    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 232.9k Views 39 Watching
    • MartinLoidoltM Offline
      MartinLoidolt
      Hello Jalibu,
      first and foremost i want to say that your module is very nice.
      But I want to ask you if it is possible to show the whole depot and not just the growth?
      Furthermore it would be nice to have the option to disable the color.
      Thanks for your Work!
      JalibuJ 1 Reply Last reply Reply Quote 0
      • JalibuJ Offline
        Jalibu Module Developer @MartinLoidolt
        @martinloidolt
        Thank you for your comment and your ideas.
        I’ll add this as soon.
        • L Offline
          Leijoh @Jalibu
          @jalibu
          Hello! Love your module;) Maybe the almighty might be able to help me out a little?
          i cant seem to be able to standard a header?
          Have tried the following without any result.
          module: "MMM-Jast",
          header: 'Finanser',
          module: "MMM-Jast",
          header: '"Finanser",
          Any ideas would be much appreciated :)
          • JalibuJ Offline
            Jalibu Module Developer @Leijoh
            @leijoh said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
            Hi @Leijoh,
            you can rely on the almighty! There indeed was a problem with the header setting which was fixed in the latest 2.3.0 release.
            @martinloidolt said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
            Hi @MartinLoidolt,
            I picked up both of your feature requests and put them in the latest 2.3.0 release, too.
            • L Offline
              Leijoh @Jalibu
              @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
              Hi @Leijoh,
              The ALMIGHTY has provided! Thanks alot:)
              • G Offline
                gpaquin
                Hello Everyone!
                I’m currently trying to install and use this module but when I start it, it says “undefined” and I have no clue of what’s going on… I follow exactly the instruction but… I can’t make it work. Am I missing something?
                Thank You!
                • JalibuJ Offline
                  Jalibu Module Developer @gpaquin
                  @gpaquin please send me a PN to provide more information
                    morphisto
                    Hi, is it possible to increase the font size? Often I have wear no glasses if I`m in my bath room after showering - and I need a bigger font size without glasses…
                    uros76U 1 Reply Last reply Reply Quote 0
                    • uros76U Offline
                      uros76 @morphisto
                      @morphisto said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                      You can do that with CSS.
                      https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
                        morphisto @uros76
                        @uros76 I know how css works - but i cannot find the right class in the Jast Module to change the font size. Therefore I asked the developer if there is a chance to to it?
                        S JalibuJ 2 Replies Last reply Reply Quote 0
                          sdetweil @morphisto
                          @morphisto see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1622084388280
                          you can discover what you need to know
                          • JalibuJ Offline
                            Jalibu Module Developer @morphisto
                            @morphisto
                            you should be fine by just adding
                            .jast-wrapper {
                            --size: 2.0rem;
                            to your custom css
                              morphisto @Jalibu
                              –size: 2.0rem;
                              Thank You!
                              • JalibuJ Offline
                                Dear user of this module,
                                so far, the wording around the portfolio function was incorrect/misleading, as I incorrectly used the German term “Depot” for that.
                                In the latest version the translation should be clearer.
                                Attention: Due to the renaming, configuration properties have also changed. Temporarily old AND new properties are supported, but in future versions I will only support the new ones. So, please update your config.
                                  doscas @Jalibu
                                  @Jalibu
                                  Hi, Just installed this. What a great addition to my MagicMirror. Congrats!
                                  I’m running on top of a background with pictures and I would like to have the letters fading when disappearing on the horizontal mode (guess it could be the same for the vertical mode).
                                  Instead of “seeing” an invisible line where all the letters just disappear, I believe a little fade option would be a design touch that would elevate this module a lot.
                                  I’m not sure I can achieve it with CSS only without damaging the view of the background picture.
                                  Thank you.
                                  • I Offline
                                    ItsDonJ
                                    I love the idea of that Ticker but sadly if i try to use it, i also only get an “Undefined” error message on my mirror. Any idea why so? For the moment i tried it with the BASF and SAP-Stocks like in the example.
                                    • JalibuJ Offline
                                      Jalibu Module Developer @ItsDonJ
                                      @itsdonj
                                      Please check your symbols. The “undefined” error comes when there are invalid symbols in your list
                                      • uros76U Offline
                                        uros76
                                        @Jalibu thanks for your continuos work on this module. It’s awesome and I use it on few MM deployments. Virtual beer sent your way :)
                                        Perhaps you know, is there a way to pull a list of stocks into a config.js file, from a different file? I am no expert in JS but maybe there is a way to pull some of the config elements from a different file?
                                        • JalibuJ Offline
                                          Jalibu Module Developer @uros76
                                          Hi @uros76,
                                          thank you for the beer :-)
                                          What do you mean with “different file”? Should that be a central/remote file which should be loaded over the internet from different mirrors or just another local file on the same system?
                                          Prost!
                                          uros76U S 2 Replies Last reply Reply Quote 0
                                          • uros76U Offline
                                            uros76 @Jalibu
                                            @jalibu welcome :)
                                            Preferably the other file with defined stocks would be on the same system.
                                            I kind of get it how to make this work with python scripts but I have no clue if it’s possible with JS.
                                            • 4 / 9
