    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.9k Views 31 Watching
    • BKeyportB
      BKeyport Module Developer
      So, I’m getting the header and nothing else.
      fresh install of MagicMirror using the script, PM2. Here’s my config, as you can see, the only changes are the listening address, the ipWhitelist, and the addition of the module as shown in the readme.
      modules I installed (but didn’t configure for testing) were MMM-Config, MMM-Multimonth, and MMM-OpenWeatherForecast.
      var config = {
              address: "0.0.0.0",     // Address to listen on, can be:
              port: 8080,
              basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              ipWhitelist: [],        // Set [] to allow all IP addresses
              useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
              httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
              httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
              language: "en",
              locale: "en-US",
              timeFormat: 24,
              units: "metric",
                      module:"MMM-Config",
                      position:"top_right",  // the QR code (if requested) will appear here
                      config:{
      ... (no changes after this point)
        sdetweil @BKeyport
        @bkeyport if u open the developers window, ctrl-shift-i, and select the console tab. are there errors shown
        also if u look in the pm2 logs, are there problems.
        do a
        git checkout newform
        and try again. lots of fixes there
        the latest code requires a port number to be passed to the form page… use the review link
        http://mm_ip:mm_port/modules/MMM-Config/review
        (thats the url on the qr image)
        BKeyportB 1 Reply Last reply
        • BKeyportB
          Failed to load resource (Connection refused) http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkO1_
          DevTools failed to load SourceMap: Could not load content for http://IP:8080/modules/MMM-Config/node_modules/jsonform/deps/opt/bootstrap.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          Then repeated
          (anonymous) @ VM6:1
          create @ polling-xhr.js:198
          Request @ polling-xhr.js:115
          request @ polling-xhr.js:62
          doPoll @ polling-xhr.js:90
          poll @ polling.js:74
          doOpen @ polling.js:23
          open @ transport.js:44
          open @ socket.js:194
          Socket @ socket.js:119
          ./node_modules/engine.io-client/lib/index.js.module.exports @ index.js:3
          open @ manager.js:112
          (anonymous) @ manager.js:342
          VM6:1 GET http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkPo7 net::ERR_CONNECTION_REFUSED
            sdetweil @BKeyport
            @bkeyport did u use the review link, its probably port 8300 now
            see the instructions here
            https://github.com/sdetweil/MMM-Config/issues/8
            • BKeyportB
              @sdetweil review link as shown redirects to:
              http://raspberrypi:8080/modules/MMM-Config/config.html?port=8301
              which fails because it’s not in DNS - changing raspberrypi to my IP address results in same header as before. Did update newform, and restarted MM.
              S 3 Replies Last reply
                sdetweil @BKeyport
                @bkeyport i have cors allow all …
                  sdetweil @BKeyport
                  @bkeyport I asked the machine for its IP address /name…
                  most routers now -a-days register the DHCP requests to names…
                  • BKeyportB
                    Yeah, my router setup is stupid in my testing area. :)
                      sdetweil @BKeyport
                      @bkeyport and npm install after checkout newform?
                      • BKeyportB
                        @sdetweil Yeah, that did it… Forgot to npm install. D’oh!
                        S 2 Replies Last reply
                          sdetweil @BKeyport
                          @bkeyport I construct the review url like this
                                // thi is the name in the preferences pi
                                this.hostname = os.hostname();
                                this.config.url =
                                  "http://" +
                                  (this.config.address == "0.0.0.0"
                                    ? this.hostname
                                    : this.config.address) +
                                  this.config.port;
                          so, lacking the dns entry, I would configure to use one of the specific ip addresses
                            sdetweil @BKeyport
                            @bkeyport
                            @bkeyport said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                            Yeah, that did it…
                            does that mean you system is working now?
                            • BKeyportB
                              @sdetweil Yeah. playing with it now making sure it works with my module and modules I’ve taken up support for.
                                sdetweil @BKeyport
                                @bkeyport cool… there are SO many variations… and guesses to make…
                                the upcoming multi-module version, will add on a new capability…
                                generate a new file that can be used to REALLY describe the parms, and take away any abiguity on my part.
                                I generate it ANYHOW to make the form work… so, its a nit to save it… I’m working thru USING the file, instead of recreating every time…
                                and then the author can tune it, to make selection lists, instead of text fields, etc…
                                optional sets of fields, depending on selection
                                the author packages that file with the module and voila, if its there my module uses it…
                                described here
                                https://github.com/sdetweil/MMM-Config/issues/11
                                • BKeyportB
                                  @sdetweil OK, it seems to be horribly broken on my side. From save to save, it’s not keeping the modules in config.js - example, my MMM-Multimonth won’t stay configured.
                                  I can’t disable default modules. (Calendar, which I don’t use due to incompatibility with my agenda provider)
                                  You want the config files to look though and see what’s happening?
                                    sdetweil @BKeyport
                                    @bkeyport yes please…
                                      I have updated the module now to support multiple instances of the same module,
                                      a little config (adding name to a file) … altho the module will auto detect if multiples are being used NOW, regardless of the file
                                      ALSO, one lacking feature of this solution is being able to get the form exactly right… as the info is missing in the module data…
                                      BUT i am creating the form info ANYHOW, so it can be saved and manually edited to improve the module experience, and I will use THAT instead of constructing the info every time…
                                      this means u can add selection lists, and other features (very easily)
                                      see the two issues for instructions
                                      multi-module
                                      https://github.com/sdetweil/MMM-Config/issues/2
                                      and save and use schema file
                                      Mykle1M 1 Reply Last reply
                                      Reply Quote 2
                                      • Mykle1M
                                        @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                        Oh, this is quite a feature, and much appreciated. :thumbsup:
                                          if u downloaded to test out multi-module, do another git pull…
                                          I had turned off rename of config.js while I tested save… oops… forgot to turn it back on
                                          corrected now
                                            I have promoted the multi-module version to be the only version…
                                            no need for any git checkout now
                                            • 14
                                            • 15
                                            • 3 / 15
