    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.9k Views 31 Watching
      sdetweil @stoffel
      @stoffel ok, fixes… in branch newform…
      on the QR code messages I was changing address AND ipWhitelist EMPTY…
      i only check address now, and assume you know what you are doing on whitelist
        For any that want to look at the multi-module form layout and give feedback
        checkout the multi-module branch
        git checkout multi-module
        there is a file that contains the list of module names that CAN be used multiple times in the same config.js
        modules_list.txt
        you cannot submit the form, only view it…
        to go back to the operating version
        git checkout main
        or
        (with the .... fixes)
        git checkout newform
          stoffel @sdetweil
          i did it. WOW, all works well. thanks, great job and fast :thumbs_up:
          but it works only when i open …/review or must add ‘?port=8300’ at …/config.html
          thank you very much :-)
            sdetweil @stoffel
            @stoffel said in Are you tired of editing config.js, or have trouble doing it, see my new module:
            well, i need a free port to have the two parts communicate.
            I had ‘guessed’ at a free port, but some other users had stuff running there
            so, I have it get a free port, but now I have to pass that to the form side…
            use the review URL , it will always redirect to the correct url
            it will probably never change on your system , so once u know what the number is, use that url…
              stoffel @sdetweil
              ok, thanks for you support. great job !
              i follow this tread and test your module. but in the next days i am a little bit busy.
              so, @ all have a nice WE
                sdetweil @stoffel
                @stoffel thanks for your help!..
                I need people like you to help improve the module. every bug found now helps…
                  stoffel @sdetweil
                  thanks ;-)
                  and i like people like you who spent a lot of time for creating useful modules like this !!
                  again thanks a lot
                  • BKeyportB
                    BKeyport Module Developer
                    So, I’m getting the header and nothing else.
                    fresh install of MagicMirror using the script, PM2. Here’s my config, as you can see, the only changes are the listening address, the ipWhitelist, and the addition of the module as shown in the readme.
                    modules I installed (but didn’t configure for testing) were MMM-Config, MMM-Multimonth, and MMM-OpenWeatherForecast.
                    var config = {
                            address: "0.0.0.0",     // Address to listen on, can be:
                            port: 8080,
                            basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                            ipWhitelist: [],        // Set [] to allow all IP addresses
                            useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
                            httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                            httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                            language: "en",
                            locale: "en-US",
                            timeFormat: 24,
                            units: "metric",
                                    module:"MMM-Config",
                                    position:"top_right",  // the QR code (if requested) will appear here
                                    config:{
                    ... (no changes after this point)
                      sdetweil @BKeyport
                      @bkeyport if u open the developers window, ctrl-shift-i, and select the console tab. are there errors shown
                      also if u look in the pm2 logs, are there problems.
                      do a
                      and try again. lots of fixes there
                      the latest code requires a port number to be passed to the form page… use the review link
                      http://mm_ip:mm_port/modules/MMM-Config/review
                      (thats the url on the qr image)
                      BKeyportB 1 Reply Last reply
                      • BKeyportB
                        Failed to load resource (Connection refused) http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkO1_
                        DevTools failed to load SourceMap: Could not load content for http://IP:8080/modules/MMM-Config/node_modules/jsonform/deps/opt/bootstrap.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        Then repeated
                        (anonymous) @ VM6:1
                        create @ polling-xhr.js:198
                        Request @ polling-xhr.js:115
                        request @ polling-xhr.js:62
                        doPoll @ polling-xhr.js:90
                        poll @ polling.js:74
                        doOpen @ polling.js:23
                        open @ transport.js:44
                        open @ socket.js:194
                        Socket @ socket.js:119
                        ./node_modules/engine.io-client/lib/index.js.module.exports @ index.js:3
                        open @ manager.js:112
                        (anonymous) @ manager.js:342
                        VM6:1 GET http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkPo7 net::ERR_CONNECTION_REFUSED
                          sdetweil @BKeyport
                          @bkeyport did u use the review link, its probably port 8300 now
                          see the instructions here
                          https://github.com/sdetweil/MMM-Config/issues/8
                          • BKeyportB
                            @sdetweil review link as shown redirects to:
                            http://raspberrypi:8080/modules/MMM-Config/config.html?port=8301
                            which fails because it’s not in DNS - changing raspberrypi to my IP address results in same header as before. Did update newform, and restarted MM.
                            S 3 Replies Last reply
                              sdetweil @BKeyport
                              @bkeyport i have cors allow all …
                                sdetweil @BKeyport
                                @bkeyport I asked the machine for its IP address /name…
                                most routers now -a-days register the DHCP requests to names…
                                • BKeyportB
                                  Yeah, my router setup is stupid in my testing area. :)
                                    sdetweil @BKeyport
                                    @bkeyport and npm install after checkout newform?
                                    • BKeyportB
                                      @sdetweil Yeah, that did it… Forgot to npm install. D’oh!
                                      S 2 Replies Last reply
                                        sdetweil @BKeyport
                                        @bkeyport I construct the review url like this
                                              // thi is the name in the preferences pi
                                              this.hostname = os.hostname();
                                              this.config.url =
                                                "http://" +
                                                (this.config.address == "0.0.0.0"
                                                  ? this.hostname
                                                  : this.config.address) +
                                                this.config.port;
                                        so, lacking the dns entry, I would configure to use one of the specific ip addresses
                                          sdetweil @BKeyport
                                          @bkeyport
                                          @bkeyport said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                          Yeah, that did it…
                                          does that mean you system is working now?
                                          • BKeyportB
                                            @sdetweil Yeah. playing with it now making sure it works with my module and modules I’ve taken up support for.
                                            • 14
                                            • 15
                                            • 3 / 15
