    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 446.9k Views 31 Watching
      I have updated the module now to support multiple instances of the same module,
      a little config (adding name to a file) … altho the module will auto detect if multiples are being used NOW, regardless of the file
      ALSO, one lacking feature of this solution is being able to get the form exactly right… as the info is missing in the module data…
      BUT i am creating the form info ANYHOW, so it can be saved and manually edited to improve the module experience, and I will use THAT instead of constructing the info every time…
      this means u can add selection lists, and other features (very easily)
      see the two issues for instructions
      multi-module
      https://github.com/sdetweil/MMM-Config/issues/2
      and save and use schema file
      https://github.com/sdetweil/MMM-Config/issues/11
        @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
        Oh, this is quite a feature, and much appreciated. :thumbsup:
          if u downloaded to test out multi-module, do another git pull…
          I had turned off rename of config.js while I tested save… oops… forgot to turn it back on
          corrected now
            I have promoted the multi-module version to be the only version…
            no need for any git checkout now
              65 emails from your repo. Come on man!
              :laughing:
              S BKeyportB 2 Replies Last reply Reply Quote 1
                sdetweil @Mykle1
                @mykle1 nah… you got a pool… I am jealous!!
                • BKeyportB Offline
                  BKeyport Module Developer @Mykle1
                  @mykle1 We’re working hard. wanna help? 🤣🤣🤣
                    Mykle1 Project Sponsor Module Developer @BKeyport
                    @bkeyport said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                    Where were you at the very beginning of development of this module? I don’t remember seeing you anywhere. You were probably off policing the forum. :-)
                    BKeyportB 1 Reply Last reply Reply Quote 1
                    • BKeyportB Offline
                      @mykle1 When it was under early development I was in the very VERY busy part of my job.
                      I’m a tax guy.
                      • BKeyportB Offline
                        I’ve now added support for MMM-Config to the modules I’m working with actively.
                        Was rather easy, all things considered - if you write a module, I would strongly recommend working with MMM-Config, who knows where this will go!
                          anima
                          hello i have a question, i am running MagiMirror ² in Docker on my Unraid Server, i have installed the module but cant open the config form site. do i need to make some special configurations because it runs in docker ?
                            sdetweil @anima
                            @anima what is your config.js setting for address:
                            you would have to use the container IP address and port on the form url. because it it not mapped to the docker host port
                              anima @sdetweil
                              @sdetweil do you mean this https://imgur.com/a/jzi0Idj ?
                                sdetweil @anima
                                @anima only needed the line with address:“0.0.0.0”
                                ok, so we need to find out the ip address of the MM container
                                docker ps
                                will give u a line like this
                                11e836525b8d   xxxyyyzzz   "/usr/bin/supervisord"   4 months ago   Up 3 weeks   0.0.0.0:82->81/tcp, :::82->81/tcp, 0.0.0.0:5901->5900/tcp, :::5901->5900/tcp, 0.0.0.0:8280->8080/tcp, :::8280->8080/tcp
                                the 1st token is the container id
                                then do this
                                docker inspect 11e836525b8d
                                and in the stream of info is
                                            "IPAddress": "172.17.0.2",
                                then use that from the system running the docker container
                                http://172.17.0.2:8300
                                to get that as one line of output, u can create this one line bash script
                                docker inspect $(docker ps -q | awk '{print $1}') | grep -m 1 '"IPAddress"' | awk -F\" '{print $4}'
                                you can’t use it from another system as there is no path to the container from outside
                                now, you could fix the startup of the MM container by adding
                                -p 8300:8300
                                to the docker run command
                                this map the container port 8300 to the host port 8300
                                then from your pc or non-docker-host machine
                                http://docker_host_ip:8300
                                should bring up the form
                                  anima @sdetweil
                                  @sdetweil ok thx, but then it should be better to run it from a pi (i have a spare one) because the container port is used by another service which i need.
                                    sdetweil @anima
                                    @anima well, each container has its own set…
                                    the code looks for a free port from 8300 - 8500… but in a container it will be fresh, so 8300
                                    the code hard codes 8300, so you can’t map it to anything else
                                    uros76U 1 Reply Last reply Reply Quote 0
                                    • uros76U Offline
                                      uros76 @sdetweil
                                      Hi. I am trying to implement it on my MM and get only get below header in the browser. I am trying to open it with this address http://raspberrypi:8080/modules/MMM-Config/review
                                      The same happens if I open MM via IP address.
                                      Did I miss something? I saw on page6 of this thread someone else had same problem but that solution didn’t help me.
                                      Doing ctrl+shift+I and looking at console output I get this error:
                                        sdetweil @uros76
                                        @uros76 can u show me the config.js for the module?
                                        does it show on the MM screen?
                                        is your config.js address:“localhost”
                                        if so, you can only access from the PI system itself (localhost means only apps INSIDE the pi can access that app)
                                        uros76U 1 Reply Last reply Reply Quote 1
                                          sdetweil @uros76
                                          @uros76 ok, can u send me config.js and the defaults.js from the MMM-Config folder…
                                          have to rename them to .txt to add as attachments
                                          via email…to my same userid at gmail…
                                          • uros76U Offline
                                            uros76 @sdetweil
                                            @sdetweil yes the module shows on screen in form of QR code. That part works.
                                            My basics from config file:
                                            address: "0.0.0.0",
                                            useHttps: false,
                                            port: 8080,
                                            ipWhitelist: [],
                                            • 14
                                            • 15
                                            • 4 / 15
