    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.9k Views 31 Watching
      sdetweil @BKeyport
      @bkeyport I asked the machine for its IP address /name…
      most routers now -a-days register the DHCP requests to names…
      BKeyportB 1 Reply Last reply
      • BKeyportB
        Yeah, my router setup is stupid in my testing area. :)
          sdetweil @BKeyport
          @bkeyport and npm install after checkout newform?
          • BKeyportB
            @sdetweil Yeah, that did it… Forgot to npm install. D’oh!
            S 2 Replies Last reply
              sdetweil @BKeyport
              @bkeyport I construct the review url like this
                    // thi is the name in the preferences pi
                    this.hostname = os.hostname();
                    this.config.url =
                      "http://" +
                      (this.config.address == "0.0.0.0"
                        ? this.hostname
                        : this.config.address) +
                      this.config.port;
              so, lacking the dns entry, I would configure to use one of the specific ip addresses
                sdetweil @BKeyport
                @bkeyport
                @bkeyport said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                Yeah, that did it…
                does that mean you system is working now?
                • BKeyportB
                  @sdetweil Yeah. playing with it now making sure it works with my module and modules I’ve taken up support for.
                    sdetweil @BKeyport
                    @bkeyport cool… there are SO many variations… and guesses to make…
                    the upcoming multi-module version, will add on a new capability…
                    generate a new file that can be used to REALLY describe the parms, and take away any abiguity on my part.
                    I generate it ANYHOW to make the form work… so, its a nit to save it… I’m working thru USING the file, instead of recreating every time…
                    and then the author can tune it, to make selection lists, instead of text fields, etc…
                    optional sets of fields, depending on selection
                    the author packages that file with the module and voila, if its there my module uses it…
                    described here
                    https://github.com/sdetweil/MMM-Config/issues/11
                    • BKeyportB
                      @sdetweil OK, it seems to be horribly broken on my side. From save to save, it’s not keeping the modules in config.js - example, my MMM-Multimonth won’t stay configured.
                      I can’t disable default modules. (Calendar, which I don’t use due to incompatibility with my agenda provider)
                      You want the config files to look though and see what’s happening?
                        sdetweil @BKeyport
                        @bkeyport yes please…
                          I have updated the module now to support multiple instances of the same module,
                          a little config (adding name to a file) … altho the module will auto detect if multiples are being used NOW, regardless of the file
                          ALSO, one lacking feature of this solution is being able to get the form exactly right… as the info is missing in the module data…
                          BUT i am creating the form info ANYHOW, so it can be saved and manually edited to improve the module experience, and I will use THAT instead of constructing the info every time…
                          this means u can add selection lists, and other features (very easily)
                          see the two issues for instructions
                          multi-module
                          https://github.com/sdetweil/MMM-Config/issues/2
                          and save and use schema file
                          Mykle1M 1 Reply Last reply
                          Reply Quote 2
                          • Mykle1M
                            @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                            Oh, this is quite a feature, and much appreciated. :thumbsup:
                              if u downloaded to test out multi-module, do another git pull…
                              I had turned off rename of config.js while I tested save… oops… forgot to turn it back on
                              corrected now
                                I have promoted the multi-module version to be the only version…
                                no need for any git checkout now
                                • Mykle1M
                                  65 emails from your repo. Come on man!
                                  :laughing:
                                  S BKeyportB 2 Replies Last reply
                                    sdetweil @Mykle1
                                    @mykle1 nah… you got a pool… I am jealous!!
                                    • BKeyportB
                                      BKeyport Module Developer @Mykle1
                                      @mykle1 We’re working hard. wanna help? 🤣🤣🤣
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @BKeyport
                                        Where were you at the very beginning of development of this module? I don’t remember seeing you anywhere. You were probably off policing the forum. :-)
                                        • BKeyportB
                                          @mykle1 When it was under early development I was in the very VERY busy part of my job.
                                          I’m a tax guy.
                                          • BKeyportB
                                            I’ve now added support for MMM-Config to the modules I’m working with actively.
                                            Was rather easy, all things considered - if you write a module, I would strongly recommend working with MMM-Config, who knows where this will go!
                                            • 14
                                            • 15
                                            • 4 / 15
