    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 245.4k Views 39 Watching
    • uros76U
      uros76 @Jalibu
      @jalibu you sir are a legend! Thanks a lot for such quick implementation of decimals idea. I just pulled the latest version and it works. Virtual beer for you :beer_mug:
      • JalibuJ
        Jalibu Module Developer
        The latest version has some major improvements for localizations in number formatting (i.e $123.45 en-US vs. 123,45 EUR de-DE)
        Please check it out and let me know if you‘re facing issues.
        • MartinLoidoltM
          MartinLoidolt
          Hello Jalibu,
          first and foremost i want to say that your module is very nice.
          But I want to ask you if it is possible to show the whole depot and not just the growth?
          Furthermore it would be nice to have the option to disable the color.
          Thanks for your Work!
          JalibuJ 1 Reply Last reply
          • JalibuJ
            Jalibu Module Developer @MartinLoidolt
            @martinloidolt
            Thank you for your comment and your ideas.
            I’ll add this as soon.
            L 1 Reply Last reply
            • L
              Leijoh @Jalibu
              @jalibu
              Hello! Love your module;) Maybe the almighty might be able to help me out a little?
              i cant seem to be able to standard a header?
              Have tried the following without any result.
              module: "MMM-Jast",
              header: 'Finanser',
              module: "MMM-Jast",
              header: '"Finanser",
              Any ideas would be much appreciated :)
              • JalibuJ
                Jalibu Module Developer @Leijoh
                @leijoh said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                Hi @Leijoh,
                you can rely on the almighty! There indeed was a problem with the header setting which was fixed in the latest 2.3.0 release.
                @martinloidolt said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                Hi @MartinLoidolt,
                I picked up both of your feature requests and put them in the latest 2.3.0 release, too.
                • L
                  Leijoh @Jalibu
                  @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                  Hi @Leijoh,
                  The ALMIGHTY has provided! Thanks alot:)
                  • G
                    gpaquin
                    Hello Everyone!
                    I’m currently trying to install and use this module but when I start it, it says “undefined” and I have no clue of what’s going on… I follow exactly the instruction but… I can’t make it work. Am I missing something?
                    Thank You!
                    • JalibuJ
                      Jalibu Module Developer @gpaquin
                      @gpaquin please send me a PN to provide more information
                        morphisto
                        Hi, is it possible to increase the font size? Often I have wear no glasses if I`m in my bath room after showering - and I need a bigger font size without glasses…
                        uros76U 1 Reply Last reply
                        • uros76U
                          uros76 @morphisto
                          @morphisto said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                          You can do that with CSS.
                          https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
                          M 1 Reply Last reply
                            morphisto @uros76
                            @uros76 I know how css works - but i cannot find the right class in the Jast Module to change the font size. Therefore I asked the developer if there is a chance to to it?
                            S JalibuJ 2 Replies Last reply
                              sdetweil @morphisto
                              @morphisto see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1622084388280
                              you can discover what you need to know
                              • JalibuJ
                                Jalibu Module Developer @morphisto
                                @morphisto
                                you should be fine by just adding
                                .jast-wrapper {
                                --size: 2.0rem;
                                to your custom css
                                  morphisto @Jalibu
                                  –size: 2.0rem;
                                  Thank You!
                                  • JalibuJ
                                    Dear user of this module,
                                    so far, the wording around the portfolio function was incorrect/misleading, as I incorrectly used the German term “Depot” for that.
                                    In the latest version the translation should be clearer.
                                    Attention: Due to the renaming, configuration properties have also changed. Temporarily old AND new properties are supported, but in future versions I will only support the new ones. So, please update your config.
                                    D 1 Reply Last reply
                                      doscas @Jalibu
                                      @Jalibu
                                      Hi, Just installed this. What a great addition to my MagicMirror. Congrats!
                                      I’m running on top of a background with pictures and I would like to have the letters fading when disappearing on the horizontal mode (guess it could be the same for the vertical mode).
                                      Instead of “seeing” an invisible line where all the letters just disappear, I believe a little fade option would be a design touch that would elevate this module a lot.
                                      I’m not sure I can achieve it with CSS only without damaging the view of the background picture.
                                      Thank you.
                                      • I
                                        ItsDonJ
                                        I love the idea of that Ticker but sadly if i try to use it, i also only get an “Undefined” error message on my mirror. Any idea why so? For the moment i tried it with the BASF and SAP-Stocks like in the example.
                                        • JalibuJ
                                          Jalibu Module Developer @ItsDonJ
                                          @itsdonj
                                          Please check your symbols. The “undefined” error comes when there are invalid symbols in your list
                                          • uros76U
                                            uros76
                                            @Jalibu thanks for your continuos work on this module. It’s awesome and I use it on few MM deployments. Virtual beer sent your way :)
                                            Perhaps you know, is there a way to pull a list of stocks into a config.js file, from a different file? I am no expert in JS but maybe there is a way to pull some of the config elements from a different file?
                                            • 4 / 9
