    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
      stoffel
      ok, thanks. it works well with all my modules, great!
      but when i add the MMM-Volume i have another error. i think it is a problem from MMM-Volume. it’s two years old. it’s a json format error
        sdetweil @stoffel
        @stoffel no, I fixed a problem with MMM-Volume earlier today… haven’t pushed it yet…
          stoffel @sdetweil
          ok
          when you module works also with MMM-Volume then i am very happy.:beaming_face_with_smiling_eyes: i control my mm over remote control.
          thank you very much for your support, great job :thumbs_up:
            sdetweil @stoffel
            @stoffel do a git pull on the newform branch, and try it out… this is with the fix for MMM-Volume
            and another, plus an npm install after
            • AssassinsA
              Assassins
              Work 100% with rpi 3, Nice modul you made, Thanks alot
                stoffel @sdetweil
                good morning
                sometimes i can not post, when i submit i have a error message in the lower right corner ?!
                ok, i’v tested your fix. at the moment your module do not work for. in mm says i use localhost, but in my config i have addressed at 0.0.0.0 and ipWhitelist: []
                i send you the result of pm2 logs --lines=100. one for test without MMM-Volume and one with.
                i hope it’s help you.
                  sdetweil @stoffel
                  @stoffel yes, the forum is not very helpful on why a posting error… i get it too…
                  i refresh the screen and then I can post the exact same message… (I copy it before refresh)
                  MMM-Volume… i thought i pushed that one line change… just did… git pull
                  the localhost/0.0.0.0
                  will examine
                    sdetweil @stoffel
                    @stoffel ok, fixes… in branch newform…
                    on the QR code messages I was changing address AND ipWhitelist EMPTY…
                    i only check address now, and assume you know what you are doing on whitelist
                      For any that want to look at the multi-module form layout and give feedback
                      checkout the multi-module branch
                      git checkout multi-module
                      there is a file that contains the list of module names that CAN be used multiple times in the same config.js
                      modules_list.txt
                      you cannot submit the form, only view it…
                      to go back to the operating version
                      git checkout main
                      or
                      (with the .... fixes)
                      git checkout newform
                        stoffel @sdetweil
                        i did it. WOW, all works well. thanks, great job and fast :thumbs_up:
                        but it works only when i open …/review or must add ‘?port=8300’ at …/config.html
                        thank you very much :-)
                          sdetweil @stoffel
                          @stoffel said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                          well, i need a free port to have the two parts communicate.
                          I had ‘guessed’ at a free port, but some other users had stuff running there
                          so, I have it get a free port, but now I have to pass that to the form side…
                          use the review URL , it will always redirect to the correct url
                          it will probably never change on your system , so once u know what the number is, use that url…
                            stoffel @sdetweil
                            ok, thanks for you support. great job !
                            i follow this tread and test your module. but in the next days i am a little bit busy.
                            so, @ all have a nice WE
                              sdetweil @stoffel
                              @stoffel thanks for your help!..
                              I need people like you to help improve the module. every bug found now helps…
                                stoffel @sdetweil
                                thanks ;-)
                                and i like people like you who spent a lot of time for creating useful modules like this !!
                                again thanks a lot
                                • BKeyportB
                                  BKeyport Module Developer
                                  So, I’m getting the header and nothing else.
                                  fresh install of MagicMirror using the script, PM2. Here’s my config, as you can see, the only changes are the listening address, the ipWhitelist, and the addition of the module as shown in the readme.
                                  modules I installed (but didn’t configure for testing) were MMM-Config, MMM-Multimonth, and MMM-OpenWeatherForecast.
                                  var config = {
                                          address: "0.0.0.0",     // Address to listen on, can be:
                                          port: 8080,
                                          basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                          ipWhitelist: [],        // Set [] to allow all IP addresses
                                          useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
                                          httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                                          httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                                          language: "en",
                                          locale: "en-US",
                                          timeFormat: 24,
                                          units: "metric",
                                                  module:"MMM-Config",
                                                  position:"top_right",  // the QR code (if requested) will appear here
                                                  config:{
                                  ... (no changes after this point)
                                    sdetweil @BKeyport
                                    @bkeyport if u open the developers window, ctrl-shift-i, and select the console tab. are there errors shown
                                    also if u look in the pm2 logs, are there problems.
                                    do a
                                    and try again. lots of fixes there
                                    the latest code requires a port number to be passed to the form page… use the review link
                                    http://mm_ip:mm_port/modules/MMM-Config/review
                                    (thats the url on the qr image)
                                    • BKeyportB
                                      Failed to load resource (Connection refused) http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkO1_
                                      DevTools failed to load SourceMap: Could not load content for http://IP:8080/modules/MMM-Config/node_modules/jsonform/deps/opt/bootstrap.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                      Then repeated
                                      (anonymous) @ VM6:1
                                      create @ polling-xhr.js:198
                                      Request @ polling-xhr.js:115
                                      request @ polling-xhr.js:62
                                      doPoll @ polling-xhr.js:90
                                      poll @ polling.js:74
                                      doOpen @ polling.js:23
                                      open @ transport.js:44
                                      open @ socket.js:194
                                      Socket @ socket.js:119
                                      ./node_modules/engine.io-client/lib/index.js.module.exports @ index.js:3
                                      open @ manager.js:112
                                      (anonymous) @ manager.js:342
                                      VM6:1 GET http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkPo7 net::ERR_CONNECTION_REFUSED
                                        sdetweil @BKeyport
                                        @bkeyport did u use the review link, its probably port 8300 now
                                        see the instructions here
                                        https://github.com/sdetweil/MMM-Config/issues/8
                                        • BKeyportB
                                          @sdetweil review link as shown redirects to:
                                          http://raspberrypi:8080/modules/MMM-Config/config.html?port=8301
                                          which fails because it’s not in DNS - changing raspberrypi to my IP address results in same header as before. Did update newform, and restarted MM.
                                          S 3 Replies Last reply Reply Quote 0
                                            sdetweil @BKeyport
                                            @bkeyport i have cors allow all …
                                            • 14
                                            • 15
                                            • 3 / 15
