              Hi, thats the web link. There is no fork link.
              Create a folder “snow” in your module folder.
              Copy snow.js and snow.css in this folder.
              Edit your config.js an put folowing code into
                  module: 'snow',
              restart your mm with
              pm2 restart mm
              Good luck
              • V Offline
                valid8r @lolobyte
                @lolobyte Got it! Thanks! Wife love it.
